Results 1 to 4 of 4
Thread: Midi
    Midi
    I want to interface a cheap midi controller such at this - https://www.amazon.com/ammoon-EasyCo.../dp/B01DKQZFSC to a teensy 3.6 with the teensy audio shield.
    The control message from the midi device will be linked to various attributes of the audio components - delay time, filter cutoff, etc. It looks like all the smaller/newer controllers only have a USB interface, and not the "old" 5-pin round connector.
    SO what options to I have to interface such a setup?
    THanks
    Leor
    Senior Member Blackaddr's Avatar
    Mar 2017
    Canada
    194
    If the device only has USB, you would need something to act as a HOST and can recognize USB MIDI Class compliant devices in order to extract the data, then send it out a serial port instead.
    You may be better off buying a proper MIDI controller with DIN connectors, or building your own. Teensy LC's are a great platform for custom building your own MIDI controller. No, it won't be as cheap as the one you linked if you need a lot of encoders and switches, but sometimes the only to get what you need is DIY.
    Olympia, WA
    52
    Since you have a Teensy 3.6, it can act as host. You might need a cable: https://www.pjrc.com/store/cable_usb_host_t36.html and the pins.
    This example code may help: Examples>USBHost_t36>MIDI>InputFunctions
    Actually I was mistaken. My axiom49 controller does have traditional midi in/out. So I got a breakout board to connect - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
