Hi, I did run into a bug after enabling hardware flow control on serial 3. The problem is that the high watermark test is implemented incorrectly in the interrupt handler:
There shouldn't be any test code required to reproduce, the issue is obvious.
Thanks,
Marius
void uart2_status_isr(void)
if (rts_pin) {
int avail;
<< tail = tx_buffer_tail; <- wrong
>> tail = rx_buffer_tail; <- correct
Thanks,
Marius
