I2C Examples not working on Teensy 3.6
jingleby
I am at a loss as to why I can't get any communication between 2 teensy 3.6's. I am using a pull-up resistor (tried 4.7k and 2.2k). I've seen a variety of posts with similar issues. I had it working with an Uno to 3.2.
Trying a "Scanner" example didn't show any broadcaster/master, yet the master seems to be running properly as it is very basic code and pretty sure wired properly. Here's an image of the basic wiring ... both are wired the same.
Ultimately I need to send values of a couple variables to teensy's that control stepper motors (via TeensyStep). I have posted my previous code at the bottom which I need to expand so that I can retrieve several integer variables (motorSpeed, acceleration, enable, etc). Really hoping someone can help resolve my issues. Thanks!
MASTER EXAMPLE:
// Wire Master Writer
int led = LED_BUILTIN;
  pinMode(led, OUTPUT);
  Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
  digitalWrite(led, HIGH);    // briefly flash the LED
  Wire.beginTransmission(9);  // transmit to device #9
  Wire.write("x is ");        // sends five bytes
  Wire.write(x);              // sends one byte
  Wire.endTransmission();     // stop transmitting
  digitalWrite(led, LOW);
  x++;
SLAVE EXAMPLE:
// Wire Slave Receiver
  Wire.begin(9);                // join i2c bus with address #9
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
  while(Wire.available() > 1) {  // loop through all but the last
    char c = Wire.read();        // receive byte as a character
    Serial.print(c);             // print the character
  int x = Wire.read();           // receive byte as an integer
  Serial.println(x);             // print the integer
PREVIOUS WORKING CODE:
#include <StepControl.h>
unsigned long targetInterval = 5000; // read speed from master
unsigned long pulsePerSec = 1000000/targetInterval;
//Step, Dir
Stepper M1(23, 22), M2(21, 20), M3(17, 16), M4(15, 14), M5(12, 11), M6(10, 9), M7(8, 7), M8(6, 5), M9(4, 3);
StepControl<> controller;   // Use default settings
constexpr int spr = 16*200; // 3200 steps per revolution
int acceleration = 1500;
int pullInSpeed = 100;
const byte numMotors = 9;
int microSteps = 4;
int PPR = 5000; //pulses per rotation wo microstepping
int targetDist[numMotors] = {100*spr}; //50x decent
//int S1MaxSpeed[numMotors] = {50000};
//int S1MaxSpeed[numMotors] = {1*PPR*microSteps};
int S1MaxSpeed[numMotors] = {8000};
int scene = 0;
// SCL/SDA Stuff
byte b[3];  //byte array
bool flag1 = LOW;
  delay(2000);
  Wire.begin(8);                // join i2c bus with address #8
  delay(4000);
  Stepper* motorSet_A[] = {&M1, &M2, &M3, &M4, &M5, &M6, &M7, &M8, &M9};
  for (int i = 0; i < numMotors; i++) {
    motorSet_A[i]->setPullInSpeed(pullInSpeed);
    motorSet_A[i]->setAcceleration(acceleration);
  scene = 0;
//  if (scene != lastScene){  // only go through if scene changes
    switch (scene){
      case 0:
        M1.setMaxSpeed(S1MaxSpeed[0]);
        M2.setMaxSpeed(S1MaxSpeed[0]);
        M3.setMaxSpeed(S1MaxSpeed[0]);
        M4.setMaxSpeed(S1MaxSpeed[0]);
        M5.setMaxSpeed(S1MaxSpeed[0]);
        M6.setMaxSpeed(S1MaxSpeed[0]);
        M7.setMaxSpeed(S1MaxSpeed[0]);
        M8.setMaxSpeed(S1MaxSpeed[0]);
        M9.setMaxSpeed(S1MaxSpeed[0]);
        M1.setTargetRel(targetDist[0]);
        M2.setTargetRel(targetDist[0]);
        M3.setTargetRel(targetDist[0]);
        M4.setTargetRel(targetDist[0]);
        M5.setTargetRel(targetDist[0]);
        M6.setTargetRel(targetDist[0]);
        M7.setTargetRel(targetDist[0]);
        M8.setTargetRel(targetDist[0]);
        M9.setTargetRel(targetDist[0]);
//        for (int i = 0; i < numMotors; i++) {                    // loop through all motors in motorSet_A...
//          motorSet_A[i]->setTargetRel(targetDist[i]);                // ... set targets to 0...
//          motorSet_A[i]->setMaxSpeed(S1MaxSpeed[i]);
//          Serial.print(i); Serial.print(": MaxSpeed "); Serial.println(S1MaxSpeed[i]);
//          Serial.print(i); Serial.print(": targetDist "); Serial.println(targetDist[i]);
        Serial.print("M1: MaxSpeed "); Serial.println(S1MaxSpeed[0]);
        Serial.print("M1: TargetDist "); Serial.println(targetDist[0]);
//      default:
//        Serial.println("error");
//        break;
//  lastScene = scene;
    if (flag1 == HIGH){
      if (b[0] == '*')
        targetInterval = (b[1] << 8) | b[2];
        pulsePerSec = 1000000/targetInterval; //OLD SPEED STUFF
//        Serial.print("Slave Speed: ");
//        Serial.println(targetInterval, DEC); //target speed
        flag1 = LOW;
  controller.move(motorSet_A);
  delay(5000);
void receiveEvent(int howMany){
  for (int i = 0; i < howMany; i++){
    b[i] = Wire.read();
  flag1 = HIGH;
as teensy is very fast, put a delay(100) after wire.begin to let I2C settle before reading/writing. maybe this helps.
Your example master and slave work for me. I have 2.2K pullups to 3v3 and a common ground. your photo looked a little ambiguous ?, I presume both edges of the T3.6 were not pushed into same conductive plane of black breadboard.
I did add a delay(3000) after Wire.begin() in master, just to give slave a chance to fire up
Absolutely, there must be a common ground connection between the two Teensys.
