Results 1 to 7 of 7
Thread: Receiving double digit numbers from Pure Data to Arduino over OSC
    Sep 2018
    9
    Hi, I'm trying to trying to control an led matrix from pure data over osc. I'm able to control 10 leds (ie.'/led/1' - '/led/9'. However I'm not able to receive osc messages with double digit numbers.
    I believe the problem has to do with the following lines of code which I did not write and as a result don't fully understand. Could someone give me a better understanding of what's going on here so I might be able to adjust the code?
    char whatLED[] = {'/','1',0};
          for(int i=0; i<16;i++){
            whatLED[1] = char (i | 0x30);
    #include "Tlc5940.h"
    #include <OSCBoards.h>
    #include <OSCMessage.h>
    #ifdef BOARD_HAS_USB_SERIAL
    #include <SLIPEncodedUSBSerial.h>
    SLIPEncodedUSBSerial SLIPSerial( thisBoardsSerialUSB );
    #else
    #include <SLIPEncodedSerial.h>
     SLIPEncodedSerial SLIPSerial(Serial1);
    byte outPins[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};    //for tlc pins
    int brightness;
    int i;
        SLIPSerial.begin(9600);   // set this as high as you can reliably run on your platform
        Tlc.init();
    void routeSystem(OSCMessage &msg, int matched ){
            if(msg.match(whatLED,matched)){
                if(msg.getInt(0));
                int brightness = msg.getInt(0);
                Tlc.set(outPins[i],brightness);    // addressing tlcs
                Tlc.update();
    //reads and routes the incoming messages
    void loop(){
        OSCMessage messageIN;
        int size;
        while(!SLIPSerial.endofPacket())
            if ((size =SLIPSerial.available()) > 0)
               while(size--)
                  messageIN.fill(SLIPSerial.read());
        if(!messageIN.hasError())
            messageIN.route("/led", routeSystem);
    Feb 2017
    288
    If you do a logical OR (or an addition) of the numbers 0...9 with 0x30, you'll get 0x30, 0x31, .... 0x39. These happen to be the ASCII codes for the characters '0', '1', ....'9'.
    So, the code is building a set of null-terminated c-strings: "/0", "/1", .... "/9".
    It doesn't work when you go beyond 9 because 10 (decimal) + 0x30 = 0x3A which is the ASCII code for the character ":".
    Sep 2018
    9
    Thanks for the response! I understand what you're saying about the character codes, though I feel I'm a bit at a loss about how to proceed.
    Is there a simple way around this? Or is it simply not possible given the format of osc?
    I was able to double up the code as seen below, but this approach is messy and time consuming for number of leds that im working with.
    #else
    //byte outPins[] = {9,10};      //for analogwrite pins standard leds w/o tlc
    byte outPins1[] = {0,1,2,3,4,5,6,7,8,9};    //for tlc pins
    byte outPins2[] = {10,11,12,13,14,15};    //for tlc pins
    int brightness;
    int i;
        Tlc.init();
    void led1(OSCMessage &msg, int matched ){
                if(msg.getInt(0));
                //analogWrite(outPins[i],brightness);  // addressing standard leds w/o tlc
                Tlc.set(outPins1[i],brightness);    // addressing tlcs
                //Tlc.setAll(4000);                  //address all tlcs with set value of 4000
                Tlc.update();
    void led2(OSCMessage &msg, int matched ){
                if(msg.getInt(0));
                Tlc.set(outPins2[i],brightness);    // addressing tlcs
                Tlc.update();
    void loop(){
        int size;
               while(size--)
            messageIN.route("/led", led1);
            messageIN.route("/led2", led2);
    Feb 2017
    288
    Quote Originally Posted by TrueBlue View Post
    I don't know what "osc" is, what it does, or what it's format is.
    Sep 2018
    9
    Open Sound Control. The format that the messages from Pure Data are being sent and received in.
    Feb 2017
    288
    Sorry, don't know anything about it.
    Jan 2017
    Maastricht
    165
    I came up with this function for extracting an index from an OSC path:
    int getAddresPartAsIndex(char* addres, int position){
      int number=0;   // function will return -1 if the position doesn't exist or doesn't contain an integer
      char* addresRest=addres;
      char* path=strtok_r(addresRest,"/",&addresRest);
      for (int i=1;i<position;i++){
      number=atoi(path);
      return number-1;
    It's essentially a tokenise '/' function to get a specific part in the OSC address
    I use it to get the track or other number from the path like this:
        char adresStr[48];
        msg.getAddress(adresStr);
        int index = getAddresPartAsIndex(adresStr,2);
        if (msg.match("/fxparam/*/name")){
          msg.getString(0,reaper.insertParameter[index].name,NAME_LENGTH);
          if (index==reaper.selectedParameter) addToQueue(4);
          return;
    Beware that the function returns -1 if the requested message part index does not exist or does not contain an integer.
