Results 1 to 3 of 3
Thread: SAE J1939 CAN to teensy 3.6
    Jan 2019
    1
    Hello everyone,
    I'm looking for a way to have some data of a Battery Management System (BMS) to be displayed on a dashboard of a car.
    The data that I need are on the Bus CAN format. Specifically the SAE J1939.
    We wan't to use a teensy 3.6 to convert the data from the BMS to the dashboard.
    Have anyone of you already tried this ? Or just to convert CAN data with a teensy 3.6 ?
    Thanks for everything !
    Dec 2016
    Montreal, Canada
    3,133
    not familiar with the j1939 protocol itself, but theres 2 libraries available for teensy 3.6 FlexCAN_Library and IFCT. You might want to search github for “J1939 arduino” or “J1939 teensy” to show what shows up. If you find a teensy version most likely it will be using FlexCAN_Library.
    Nov 2019
    1
    hello everyone,
    I'm looking for an exemple on teensy3.6 and reading protocol j1939.
    thanks for everything
