PaulStoffregen
Not quite sure what you mean by "TEENSY_OPT_SMALLEST_CODE". That's not a name used anywhere in the code I've published. Maybe it's something specific to PlatformIO which I do not know?
I'll add this to my list of issues to investigate.
When you say "this code snipped", you mean the code on msg #3, right? Or should I look at some other code when I investigate this problem?
Yes, I can confirm that this code snipped DOES NOT work with the Arduino IDE using Faster optimization & Serial + Midi setting.
