Results 1 to 2 of 2
Thread: Octows2811 For Dummies - Understanding PWM / DMA driven waveforms
    Senior Member crees's Avatar
    Dec 2016
    Utah
    216
    First the octows2811 is brilliant way to generate the ws2811 protocol! I want to really understand every bit of how this code does it job.
    I have made some comments to try to break this up and looking for corrections on my assumptions. I have placed ////////////// marks for comments on the code. More questions to follow below.
    Code below is portions of Octows2811 key points I am focusing on. Please see the actual library for full code.
    ////////// Set ones as all 1's 11111111
    static uint8_t ones = 0xFF;
    //////////// Set PWM TIMING Values
    #define WS2811_TIMING_T0H  60
    #define WS2811_TIMING_T1H  176
    //////////// SET UP TIMER based off of MCU TYPE
    #if defined(__MK20DX128__)
    	FTM1_SC = 0;
    	FTM1_CNT = 0;
    	uint32_t mod = (F_BUS + frequency / 2) / frequency;
    	FTM1_MOD = mod - 1;
    	FTM1_SC = FTM_SC_CLKS(1) | FTM_SC_PS(0);
    	FTM1_C0SC = 0x69;
    	FTM1_C1SC = 0x69;
    	FTM1_C0V = (mod * WS2811_TIMING_T0H) >> 8;
    	FTM1_C1V = (mod * WS2811_TIMING_T1H) >> 8;
    	// pin 16 triggers DMA(port B) on rising edge
    	CORE_PIN16_CONFIG = PORT_PCR_IRQC(1)|PORT_PCR_MUX(3);
    	//CORE_PIN4_CONFIG = PORT_PCR_MUX(3); // testing only
    #elif defined(__MK20DX256__)
    	FTM2_SC = 0;
    	FTM2_CNT = 0;
    	FTM2_MOD = mod - 1;
    	FTM2_SC = FTM_SC_CLKS(1) | FTM_SC_PS(0);
    	FTM2_C0SC = 0x69;
    	FTM2_C1SC = 0x69;
    	FTM2_C0V = (mod * WS2811_TIMING_T0H) >> 8;
    	FTM2_C1V = (mod * WS2811_TIMING_T1H) >> 8;
    	// pin 32 is FTM2_CH0, PTB18, triggers DMA(port B) on rising edge
    	// pin 25 is FTM2_CH1, PTB19
    	CORE_PIN32_CONFIG = PORT_PCR_IRQC(1)|PORT_PCR_MUX(3);
    	//CORE_PIN25_CONFIG = PORT_PCR_MUX(3); // testing only
    #elif defined(__MK64FX512__) || defined(__MK66FX1M0__)
    	FTM2_SC = 0;
    	FTM2_CNT = 0;
    	FTM2_MOD = mod - 1;
    	FTM2_C0SC = 0x69;
    	FTM2_C1SC = 0x69;
    	// FTM2_CH0, PTA10 (not connected), triggers DMA(port A) on rising edge
    	PORTA_PCR10 = PORT_PCR_IRQC(1)|PORT_PCR_MUX(3);
    #elif defined(__MKL26Z64__)
    	FTM2_SC = 0;
    	FTM2_CNT = 0;
    	uint32_t mod = F_CPU / frequency;
    	FTM2_MOD = mod - 1;
    	FTM2_C0SC = FTM_CSC_CHF | FTM_CSC_MSB | FTM_CSC_ELSB;
    	FTM2_C1SC = FTM_CSC_CHF | FTM_CSC_MSB | FTM_CSC_ELSB;
    	TPM2_C0V = mod - ((mod * WS2811_TIMING_T1H) >> 8);
    	TPM2_C1V = mod - ((mod * WS2811_TIMING_T1H) >> 8) + ((mod * WS2811_TIMING_T0H) >> 8);
    ////////////// PREPARE DMA 1, 2, 3 VALUES
    	// DMA channel #1 sets WS2811 high at the beginning of each cycle
    	dma1.source(ones);
    	dma1.destination(GPIOD_PSOR);
    	dma1.transferSize(1);
    	dma1.transferCount(bufsize);
    	dma1.disableOnCompletion();
    	// DMA channel #2 writes the pixel data at 23% of the cycle
    	dma2.sourceBuffer((uint8_t *)frameBuffer, bufsize);
    	dma2.destination(GPIOD_PDOR);
    	dma2.transferSize(1);
    	dma2.transferCount(bufsize);
    	dma2.disableOnCompletion();
    	// DMA channel #3 clear all the pins low at 69% of the cycle
    	dma3.source(ones);
    	dma3.destination(GPIOD_PCOR);
    	dma3.transferSize(1);
    	dma3.transferCount(bufsize);
    	dma3.disableOnCompletion();
    	dma3.interruptAtCompletion();
    ///////// DEFINE TRIGGERS FROM PORTB=DMA1 High Bit 1? AND TIMERS FOR THE DMA 2  3 CHANNELS? DEPENDING ON CHIP TYPE
    	// route the edge detect interrupts to trigger the 3 channels
    	dma1.triggerAtHardwareEvent(DMAMUX_SOURCE_PORTB);
    	dma2.triggerAtHardwareEvent(DMAMUX_SOURCE_FTM1_CH0);
    	dma3.triggerAtHardwareEvent(DMAMUX_SOURCE_FTM1_CH1);
    	DMAPriorityOrder(dma3, dma2, dma1);
    	dma2.triggerAtHardwareEvent(DMAMUX_SOURCE_FTM2_CH0);
    	dma3.triggerAtHardwareEvent(DMAMUX_SOURCE_FTM2_CH1);
    	dma1.triggerAtHardwareEvent(DMAMUX_SOURCE_PORTA);
    	// route the timer interrupts to trigger the 3 channels
    	dma1.triggerAtHardwareEvent(DMAMUX_SOURCE_TPM2_CH0);
    	dma2.triggerAtHardwareEvent(DMAMUX_SOURCE_TPM2_CH1);
    	dma3.triggerAtHardwareEvent(DMAMUX_SOURCE_FTM2_OV);
    	// enable a done interrupts when channel #3 completes
    	dma3.attachInterrupt(isr);
    	//pinMode(9, OUTPUT); // testing: oscilloscope trigger
    void OctoWS2811::isr(void)
    	//digitalWriteFast(9, HIGH);
    	//Serial1.print(".");
    	//Serial1.println(dma3.CFG->DCR, HEX);
    	//Serial1.print(dma3.CFG->DSR_BCR > 24, HEX);
    	dma3.clearInterrupt();
    #if defined(__MKL26Z64__)
    	GPIOD_PCOR = 0xFF;
    	//Serial1.print("*");
    	update_completed_at = micros();
    	update_in_progress = 0;
    	//digitalWriteFast(9, LOW);
    int OctoWS2811::busy(void)
    	if (update_in_progress) return 1;
    	// busy for 50 (or 300 for ws2813) us after the done interrupt, for WS2811 reset
    	if (micros() - update_completed_at < 300) return 1;
    	return 0;
    void OctoWS2811::show(void)
    	// wait for any prior DMA operation
    	//Serial1.print("1");
    	while (update_in_progress) ;
    	//Serial1.print("2");
    	// it's ok to copy the drawing buffer to the frame buffer
    	// during the 50us WS2811 reset time
    	if (drawBuffer != frameBuffer) {
    		// TODO: this could be faster with DMA, especially if the
    		// buffers are 32 bit aligned... but does it matter?
    		memcpy(frameBuffer, drawBuffer, stripLen * 24);
    	// wait for WS2811 reset
    	while (micros() - update_completed_at < 300) ;
    	// ok to start, but we must be very careful to begin
    	// without any prior 3 x 800kHz DMA requests pending
    ///////////  DEPENDING ON CHIP TYPE SET THE REGISTERS APPROPRIATELY AND SEND DMA VALUES (DMA x ENABLE?)
    	uint32_t cv = FTM1_C0V;
    	noInterrupts();
    	// CAUTION: this code is timing critical.
    	while (FTM1_CNT <= cv) ;
    	while (FTM1_CNT > cv) ; // wait for beginning of an 800 kHz cycle
    	while (FTM1_CNT < cv) ;
    	FTM1_SC = 0;            // stop FTM1 timer (hopefully before it rolls over)
    	FTM1_CNT = 0;
    	update_in_progress = 1;
    	//digitalWriteFast(9, HIGH); // oscilloscope trigger
    	PORTB_ISFR = (1<<0);    // clear any prior rising edge
    	uint32_t tmp __attribute__((unused));
    	FTM1_C0SC = 0x28;
    	tmp = FTM1_C0SC;        // clear any prior timer DMA triggers
    	FTM1_C0SC = 0x69;
    	FTM1_C1SC = 0x28;
    	tmp = FTM1_C1SC;
    	FTM1_C1SC = 0x69;
    	dma1.enable();
    	dma2.enable();          // enable all 3 DMA channels
    	dma3.enable();
    	FTM1_SC = FTM_SC_CLKS(1) | FTM_SC_PS(0); // restart FTM1 timer
    	FTM2_C0SC = 0x28;
    	FTM2_C1SC = 0x28;
    	uint32_t cv = FTM2_C0V;
    	noInterrupts();
    	while (FTM2_CNT <= cv) ;
    	while (FTM2_CNT > cv) ; // wait for beginning of an 800 kHz cycle
    	while (FTM2_CNT < cv) ;
    	FTM2_SC = 0;             // stop FTM2 timer (hopefully before it rolls over)
    	FTM2_CNT = 0;
    	PORTB_ISFR = (1<<18);    // clear any prior rising edge
    	FTM2_C0SC = 0x28;
    	tmp = FTM2_C0SC;         // clear any prior timer DMA triggers
    	FTM2_C0SC = 0x69;
    	FTM2_C1SC = 0x28;
    	tmp = FTM2_C1SC;
    	FTM2_C1SC = 0x69;
    	dma1.enable();
    	dma3.enable();
    	FTM2_SC = FTM_SC_CLKS(1) | FTM_SC_PS(0); // restart FTM2 timer
    	FTM2_C0SC = 0x28;
    	FTM2_C1SC = 0x28;
    	uint32_t cv = FTM2_C1V;
    	noInterrupts();
    	FTM2_CNT = 0;
    	#if defined(__MK64FX512__)
    	asm("nop");
    	PORTA_ISFR = (1<<10);    // clear any prior rising edge
    	FTM2_C0SC = 0x28;
    	FTM2_C0SC = 0x69;
    	FTM2_C1SC = 0x28;
    	tmp = FTM2_C1SC;
    	FTM2_C1SC = 0x69;
    	dma1.enable();
    	dma3.enable();
    	uint32_t sc __attribute__((unused)) = FTM2_SC;
    	noInterrupts();
    	dma1.clearComplete();
    	dma2.clearComplete();
    	dma3.clearComplete();
    	uint32_t bufsize = stripLen*24;
    	// clear any pending event flags
    	FTM2_SC = FTM_SC_TOF;
    	FTM2_C0SC = FTM_CSC_CHF | FTM_CSC_MSB | FTM_CSC_ELSB | FTM_CSC_DMA;
    	FTM2_C1SC = FTM_CSC_CHF | FTM_CSC_MSB | FTM_CSC_ELSB | FTM_CSC_DMA;
    	// clear any prior pending DMA requests
    	dma1.enable();
    	dma3.enable();
    	FTM2_CNT = 0; // writing any value resets counter
    	FTM2_SC = FTM_SC_DMA | FTM_SC_CLKS(1) | FTM_SC_PS(0);
    	//Serial1.print("3");
    	interrupts();
    	//Serial1.print("4");
    If I understand this correctly we are basically setting the values to generate two kinds of wave forms to satisfy a 0 and 1 in a synthesized NRZ. We use DMA to process the buffer values (0 or 1) to the 8 Pins. DMA1 sets the bits high (all 1's?). DMA 2 triggers the actual pixel data buffer, 0's pull the wave form low and 1's keep it high until DMA 3 brings them all low (0 ??)
    The question I have is in this code snippet and how its done.
    	dma3.source(ones); ///Is this all FF values (1's)???  this is my confusion.  I would think we should be all 0's  Or is setting the DMA the same value do the opposite???
    on dma3.source(ones).... Is this all FF values (1's)??? this is my confusion. I would think we should be all 0's Or is setting the DMA the same value do the opposite???
    Dec 2016
    Utah
    216
    It helps to read the manual often referred here in the forums. A good friend of mine pointed me to it as well. My answer is on page 1335 * 1336. dma3.source(ones) for GPIOD_PCOR according to the manual uses 1 to clear the port and reset its state to 0.
    The GPIOx_PSOR PDOR PCOR is corresponds to REGISTER, SET and CLEAR
    PSOR Data state of the pins high or low.
    PDOR Set will set the pins 1 or 0
    PCOR Clear will set all pins 0 (requires a value of 1 or FF in the case of all 8 pins)
    https://www.pjrc.com/teensy/K20P64M72SF1RM.pdf
