Results 1 to 5 of 5
Thread: Calling attachInterrupt() inside a C++ class
    I'm trying to write a C++ class which a attachInterrupt() is called but it won't compile and giving me an error message of :
    /var/folders/6s/w7v5ds1s2hb0f3g_z9fb0ftc0000gn/T/arduino_build_39910/sketch/lin.cpp: In member function 'void lin::slave_init()':
    lin.cpp:16: error: invalid use of non-static member function
    attachInterrupt(digitalPinToInterrupt(rx_pin),rxIS R,CHANGE);
    How can I fix this ?
    isr_test.ino
    #include "lin.h"
    lin linslave(1);
    lin.cpp
    #include "lin.h"
    lin::lin(uint8_t Rx_pin)
     rx_pin = Rx_pin;
    void lin::rxISR(void)
      uint8_t i;
    void lin::slave_init(void)
      attachInterrupt(digitalPinToInterrupt(rx_pin),rxISR,CHANGE);  // <- This line won't compile
    lin.h
    #include <Arduino.h>
    class lin
      public:
      lin(uint8_t Rx_pin);
      void rxISR(void);
      void slave_init(void);
      private:
      uint8_t rx_pin;
    This compiles ok if I don't use class and put everything in the .ino file but making a class would be more useful to others.
    Germany NRW
    5,513
    Why is it more useful? You can use the interrupt vector only one time.
    More useful to others, as in people by making a class in a library.
    Feb 2017
    270
    You can't get a pointer to a member function the same way as a regular function. See: https://isocpp.org/wiki/faq/pointers-to-members
    19,692
    This line in the class definition is the problem.
      void rxISR(void);
    Functions called from attachInterrupt must be static.
