Results 1 to 2 of 2
Thread: Accuracy of Teensy 3.5
    Hello, what is the accuracy of the Teensy 3.5's analog input pins? I will measure the voltage of a battery by using analog input pins, and accuracy information is required for me.
    Feb 2014
    Colmar, France
    2,321
    The ADCs have 12bit resolution. You can even set them to 16bit, but the last 3-4 bits will mostly contain noise, so we start with 12 usable bits which corresponds to 4096 steps. Then, you might choose between two reference voltages: 3.3V and 1.2V. If you take 3.3V, step height will be 3.3/4096= 0.8057mV or roughly +/- 0.4mV. With the 1.2V reference, it's 1.2/4096 = 0.2930mV or roughly +/- 0.15mV. More detailed info about noise, ENOB and DNL in the data sheet: https://www.pjrc.com/teensy/K64P144M120SF5.pdf
