Teensy 3.2 won't send MIDI over USB
heyjudemw
Hi all,
I received a Teensy 3.2 today. It's my first Teensy but I am familiar with Arduino. I ran a few blink sketches to become acquainted with the Teensy and they worked just as expected. I then tried a few MIDI over USB sketches and my computer doesn't seem to be receiving MIDI from the Teensy.
I'm using Mainstage to receive MIDI.
I'm using Arduino IDE.
Board: "Teensy 3.2"
USB type: "MIDI"
Port: "...(Teensy 3.2) MIDI"
"Teensy MIDI" does appear in the MIDI studio and is active
Other MIDI controllers do work through both of my computer ports with both cables that I have tried
Among other codes that I've tried to no avail is this one from PJRC MIDI library page:
#include <MIDI.h>
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
const int channel = 1;
  MIDI.begin();
  int note;
  for (note=10; note <= 127; note++) {
    MIDI.sendNoteOn(note, 100, channel);
    delay(200);
    MIDI.sendNoteOff(note, 100, channel);
  delay(2000);
Does anyone have any idea?
Thanks!
Now I'm just complicating things. The code I posted above is not the code I meant to refer to. The above code is not USB over MIDI. The one I'm trying to work with is this one:
/* Simple Teensy DIY USB-MIDI controller.
  Created by Liam Lacey, based on the Teensy USB-MIDI Buttons example code.
   Contains 8 push buttons for sending MIDI messages,
   and a toggle switch for setting whether the buttons
   send note messages or CC messages.
   The toggle switch is connected to input pin 0,
   and the push buttons are connected to input pins 1 - 8.
   You must select MIDI from the "Tools > USB Type" menu for this code to compile.
   To change the name of the USB-MIDI device, edit the STR_PRODUCT define
   in the /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/usb_midi/usb_private.h
   file. You may need to clear your computers cache of MIDI devices for the name change to be applied.
   See https://www.pjrc.com/teensy/td_midi.html for the Teensy MIDI library documentation.
#include <Bounce.h>
//The number of push buttons
const int NUM_OF_BUTTONS = 8;
// the MIDI channel number to send messages
const int MIDI_CHAN = 1;
// Create Bounce objects for each button and switch. The Bounce object
// automatically deals with contact chatter or "bounce", and
// it makes detecting changes very simple.
// 5 = 5 ms debounce time which is appropriate for good quality mechanical push buttons.
// If a button is too "sensitive" to rapid touch, you can increase this time.
//button debounce time
const int DEBOUNCE_TIME = 5;
Bounce buttons[NUM_OF_BUTTONS + 1] =
  Bounce (0, DEBOUNCE_TIME),
  Bounce (1, DEBOUNCE_TIME),
  Bounce (2, DEBOUNCE_TIME),
  Bounce (3, DEBOUNCE_TIME),
  Bounce (4, DEBOUNCE_TIME),
  Bounce (5, DEBOUNCE_TIME),
  Bounce (6, DEBOUNCE_TIME),
  Bounce (7, DEBOUNCE_TIME),
  Bounce (8, DEBOUNCE_TIME)
const int MIDI_MODE_NOTES = 0;
const int MIDI_MODE_CCS = 1;
//Variable that stores the current MIDI mode of the device (what type of messages the push buttons send).
int midiMode = MIDI_MODE_NOTES;
//Arrays the store the exact note and CC messages each push button will send.
const int MIDI_NOTE_NUMS[NUM_OF_BUTTONS] = {40, 41, 42, 43, 36, 37, 38, 39};
const int MIDI_NOTE_VELS[NUM_OF_BUTTONS] = {110, 110, 110, 110, 110, 110, 110, 110};
const int MIDI_CC_NUMS[NUM_OF_BUTTONS] = {24, 25, 26, 27, 20, 21, 22, 23};
const int MIDI_CC_VALS[NUM_OF_BUTTONS] = {127, 127, 127, 127, 127, 127, 127, 127};
//The setup function. Called once when the Teensy is turned on or restarted
  // Configure the pins for input mode with pullup resistors.
  // The buttons/switch connect from each pin to ground.  When
  // the button is pressed/on, the pin reads LOW because the button
  // shorts it to ground.  When released/off, the pin reads HIGH
  // because the pullup resistor connects to +5 volts inside
  // the chip.  LOW for "on", and HIGH for "off" may seem
  // backwards, but using the on-chip pullup resistors is very
  // convenient.  The scheme is called "active low", and it's
  // very commonly used in electronics... so much that the chip
  // has built-in pullup resistors!
  for (int i = 0; i < NUM_OF_BUTTONS + 1; i++)
    pinMode (i, INPUT_PULLUP);
//The loop function. Called over-and-over once the setup function has been called.
  // Update all the buttons/switch. There should not be any long
  // delays in loop(), so this runs repetitively at a rate
  // faster than the buttons could be pressed and released.
    buttons[i].update();
  // Check the status of each push button
  for (int i = 0; i < NUM_OF_BUTTONS; i++)
    // Check each button for "falling" edge.
    // Falling = high (not pressed - voltage from pullup resistor) to low (pressed - button connects pin to ground)
    if (buttons[i + 1].fallingEdge())
      //If in note mode send a MIDI note-on message.
      //Else send a CC message.
      if (midiMode == MIDI_MODE_NOTES)
        usbMIDI.sendNoteOn (MIDI_NOTE_NUMS[i], MIDI_NOTE_VELS[i], MIDI_CHAN);
        usbMIDI.sendControlChange (MIDI_CC_NUMS[i], MIDI_CC_VALS[i], MIDI_CHAN);
    // Check each button for "rising" edge
    // Rising = low (pressed - button connects pin to ground) to high (not pressed - voltage from pullup resistor)
    else if (buttons[i + 1].risingEdge())
      //If in note mode send a MIDI note-off message.
      //Else send a CC message with a value of 0.
        usbMIDI.sendNoteOff (MIDI_NOTE_NUMS[i], 0, MIDI_CHAN);
        usbMIDI.sendControlChange (MIDI_CC_NUMS[i], 0, MIDI_CHAN);
  } //for (int i = 0; i < NUM_OF_BUTTONS; i++)
  // Check the status of the toggle switch, and set the MIDI mode based on this.
  if (buttons[0].fallingEdge())
  else if (buttons[0].risingEdge())
    midiMode = MIDI_MODE_CCS;
  // MIDI Controllers should discard incoming MIDI messages.
  // http://forum.pjrc.com/threads/24179-Teensy-3-Ableton-Analog-CC-causes-midi-crash
  while (usbMIDI.read())
    // ignoring incoming messages, so don't do anything here.
Sorry for the confusion.
Ok, I tried again with one of the Teensy button examples. I got 1 of the 12 buttons to send MIDI. but only for a few seconds, then it stopped sending altogether again.
The code that almost worked for a second was:
/* Buttons to USB MIDI Example
   To view the raw MIDI data on Linux: aseqdump -p "Teensy MIDI"
#include <Bounce.h>
// Create Bounce objects for each button.  The Bounce object
Bounce button0 = Bounce(0, 5);
Bounce button1 = Bounce(1, 5);  // 5 = 5 ms debounce time
Bounce button2 = Bounce(2, 5);  // which is appropriate for good
Bounce button3 = Bounce(3, 5);  // quality mechanical pushbuttons
Bounce button4 = Bounce(4, 5);
Bounce button5 = Bounce(5, 5);  // if a button is too "sensitive"
Bounce button6 = Bounce(6, 5);  // to rapid touch, you can
Bounce button7 = Bounce(7, 5);  // increase this time.
Bounce button8 = Bounce(8, 5);
Bounce button9 = Bounce(9, 5);
Bounce button10 = Bounce(10, 5);
Bounce button11 = Bounce(11, 5);
  // The pushbuttons connect from each pin to ground.  When
  // the button is pressed, the pin reads LOW because the button
  // shorts it to ground.  When released, the pin reads HIGH
  pinMode(0, INPUT_PULLUP);
  pinMode(1, INPUT_PULLUP);
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  pinMode(6, INPUT_PULLUP);  // Teensy++ 2.0 LED, may need 1k resistor pullup
  pinMode(7, INPUT_PULLUP);
  pinMode(8, INPUT_PULLUP);
  pinMode(9, INPUT_PULLUP);
  pinMode(10, INPUT_PULLUP);
  pinMode(11, INPUT_PULLUP); // Teensy 2.0 LED, may need 1k resistor pullup
  // Update all the buttons.  There should not be any long
  button0.update();
  button1.update();
  button2.update();
  button3.update();
  button4.update();
  button5.update();
  button6.update();
  button7.update();
  button8.update();
  button9.update();
  button10.update();
  button11.update();
  // Send a MIDI Note On message when each button presses
  // Update the Joystick buttons only upon changes.
  // falling = high (not pressed - voltage from pullup resistor)
  //           to low (pressed - button connects pin to ground)
  if (button0.fallingEdge()) {
    usbMIDI.sendNoteOn(60, 99, channel);  // 60 = C4
  if (button1.fallingEdge()) {
    usbMIDI.sendNoteOn(61, 99, channel);  // 61 = C#4
  if (button2.fallingEdge()) {
    usbMIDI.sendNoteOn(62, 99, channel);  // 62 = D4
  if (button3.fallingEdge()) {
    usbMIDI.sendNoteOn(63, 99, channel);  // 63 = D#4
  if (button4.fallingEdge()) {
    usbMIDI.sendNoteOn(64, 99, channel);  // 64 = E4
  if (button5.fallingEdge()) {
    usbMIDI.sendNoteOn(65, 99, channel);  // 65 = F4
  if (button6.fallingEdge()) {
    usbMIDI.sendNoteOn(66, 99, channel);  // 66 = F#4
  if (button7.fallingEdge()) {
    usbMIDI.sendNoteOn(67, 99, channel);  // 67 = G4
  if (button8.fallingEdge()) {
    usbMIDI.sendNoteOn(68, 99, channel);  // 68 = G#4
  if (button9.fallingEdge()) {
    usbMIDI.sendNoteOn(69, 99, channel);  // 69 = A5
  if (button10.fallingEdge()) {
    usbMIDI.sendNoteOn(70, 99, channel);  // 70 = A#5
  if (button11.fallingEdge()) {
    usbMIDI.sendNoteOn(71, 99, channel);  // 71 = B5
  // Send a MIDI Note Off message when each button releases
  // For many types of projects, you only care when the button
  // is pressed and the release isn't needed.
  // rising = low (pressed - button connects pin to ground)
  //          to high (not pressed - voltage from pullup resistor)
  if (button0.risingEdge()) {
    usbMIDI.sendNoteOff(60, 0, channel);  // 60 = C4
  if (button1.risingEdge()) {
    usbMIDI.sendNoteOff(61, 0, channel);  // 61 = C#4
  if (button2.risingEdge()) {
    usbMIDI.sendNoteOff(62, 0, channel);  // 62 = D4
  if (button3.risingEdge()) {
    usbMIDI.sendNoteOff(63, 0, channel);  // 63 = D#4
  if (button4.risingEdge()) {
    usbMIDI.sendNoteOff(64, 0, channel);  // 64 = E4
  if (button5.risingEdge()) {
    usbMIDI.sendNoteOff(65, 0, channel);  // 65 = F4
  if (button6.risingEdge()) {
    usbMIDI.sendNoteOff(66, 0, channel);  // 66 = F#4
  if (button7.risingEdge()) {
    usbMIDI.sendNoteOff(67, 0, channel);  // 67 = G4
  if (button8.risingEdge()) {
    usbMIDI.sendNoteOff(68, 0, channel);  // 68 = G#4
  if (button9.risingEdge()) {
    usbMIDI.sendNoteOff(69, 0, channel);  // 69 = A5
  if (button10.risingEdge()) {
    usbMIDI.sendNoteOff(70, 0, channel);  // 70 = A#5
  if (button11.risingEdge()) {
    usbMIDI.sendNoteOff(71, 0, channel);  // 71 = B5
  while (usbMIDI.read()) {
    // ignore incoming messages
The Teensy is now sending random bursts of MIDI data so I'm thinking it's sending MIDI fine but maybe my button wiring is fundamentally wrong somehow.
