Results 1 to 4 of 4
Thread: 2.8" TFT touchscreen + Teensy++ 2.0
    Jan 2019
    5
    Rather than necroposting this thread, I thought I'd start another one:
    https://forum.pjrc.com/threads/16798...een-Teensy-3-0
    I have the exact same problem, but with a T++2. I am migrating from an Arduino Nano, where I FINALLY got the cheap Chinese screen working with a driver from MikeM at misc.ws. It's a shield not a breakout board, but I got it working.
    Using the teensy pinout guide, I have connected to the same pins (A0-A4 and D2-D9), but get a white screen. This indicates that the 8-bit data lines are not matching. I learned from the above forum post that PORTB and PORTB may not be mapping properly, but it is somewhat beyond my technical ability to modify the fix for a T++2. (I'm only a Java programmer! )
    Could somebody please guide me as to how to hook this up? I'm really hoping that I can just plug it into different pins!!!
    I will post the code here as instructed, but it's just the graphics test from the driver examples folder:
    #define LCD_CS A3
    #define LCD_CD A2
    #define LCD_WR A1
    #define LCD_RD A0
    #define LCD_RESET -1
    // Color definitions
    #define	BLACK           0x0000
    #define	BLUE            0x001F
    #define	RED             0xF800
    #define	GREEN           0x07E0
    #define CYAN            0x07FF
    #define MAGENTA         0xF81F
    #define YELLOW          0xFFE0
    #define WHITE           0xFFFF
    #include "TFTLCD.h"
    TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
    void setup(void) {
      Serial.println("8 Bit LCD test!");
      tft.reset();
      tft.initDisplay();
      testtext(RED);
      delay(2000);
      testlines(CYAN);
      testfastlines(RED, BLUE);
      testdrawrects(GREEN);
      testfillrects(YELLOW, MAGENTA);
      tft.fillScreen(BLACK);
      testfillcircles(10, MAGENTA);
      testdrawcircles(10, WHITE);
      testtriangles();
      testfilltriangles();
      testRoundRect();
      testFillRoundRect();
    void loop(void) {
      for (uint8_t rotation=0; rotation<4; rotation++) {
        tft.setRotation(rotation);
        testtext(RED);
    void testFillRoundRect() {
      for (uint16_t x=tft.width(); x > 20 ; x-=6) {
        tft.fillRoundRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, x/8,  tft.Color565(0, x, 0));
    void testRoundRect() {
      for (uint16_t x=0; x < tft.width(); x+=6) {
        tft.drawRoundRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, x/8, tft.Color565(x, 0, 0));
    void testtriangles() {
      for (uint16_t i=0; i<tft.width()/2; i+=5) {
        tft.drawTriangle(tft.width()/2, tft.height()/2-i,
                         tft.width()/2-i, tft.height()/2+i,
                         tft.width()/2+i, tft.height()/2+i, tft.Color565(0, 0, i));
    void testfilltriangles() {
      for (uint16_t i=tft.width()/2; i>10; i-=5) {
        tft.fillTriangle(tft.width()/2, tft.height()/2-i,
                         tft.Color565(0, i, i));
                         tft.width()/2+i, tft.height()/2+i, tft.Color565(i, i, 0));
    void testtext(uint16_t color) {
      tft.setCursor(0, 20);
      tft.setTextColor(color);
      tft.setTextSize(1);
      tft.println("Hello World!");
      tft.setTextSize(2);
      tft.println(1234.56);
      tft.setTextSize(3);
      tft.println(0xDEADBEEF, HEX);
    void testfillcircles(uint8_t radius, uint16_t color) {
      for (uint16_t x=radius; x < tft.width(); x+=radius*2) {
        for (uint16_t y=radius; y < tft.height(); y+=radius*2) {
          tft.fillCircle(x, y, radius, color);
    void testdrawcircles(uint8_t radius, uint16_t color) {
      for (uint16_t x=0; x < tft.width()+radius; x+=radius*2) {
        for (uint16_t y=0; y < tft.height()+radius; y+=radius*2) {
          tft.drawCircle(x, y, radius, color);
    void testfillrects(uint16_t color1, uint16_t color2) {
     for (uint16_t x=tft.width()-1; x > 6; x-=6) {
       //Serial.println(x, DEC);
       tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
       tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
    void testdrawrects(uint16_t color) {
       tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
    void testfastlines(uint16_t color1, uint16_t color2) {
       for (uint16_t y=0; y < tft.height(); y+=5) {
         tft.drawHorizontalLine(0, y, tft.width(), color1);
       for (uint16_t x=0; x < tft.width(); x+=5) {
         tft.drawVerticalLine(x, 0, tft.height(), color2);
    void testlines(uint16_t color) {
         tft.drawLine(0, 0, x, tft.height()-1, color);
       for (uint16_t y=0; y < tft.height(); y+=6) {
         tft.drawLine(0, 0, tft.width()-1, y, color);
         tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
         tft.drawLine(tft.width()-1, 0, 0, y, color);
         tft.drawLine(0, tft.height()-1, x, 0, color);
         tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
         tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
         tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
    void testBars() {
      uint16_t i,j;
      for(i=0; i < tft.height(); i++)
        for(j=0; j < tft.width(); j++)
          if(i>279) tft.writeData(WHITE);
          else if(i>239) tft.writeData(BLUE);
          else if(i>199) tft.writeData(GREEN);
          else if(i>159) tft.writeData(CYAN);
          else if(i>119) tft.writeData(RED);
          else if(i>79) tft.writeData(MAGENTA);
          else if(i>39) tft.writeData(YELLOW);
          else tft.writeData(BLACK);
    Aaaaand here is the driver!
    TFTLCD-mikem.zip
    Thank you!!!
    Jan 2019
    5
    Hello, I have an update for this issue. I have managed to get the TFT working just fine on a T3.6... and promptly fried my chip by being careless with a 5v component ;(
    So now I am back to a T++ 2.0. MCUFRIEND_kbv gave me good results, but it won't compile for T++ because of missing chip support in the header. Errors are below. I know I need to 'add' support into this file, but this is too low-level for me and I don't know how to adapt the T3 code for a T2. Could somebody please give me a magic string to paste?
    When compiling the graphicstest sketch:
    Arduino: 1.8.7 (Mac OS X), TD: 1.45, Board: "Teensy++ 2.0, Serial, 16 MHz, US English"
    In file included from /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:21:0:
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:236:2: error: #error MCU unsupported
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'void MCUFRIEND_kbv::reset()':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:64:17: error: 'setWriteDir' was not declared in this scope
         setWriteDir();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:243:31: error: 'RD_PORT' was not declared in this scope
     #define RD_OUTPUT  PIN_OUTPUT(RD_PORT, RD_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:261:24: note: in expansion of macro 'RD_OUTPUT'
     #define CTL_INIT()   { RD_OUTPUT; WR_OUTPUT; CD_OUTPUT; CS_OUTPUT; RESET_OUTPUT; }
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:65:5: note: in expansion of macro 'CTL_INIT'
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:243:40: error: 'RD_PIN' was not declared in this scope
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:243:46: error: 'PIN_OUTPUT' was not declared in this scope
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:246:31: error: 'WR_PORT' was not declared in this scope
     #define WR_OUTPUT  PIN_OUTPUT(WR_PORT, WR_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:261:35: note: in expansion of macro 'WR_OUTPUT'
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:246:40: error: 'WR_PIN' was not declared in this scope
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:249:31: error: 'CD_PORT' was not declared in this scope
     #define CD_OUTPUT  PIN_OUTPUT(CD_PORT, CD_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:261:46: note: in expansion of macro 'CD_OUTPUT'
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:249:40: error: 'CD_PIN' was not declared in this scope
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:252:31: error: 'CS_PORT' was not declared in this scope
     #define CS_OUTPUT  PIN_OUTPUT(CS_PORT, CS_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:261:57: note: in expansion of macro 'CS_OUTPUT'
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:252:40: error: 'CS_PIN' was not declared in this scope
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:255:34: error: 'RESET_PORT' was not declared in this scope
     #define RESET_OUTPUT  PIN_OUTPUT(RESET_PORT, RESET_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:261:68: note: in expansion of macro 'RESET_OUTPUT'
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:255:46: error: 'RESET_PIN' was not declared in this scope
         CTL_INIT();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:251:29: error: 'CS_PORT' was not declared in this scope
     #define CS_IDLE    PIN_HIGH(CS_PORT, CS_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:66:5: note: in expansion of macro 'CS_IDLE'
         CS_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:251:38: error: 'CS_PIN' was not declared in this scope
         CS_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:251:44: error: 'PIN_HIGH' was not declared in this scope
         CS_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:242:29: error: 'RD_PORT' was not declared in this scope
     #define RD_IDLE    PIN_HIGH(RD_PORT, RD_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:67:5: note: in expansion of macro 'RD_IDLE'
         RD_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:242:38: error: 'RD_PIN' was not declared in this scope
         RD_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:245:29: error: 'WR_PORT' was not declared in this scope
     #define WR_IDLE    PIN_HIGH(WR_PORT, WR_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:68:5: note: in expansion of macro 'WR_IDLE'
         WR_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:245:38: error: 'WR_PIN' was not declared in this scope
         WR_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:254:32: error: 'RESET_PORT' was not declared in this scope
     #define RESET_IDLE    PIN_HIGH(RESET_PORT, RESET_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:69:5: note: in expansion of macro 'RESET_IDLE'
         RESET_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:254:44: error: 'RESET_PIN' was not declared in this scope
         RESET_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:253:52: error: 'PIN_LOW' was not declared in this scope
     #define RESET_ACTIVE  PIN_LOW(RESET_PORT, RESET_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:71:5: note: in expansion of macro 'RESET_ACTIVE'
         RESET_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'void MCUFRIEND_kbv::WriteCmdData(uint16_t, uint16_t)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:250:28: error: 'CS_PORT' was not declared in this scope
     #define CS_ACTIVE  PIN_LOW(CS_PORT, CS_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:80:5: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:250:37: error: 'CS_PIN' was not declared in this scope
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:250:43: error: 'PIN_LOW' was not declared in this scope
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:247:28: error: 'CD_PORT' was not declared in this scope
     #define CD_COMMAND PIN_LOW(CD_PORT, CD_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:262:24: note: in expansion of macro 'CD_COMMAND'
     #define WriteCmd(x)  { CD_COMMAND; write16(x); }
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:81:5: note: in expansion of macro 'WriteCmd'
         WriteCmd(cmd);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:247:37: error: 'CD_PIN' was not declared in this scope
         WriteCmd(cmd);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:262:45: error: 'write16' was not declared in this scope
         WriteCmd(cmd);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:248:29: error: 'CD_PORT' was not declared in this scope
     #define CD_DATA    PIN_HIGH(CD_PORT, CD_PIN)
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:263:24: note: in expansion of macro 'CD_DATA'
     #define WriteData(x) { CD_DATA; write16(x); }
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:82:5: note: in expansion of macro 'WriteData'
         WriteData(dat);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:248:38: error: 'CD_PIN' was not declared in this scope
         WriteData(dat);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:248:44: error: 'PIN_HIGH' was not declared in this scope
         WriteData(dat);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/mcufriend_shield.h:263:42: error: 'write16' was not declared in this scope
         WriteData(dat);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:83:5: note: in expansion of macro 'CS_IDLE'
         CS_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In function 'void WriteCmdParamN(uint16_t, int8_t, uint8_t*)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:88:5: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:89:5: note: in expansion of macro 'WriteCmd'
         WriteCmd(cmd);
         WriteCmd(cmd);
         WriteCmd(cmd);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:92:9: note: in expansion of macro 'CD_DATA'
             CD_DATA;
             CD_DATA;
             CD_DATA;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:93:18: error: 'write8' was not declared in this scope
             write8(u8);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:96:13: note: in expansion of macro 'WriteCmd'
                 WriteCmd(cmd);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:99:5: note: in expansion of macro 'CS_IDLE'
         CS_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In function 'uint16_t read16bits()':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:121:15: error: 'READ_8' was not declared in this scope
         READ_8(ret);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In function 'uint32_t readReg40(uint16_t)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:131:5: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:132:5: note: in expansion of macro 'WriteCmd'
         WriteCmd(reg);
         WriteCmd(reg);
         WriteCmd(reg);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:133:16: error: 'setReadDir' was not declared in this scope
         setReadDir();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:134:5: note: in expansion of macro 'CD_DATA'
         CD_DATA;
         CD_DATA;
         CD_DATA;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:138:5: note: in expansion of macro 'RD_IDLE'
         RD_IDLE;
         RD_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:140:17: error: 'setWriteDir' was not declared in this scope
         setWriteDir();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'uint16_t MCUFRIEND_kbv::readReg(uint16_t)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:150:5: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:151:5: note: in expansion of macro 'WriteCmd'
         WriteCmd(reg);
         WriteCmd(reg);
         WriteCmd(reg);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:152:16: error: 'setReadDir' was not declared in this scope
         setReadDir();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:153:5: note: in expansion of macro 'CD_DATA'
         CD_DATA;
         CD_DATA;
         CD_DATA;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:156:5: note: in expansion of macro 'RD_IDLE'
         RD_IDLE;
         RD_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:158:17: error: 'setWriteDir' was not declared in this scope
         setWriteDir();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:147:13: warning: unused variable 'lo' [-Wunused-variable]
         uint8_t lo;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'uint32_t MCUFRIEND_kbv::readReg32(uint16_t)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:165:5: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:166:5: note: in expansion of macro 'WriteCmd'
         WriteCmd(reg);
         WriteCmd(reg);
         WriteCmd(reg);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:167:16: error: 'setReadDir' was not declared in this scope
         setReadDir();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:168:5: note: in expansion of macro 'CD_DATA'
         CD_DATA;
         CD_DATA;
         CD_DATA;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:171:5: note: in expansion of macro 'RD_IDLE'
         RD_IDLE;
         RD_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:173:17: error: 'setWriteDir' was not declared in this scope
         setWriteDir();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'uint16_t MCUFRIEND_kbv::readID()':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:179:19: warning: unused variable 'ret2' [-Wunused-variable]
         uint16_t ret, ret2;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'int16_t MCUFRIEND_kbv::readGRAM(int16_t, int16_t, uint16_t*, int16_t, int16_t)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:249:9: note: in expansion of macro 'CS_ACTIVE'
             CS_ACTIVE;
             CS_ACTIVE;
             CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:250:9: note: in expansion of macro 'WriteCmd'
             WriteCmd(_MR);
             WriteCmd(_MR);
             WriteCmd(_MR);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:251:20: error: 'setReadDir' was not declared in this scope
             setReadDir();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:252:9: note: in expansion of macro 'CD_DATA'
             CD_DATA;
             CD_DATA;
             CD_DATA;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:256:21: error: 'READ_8' was not declared in this scope
                 READ_8(r);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:258:26: error: 'READ_16' was not declared in this scope
                 READ_16(dummy);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:260:34: error: 'READ_8' was not declared in this scope
       if (_lcd_ID == 0x1511) READ_8(r);   //extra dummy for R61511
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:263:25: error: 'READ_8' was not declared in this scope
                     READ_8(r);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:271:28: error: 'READ_16' was not declared in this scope
                     READ_16(ret);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:287:9: note: in expansion of macro 'RD_IDLE'
             RD_IDLE;
             RD_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:289:21: error: 'setWriteDir' was not declared in this scope
             setWriteDir();
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:240:22: warning: unused variable 'tmp' [-Wunused-variable]
         uint8_t r, g, b, tmp;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'virtual void MCUFRIEND_kbv::setRotation(uint8_t)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:298:27: warning: unused variable 'REV' [-Wunused-variable]
         uint16_t GS, SS, ORG, REV = _lcd_rev;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:371:11: warning: label 'common_S6D' defined but not used [-Wunused-label]
               common_S6D:
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'virtual void MCUFRIEND_kbv::fillRect(int16_t, int16_t, int16_t, int16_t, uint16_t)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:502:5: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:503:5: note: in expansion of macro 'WriteCmd'
         WriteCmd(_MW);
         WriteCmd(_MW);
         WriteCmd(_MW);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:510:5: note: in expansion of macro 'CD_DATA'
         CD_DATA;
         CD_DATA;
         CD_DATA;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:538:22: error: 'write8' was not declared in this scope
                 write8(hi);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'void MCUFRIEND_kbv::pushColors(uint16_t*, int16_t, bool)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:551:5: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:553:9: note: in expansion of macro 'WriteCmd'
             WriteCmd(_MW);
             WriteCmd(_MW);
             WriteCmd(_MW);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:555:5: note: in expansion of macro 'CD_DATA'
         CD_DATA;
         CD_DATA;
         CD_DATA;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:558:22: error: 'write16' was not declared in this scope
             write16(color);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'void MCUFRIEND_kbv::pushColors(uint8_t*, int16_t, bool)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:567:5: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:569:9: note: in expansion of macro 'WriteCmd'
             WriteCmd(_MW);
             WriteCmd(_MW);
             WriteCmd(_MW);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:571:5: note: in expansion of macro 'CD_DATA'
         CD_DATA;
         CD_DATA;
         CD_DATA;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:576:22: error: 'write16' was not declared in this scope
             write16(color);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'void MCUFRIEND_kbv::pushColors(const uint8_t*, int16_t, bool)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:585:5: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:587:9: note: in expansion of macro 'WriteCmd'
             WriteCmd(_MW);
             WriteCmd(_MW);
             WriteCmd(_MW);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:589:5: note: in expansion of macro 'CD_DATA'
         CD_DATA;
         CD_DATA;
         CD_DATA;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:594:22: error: 'write16' was not declared in this scope
             write16(color);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In function 'void init_table16(const void*, int16_t)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:765:13: note: in expansion of macro 'CS_ACTIVE'
                 CS_ACTIVE;
                 CS_ACTIVE;
                 CS_ACTIVE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:766:13: note: in expansion of macro 'WriteCmd'
                 WriteCmd(cmd);
                 WriteCmd(cmd);
                 WriteCmd(cmd);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:767:13: note: in expansion of macro 'WriteData'
                 WriteData(d);
                 WriteData(d);
                 WriteData(d);
                 WriteData(d);
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:768:13: note: in expansion of macro 'CS_IDLE'
                 CS_IDLE;
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp: In member function 'void MCUFRIEND_kbv::begin(uint16_t)':
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:1343:30: warning: unused variable 'ST7789_regValues_arcain6' [-Wunused-variable]
             static const uint8_t ST7789_regValues_arcain6[] PROGMEM = {
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:2079:30: warning: unused variable 'ILI9481_CPT29_regValues' [-Wunused-variable]
             static const uint8_t ILI9481_CPT29_regValues[] PROGMEM = {    // 320x430
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:2104:30: warning: unused variable 'ILI9481_PVI35_regValues' [-Wunused-variable]
             static const uint8_t ILI9481_PVI35_regValues[] PROGMEM = {    // 320x480
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:2127:30: warning: unused variable 'ILI9481_AUO317_regValues' [-Wunused-variable]
             static const uint8_t ILI9481_AUO317_regValues[] PROGMEM = {    // 320x480
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:2149:30: warning: unused variable 'ILI9481_CMO35_regValues' [-Wunused-variable]
             static const uint8_t ILI9481_CMO35_regValues[] PROGMEM = {    // 320480
    /Users/Tyson/Documents/Arduino/libraries/MCUFRIEND_kbv/MCUFRIEND_kbv.cpp:2173:30: warning: unused variable 'ILI9481_RGB_regValues' [-Wunused-variable]
             static const uint8_t ILI9481_RGB_regValues[] PROGMEM = {    // 320x480
    Error compiling for board Teensy++ 2.0.
    7,992
    Sorry I've only touched a Teensy - all the Teensy's - with the 32 bit ARM processors. That would be the T3 code and if it isn't already compatible then it won't be an easy job I'd assume.
    But giving a look I found this page from AdaFruit 2-8-tft-touch-shield
    If my reading is right that is what you have and there they link to an AVR driver that "Works with any Arduino '328 or Mega" - there they offer these libraries ...
    Hoping that can be adjusted to work? You may need to refer to the T2++ schematic to associate the pins from desired port?
    Jan 2019
    5
    Thank you. I had previously tried those libs with little success. It's an off-brand TFT after all. In the end I raised an issue with MCUFRIEND_kvb, and within 24 hours he had pasted a new set of defines for the T++, with no way of testing them... worked first time. What a legend.
