Hi, I did run into a bug after enabling hardware flow control on serial 3. The problem is that the high watermark test is implemented incorrectly in the interrupt handler:
void uart2_status_isr(void)
                    if (rts_pin) {
			int avail;
			<< tail = tx_buffer_tail; <- wrong
                        >> tail = rx_buffer_tail; <- correct
There shouldn't be any test code required to reproduce, the issue is obvious.
Thanks,
Marius
