Results 1 to 8 of 8
Thread: rotary encoder does not decrement
    From existing examples below, If I turn the encoder in either direction, position is always being incremented. Encoder has connection to ground, and the two output pins. Any suggestions?
    #include <Encoder.h>
    Encoder knobLeft(34, 35);
      Serial.println("TwoKnobs Encoder Test:");
      knobLeft.write(0);
    long positionLeft  = -999;
      long newLeft;
      newLeft = knobLeft.read();
      if (newLeft != positionLeft ) {
        Serial.print(newLeft);
        positionLeft = newLeft;
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    122
    Hi Lamikam,
    When I tried your code, and rotated the encoder fast, I got the same issue.
    But when I rotated the encoder very slowly [<1 click/sec], the output nicely counted up & down as expected.
    Hooking up the oscilloscope showed a lot of spikes between the clicks of the encoder at fast rotating [sorry, no picture, should have hit the Print button then...].
    That reminded me that the encoder, an ALPS EC11E1544505, is rather bouncy/noisy. Especially when it's been laying around for a few weeks. I guess some kind of corrosion builts up?
    After a minute or 5 of fast rotating the encoder back & forth, the output became more stable [meaning counting reliably] at higher rotation speeds.
    The number of spikes decreased and counting looked OK. Best visible in the yellow trace. I guess rotating the encoder for a longer time cleans the internal contacts?
    Anyway, the Encoder library does not seem to like those bouncy/noisy encoders, so I coded my own encoder handler that seems to be more bounce/noise resistant:
    #define EncoderPinA 2                    // yellow wire
    #define EncoderPinB 3                    // purple wire
    boolean StateA;
    volatile boolean StateB;
    volatile boolean RotationDetected = false;
    int8_t EncoderClicks = 0;
      pinMode(EncoderPinA, INPUT_PULLUP);
      pinMode(EncoderPinB, INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(EncoderPinA), EncoderRotated, CHANGE);
      if (RotationDetected)                  // Check whether encoder is rotated
        delay(1);                            // Debounce the interrupt pin for 1ms before reading the state
        StateA = digitalRead(EncoderPinA);   // Read interrupt pinA
        if (StateA != StateB)                // Compare the states of both pins
          ++EncoderClicks;                   // CW, increment EncoderClicks by 1
          --EncoderClicks;                   // CCW, decrement EncoderClicks by 1
        RotationDetected = false;            // Clear the flag
        Serial.println(EncoderClicks);
    void EncoderRotated()                    // ISR for encoder
      StateB = digitalRead(EncoderPinB);     // read PinB
      RotationDetected = true;               // exit the ISR, further processing by the main loop
    By the way, this is the encoder switching diagram:
    Here is the setup I used for testing:
    The green wire from the encoder is the integrated push button [not used in this example].
    Hope this helps.
    Regards,
    Paul
    Awesome! You are the Man!
    Apr 2015
    Netherlands
    122
    You're welcome.
    Please let us know how it works out for you.
    Paul
    Apr 2017
    Florida
    453
    Or you could use an external circuit that greatly reduces the bounce that affects encoders. Iíve had great success using this circuit from Bourns and I havenít missed any steps as far as I can tell:
    Attachment 14072
    Thanks will take a look
    Feb 2016
    Australia
    250
    Hi Lamikam,
    Regards,
    Paul
    I found my detent stability point on the rotary encoder I purchased always gave gnd on a and b channels.
    The pulses would only appear between the indents. I thought maybe this was normal as some sort of mechanical debounce thing.. anyway it made reading the encoder give the same result as the op. (Depending on how fast I’m checking the inputs)
    Can I get confirmation that mine were duds..
    (Asdume I know how to use my scope)
    Apr 2015
    Netherlands
    122
    You may want to check the datasheet of the particular decoder you used.
    Another version ALPS decoder from the series I used has the following switching diagram:
    Paul
