Results 1 to 6 of 6
Thread: E1.31 sACN Ethernet DMX - MegaPixel One W5500 TX socket problems
    Jan 2019
    7
    Hi group,
    I am using "crees" library"MegaPixel-One-Socket-Ethernet-masterV2_W5500" and it's working perfect to receive data. However I want to create a simple Ethernet Server to configure some parameters like the number of strips, number of leds per strip... and can't make it work. I've searched that for a TCP server, I need at least 2 sockets. So I've changed the buffer to 8K and increased the "#define MAX_SOCK_NUM" to 2 on "w5100.h" and "Ethernet.h", but still no succeed.
    Here is the code for the Ethernet Server; "page1" it's just a simple html page that i use for test. If I use the 4K or 2K buffer, everything works fine. But with 8K or 16K I only get the message: "new client" into the serial monitor and a lot of random chars. The client can't connect.
    I've made some changes into the file "w5100.cpp" to make the 8K buffer works for receive, in the original it was not working.
    I'm using Teensy 3.2 with Wiz850io
    EthernetClient client = server.available();
      if (client) {
        Serial.println("new client");
        boolean currentLineIsBlank = true;
        while (client.connected()) {
          if (client.available()) {
            char c = client.read();
            Serial.write(c);
            if (c == '\n' && currentLineIsBlank) {
              client.println("HTTP/1.1 200 OK");
              client.println("Content-Type: text/html");
              client.println("Connnection: close");
              client.println();
              client.println(page1);
            if (c == '\n') {
            else if (c != '\r') {
              currentLineIsBlank = false;
        delay(1);
        client.stop();
        Serial.println("client disonnected");
    //w5100.cpp modified file
     * Copyright (c) 2010 by Cristian Maglie <c.maglie@bug.st>
     * This file is free software; you can redistribute it and/or modify
     * it under the terms of either the GNU General Public License version 2
     * or the GNU Lesser General Public License version 2.1, both as
     * published by the Free Software Foundation.
    #include "w5100.h"
    #if defined(__arm__) && defined(TEENSYDUINO)
    #include "SPIFIFO.h"
    #ifdef  HAS_SPIFIFO
    #define USE_SPIFIFO
    //#define W5500_4K_BUFFERS
    //#define W5200_2K_BUFFERS
    //#define W5200_4K_BUFFERS
    //#define W5200_8K_BUFFERS        //MAX_SOCK_NUM has to be 2
    //#define W5200_16K_BUFFERS        //MAX_SOCK_NUM has to be 1
    #define W5500_8K_BUFFERS
    // If the core library defines a SS pin, use it as the
    // default.  Otherwise, default the default to pin 10.
    #if defined(PIN_SPI_SS)
    #define SS_PIN_DEFAULT  PIN_SPI_SS
    #elif defined(CORE_SS0_PIN)
    #define SS_PIN_DEFAULT  CORE_SS0_PIN
    #else
    #define SS_PIN_DEFAULT  10
    // W5100 controller instance
    uint16_t W5100Class::SBASE[MAX_SOCK_NUM];
    uint16_t W5100Class::RBASE[MAX_SOCK_NUM];
    uint16_t W5100Class::CH_BASE;
    uint16_t W5100Class::SSIZE;
    uint16_t W5100Class::SMASK;
    uint8_t  W5100Class::chip;
    uint8_t  W5100Class::ss_pin = SS_PIN_DEFAULT;
    W5100Class W5100;
    // pointers and bitmasks for optimized SS pin
    #if defined(__AVR__)
      volatile uint8_t * W5100Class::ss_pin_reg;
      uint8_t W5100Class::ss_pin_mask;
    #elif defined(__MK20DX128__) || defined(__MK20DX256__) || defined(__MK66FX1M0__) || defined(__MK64FX512__)
    #elif defined(__MKL26Z64__)
    #elif defined(__SAM3X8E__) || defined(__SAM3A8C__) || defined(__SAM3A4C__)
      volatile uint32_t * W5100Class::ss_pin_reg;
      uint32_t W5100Class::ss_pin_mask;
    #elif defined(__PIC32MX__)
    #elif defined(ARDUINO_ARCH_ESP8266)
    #elif defined(__SAMD21G18A__)
    uint8_t W5100Class::init(void)
    	uint16_t TXBUF_BASE, RXBUF_BASE;
    	uint8_t i;
    	// Many Ethernet shields have a CAT811 or similar reset chip
    	// connected to W5100 or W5200 chips.  The W5200 will not work at
    	// all, and may even drive its MISO pin, until given an active low
    	// reset pulse!  The CAT811 has a 240 ms typical pulse length, and
    	// a 400 ms worst case maximum pulse length.  MAX811 has a worst
    	// case maximum 560 ms pulse length.  This delay is meant to wait
    	// until the reset pulse is ended.  If your hardware has a shorter
    	// reset time, this can be edited or removed.
    	delay(560);
    	//Serial.println("w5100 init");
    #ifdef USE_SPIFIFO
    	SPI.begin();
    	SPIFIFO.begin(ss_pin, SPI_CLOCK_24MHz);  // W5200 or W5500 Will not work with W5100
    #else
    	SPI.begin();
    	initSS();
    	resetSS();
    	SPI.beginTransaction(SPI_ETHERNET_SETTINGS);
    	// Attempt W5200 detection first, because W5200 does not properly
    	// reset its SPI state when CS goes high (inactive).  Communication
    	// from detecting the other chips can leave the W5200 in a state
    	// where it won't recover, unless given a reset pulse.
    	if (isW5200()) {
    		CH_BASE = 0x4000;
        	#ifdef W5200_16K_BUFFERS
    			Serial.println("W5200 16K_BUFFER_ACTIVE");
        		SSIZE = 16384;
        	#ifdef W5200_8K_BUFFERS
        		SSIZE = 8192;
    		#ifdef W5200_4K_BUFFERS
    			SSIZE = 4096;
        	#ifdef W5200_2K_BUFFERS
    			SSIZE = 2048;    // 2K buffers
        	SMASK = SSIZE-1;
    		TXBUF_BASE = 0x8000;
    		RXBUF_BASE = 0xC000;
    		for (i=0; i<MAX_SOCK_NUM; i++) {
    			writeSnRX_SIZE(i, SSIZE >> 10);
    			writeSnTX_SIZE(i, SSIZE >> 10);
    		for (; i<8; i++) {
    			writeSnRX_SIZE(i, 0);
    			writeSnTX_SIZE(i, 0);
    		// Try W5500 next.  Wiznet finally seems to have implemented
    		// SPI well with this chip.  It appears to be very resilient,
    		// so try it after the fragile W5200
    	else if (isW5500()) {
    		CH_BASE = 0x1000;
    		#if defined(W5500_16K_BUFFERS)
    		Serial.println("W5500 16K_BUFFER_ACTIVE");
    		SSIZE = 16384;   // 16K buffers
    		#elif defined(W5500_8K_BUFFERS)
    		SSIZE = 8192;    // 8K buffers
    		#elif defined(W5500_4K_BUFFERS)
    		SSIZE = 4096;    // 4K buffers
    		#elif defined(W5500_2K_BUFFERS)
    		SMASK = SSIZE - 1;
    		#ifndef W5500_2K_BUFFERS
    		for (i = 0; i<MAX_SOCK_NUM; i++) {
    		for (; i<8; i++) {
    	// Try W5100 last.  This simple chip uses fixed 4 byte frames
    	// for every 8 bit access.  Terribly inefficient, but so simple
    	// it recovers from "hearing" unsuccessful W5100 or W5200
    	// communication.  W5100 is also the only chip without a VERSIONR
    	// register for identification, so we check this last.
    	} else if (isW5100()) {
    		CH_BASE = 0x0400;
    		SSIZE = 2048;
    		SMASK = 0x07FF;
    		TXBUF_BASE = 0x4000;
    		RXBUF_BASE = 0x6000;
    		writeTMSR(0x55);
    		writeRMSR(0x55);
    	// No hardware seems to be present.  Or it could be a W5200
    	// that's heard other SPI communication if its chip select
    	// pin wasn't high when a SD card or other SPI chip was used.
    		//Serial.println("no chip :-(");
    		chip = 0;
    		SPI.endTransaction();
    		return 0; // no known chip is responding :-(
    	// Initialize the socket base addresses
    	for (int i=0; i<MAX_SOCK_NUM; i++) {
    		SBASE[i] = TXBUF_BASE + SSIZE * i;
    		RBASE[i] = RXBUF_BASE + SSIZE * i;
    	return 1; // successful init
    // Soft reset the Wiznet chip, by writing to its MR register reset bit
    uint8_t W5100Class::softReset(void)
    	uint16_t count=0;
    	//Serial.println("Wiznet soft reset");
    	// write to reset bit
    	writeMR(0x80);
    	// then wait for soft reset to complete
    	do {
    		uint8_t mr = readMR();
    		//Serial.print("mr=");
    		//Serial.println(mr, HEX);
    		if (mr == 0) return 1;
    		delay(1);
    	} while (++count < 20);
    	return 0;
    uint8_t W5100Class::isW5100(void)
    	chip = 51;
    	//Serial.println("w5100.cpp: detect W5100 chip");
    	if (!softReset()) return 0;
    	writeMR(0x10);
    	if (readMR() != 0x10) return 0;
    	writeMR(0x12);
    	if (readMR() != 0x12) return 0;
    	writeMR(0x00);
    	if (readMR() != 0x00) return 0;
    	//Serial.println("chip is W5100");
    	return 1;
    uint8_t W5100Class::isW5200(void)
    	chip = 52;
    	//Serial.println("w5100.cpp: detect W5200 chip");
    	writeMR(0x08);
    	if (readMR() != 0x08) return 0;
    	writeMR(0x10);
    	writeMR(0x00);
    	int ver = readVERSIONR_W5200();
    	//Serial.print("version=");
    	//Serial.println(ver);
    	if (ver != 3) return 0;
    	//Serial.println("chip is W5200");
    	return 1;
    uint8_t W5100Class::isW5500(void)
    	chip = 55;
    	//Serial.println("w5100.cpp: detect W5500 chip");
    	writeMR(0x08);
    	writeMR(0x10);
    	writeMR(0x00);
    	int ver = readVERSIONR_W5500();
    	if (ver != 4) return 0;
    	//Serial.println("chip is W5500");
    	return 1;
    #ifdef USE_SPIFIFO
    uint16_t W5100Class::write(uint16_t addr, const uint8_t *buf, uint16_t len)
      uint32_t i;
      if (chip == 51) {
        for (i=0; i<len; i++) {
    	SPIFIFO.write16(0xF000 | (addr >> 8), SPI_CONTINUE);
    	SPIFIFO.write16((addr << 8) | buf[i]);
    	addr++;
    	SPIFIFO.read();
    	SPIFIFO.read();
      } else if (chip == 52) {
    	SPIFIFO.clear();
    	SPIFIFO.write16(addr, SPI_CONTINUE);
    	SPIFIFO.write16(len | 0x8000, SPI_CONTINUE);
    		SPIFIFO.write(buf[i], ((i+1<len) ? SPI_CONTINUE : 0));
    		SPIFIFO.read();
    	SPIFIFO.read();
    	SPIFIFO.read();
    	SPIFIFO.clear();
    	if (addr < 0x100) {
    		// common registers 00nn
    		SPIFIFO.write16(0x0400 | *buf++,
    			((len > 1) ? SPI_CONTINUE : 0));
    	} else if (addr < 0x8000) {
    		// socket registers  10nn, 11nn, 12nn, 13nn, etc
    		SPIFIFO.write16(((addr << 5) & 0xE000) | 0x0C00 | *buf++,
    	} else if (addr < 0xC000) {
    		// transmit buffers  8000-87FF, 8800-8FFF, 9000-97FF, etc
    		SPIFIFO.write16(((addr << 1) & 0x2000) | 0x1400 | *buf++, // 16K buffers
    		SPIFIFO.write16(((addr << 0) & 0x4000) | 0x1400 | *buf++, // 8K buffers
    		#elif defined (W5500_4K_BUFFERS)
    		SPIFIFO.write16(((addr << 1) & 0x6000) | 0x1400 | *buf++, // 4K buffers
    		#else
    		SPIFIFO.write16(((addr << 2) & 0xE000) | 0x1400 | *buf++, // 2K buffers
    		// receive buffers
    		SPIFIFO.write16(((addr << 1) & 0x2000) | 0x1C00 | *buf++, // 16K buffers
    		SPIFIFO.write16(((addr << 0) & 0x4000) | 0x1C00 | *buf++, // 8K buffers
    		SPIFIFO.write16(((addr << 1) & 0x6000) | 0x1C00 | *buf++, // 4K buffers
    		#else
    		SPIFIFO.write16(((addr << 2) & 0xE000) | 0x1C00 | *buf++, // 2K buffers
    	len--;
    	while (len >= 2) {
    		len -= 2;
    		SPIFIFO.write16((*buf << 8) | *(buf+1), (len == 0) ? 0 : SPI_CONTINUE);
    		buf += 2;
    		SPIFIFO.read();
    	if (len) {
    		SPIFIFO.write(*buf);
    		SPIFIFO.read();
    	SPIFIFO.read();
    	SPIFIFO.read();
      return len;
    #else
      if (chip == 51) {
        for (uint16_t i=0; i<len; i++) {
          setSS();
          SPI.transfer(0xF0);
          SPI.transfer(addr >> 8);
          SPI.transfer(addr & 0xFF);
          addr++;
          SPI.transfer(buf[i]);
          resetSS();
        setSS();
        SPI.transfer(((len >> 8) & 0x7F) | 0x80);
        SPI.transfer(len & 0xFF);
        resetSS();
        setSS();
        if (addr < 0x100) {
          SPI.transfer(0);
          SPI.transfer(0x04);
          SPI.transfer(0);
          SPI.transfer(((addr >> 3) & 0xE0) | 0x0C);
          //  10## #nnn nnnn nnnn
    	  #ifdef W5500_8K_BUFFERS
          SPI.transfer(((addr >> 8) & 0x40) | 0x14); // 8K buffers
          #elif defined W5500_4K_BUFFERS
          SPI.transfer(((addr >> 7) & 0x60) | 0x14); // 4K buffers
          #else
          SPI.transfer(((addr >> 6) & 0xE0) | 0x14); // 2K buffers
          // receive buffers
          SPI.transfer(((addr >> 8) & 0x40) | 0x1C); // 8K buffers
          SPI.transfer(((addr >> 7) & 0x60) | 0x1C); // 4K buffers
          #else
          SPI.transfer(((addr >> 6) & 0xE0) | 0x1C); // 2K buffers
        resetSS();
      return len;
    #ifdef USE_SPIFIFO
    uint16_t W5100Class::read(uint16_t addr, uint8_t *buf, uint16_t len)
      uint32_t i;
      if (chip == 51) {
    	#if 1
    	SPIFIFO.write(0x0F, SPI_CONTINUE);
    	addr++;
    	SPIFIFO.read();
    	SPIFIFO.write(0);
    	SPIFIFO.read();
    	buf[i] = SPIFIFO.read();
    	#if 0
    	// this does not work, but why?
    	SPIFIFO.write16(0x0F00 | (addr >> 8), SPI_CONTINUE);
    	SPIFIFO.write16(addr << 8);
    	addr++;
    	SPIFIFO.read();
    	// len = 1:  write header, write 1 byte, read
    	// len = 2:  write header, write 2 byte, read
    	// len = 3,5,7
    	SPIFIFO.clear();
    	SPIFIFO.write16(len & 0x7FFF, SPI_CONTINUE);
    	SPIFIFO.read();
    	if (len == 1) {
    		// read only 1 byte
    		SPIFIFO.write(0);
    		SPIFIFO.read();
    		*buf = SPIFIFO.read();
    	} else if (len == 2) {
    		// read only 2 bytes
    		SPIFIFO.write16(0);
    		SPIFIFO.read();
    		uint32_t val = SPIFIFO.read();
    		*buf++ = val >> 8;
    		*buf = val;
    	} else if ((len & 1)) {
    		// read 3 or more, odd length
      		//Serial.print("W5200 read, len=");
    		//Serial.println(len);
    		uint32_t count = len / 2;
    		SPIFIFO.write16(0, SPI_CONTINUE);
    		SPIFIFO.read();
    		do {
    			if (count > 1) SPIFIFO.write16(0, SPI_CONTINUE);
    			else SPIFIFO.write(0);
    			//TODO: WebClient_speedtest with READSIZE 7 is
    			//dramatically faster with this Serial.print(),
    			//and the 2 above, but not without both.  Why?!
    			//Serial.println(val, HEX);
    			*buf++ = val >> 8;
    			*buf++ = val;
    		} while (--count > 0);
    		//Serial.println(*buf, HEX);
    		// read 4 or more, even length
    		uint32_t count = len / 2 - 1;
    		SPIFIFO.read();
    		do {
    			SPIFIFO.write16(0, (count > 1) ? SPI_CONTINUE : 0);
    			*buf++ = val >> 8;
    			*buf++ = val;
    		*buf++ = val >> 8;
    		*buf++ = val;
    	//SPIFIFO.clear();
    	if (addr < 0x100) {
    		SPIFIFO.write16(0,
    		SPIFIFO.write16(((addr << 5) & 0xE000) | 0x0800,
    		SPIFIFO.write16(((addr << 1) & 0x2000) | 0x1000, // 16K buffers
    		SPIFIFO.write16(((addr << 1) & 0x4000) | 0x1000, // 8K buffers
    		SPIFIFO.write16(((addr << 1) & 0x6000) | 0x1000, // 4K buffers
    #else
    		SPIFIFO.write16(((addr << 2) & 0xE000) | 0x1000, // 2K buffers
    	else {
    		// receive buffers
    		SPIFIFO.write16(((addr << 1) & 0x2000) | 0x1800, // 16K buffers
    		SPIFIFO.write16(((addr << 1) & 0x4000) | 0x1800, // 8K buffers
    		SPIFIFO.write16(((addr << 1) & 0x6000) | 0x1800, // 4K buffers
    #else
    		SPIFIFO.write16(((addr << 2) & 0xE000) | 0x1800, // 2K buffers
    	SPIFIFO.read();
    	if (len <= 1) {
    		*buf++ = SPIFIFO.read();
    		SPIFIFO.write(0);
    	} else if (len & 1) {
    		uint32_t count = len >> 1;
    		while (count > 1) {
    			count--;
    			*buf++ = val >> 8;
    			*buf++ = val;
    		*buf++ = val >> 8;
    		*buf++ = val;
    		while (count > 1) {
    			count--;
    			if (count > 1) {
    				SPIFIFO.write(0, 0);
    			*buf++ = val >> 8;
    			*buf++ = val;
      return len;
    #else
      if (chip == 51) {
          setSS();
          SPI.transfer(0x0F);
          addr++;
          buf[i] = SPI.transfer(0);
          resetSS();
        setSS();
        SPI.transfer((len >> 8) & 0x7F);
        resetSS();
        setSS();
        if (addr < 0x100) {
          SPI.transfer(0);
          SPI.transfer(0x00);
          SPI.transfer(0);
          SPI.transfer(((addr >> 3) & 0xE0) | 0x08);
          SPI.transfer(((addr >> 8) & 0x40) | 0x10); // 8K buffers
          SPI.transfer(((addr >> 7) & 0x60) | 0x10); // 4K buffers
          #else
          SPI.transfer(((addr >> 6) & 0xE0) | 0x10); // 2K buffers
          // receive buffers
          SPI.transfer(((addr >> 8) & 0x40) | 0x18); // 8K buffers
          SPI.transfer(((addr >> 7) & 0x60) | 0x18); // 4K buffers
          #else
          SPI.transfer(((addr >> 6) & 0xE0) | 0x18); // 2K buffers
        resetSS();
      return len;
    void W5100Class::execCmdSn(SOCKET s, SockCMD _cmd) {
      // Send command to socket
      writeSnCR(s, _cmd);
      // Wait for command to complete
      while (readSnCR(s))
    Senior Member crees's Avatar
    Dec 2016
    Utah
    214
    I recall that there is minimum socket requirement for tcp. If you have a reference to this can you post the link and I can take a look.
    Jan 2019
    7
    Quote Originally Posted by crees View Post
    I read it here: https://stackoverflow.com/questions/...t-and-one-conn
    I've tested now that if I only create the server and don't use UDP, sometimes the connection stabilishes and sometimes not. But while listening to UDP I really can't get the server to work.
    Jan 2019
    7
    Is it possible to create a http webserver using udp ?
    Jan 2019
    7
    I was able to create a webserver with 8k buffers and 2 sockets, but only for the first try. From the second attempt of connection the teensy stops and crash; In addition, UDP signal reception had to be disabled. My ideia is to let UDP on, receiving packets, and one socket to identify the client. Once the client was identified, UDP stops for a moment and we use both sockets to send the webpage and then restarts the UDP.
    Oct 2018
    15
    I'm following this thread too.
    What for me would be a nice parameter to configure via a very simple webinterface:
    LEDS.setBrightness(50); //value should be 0-255 Very Bright after 100 default is 50 to save on current and eyes!
    Unfortunately, I'm not good at programming, so might not be able to help, only to test.
    Kind regards,
    Geert
