Results 1 to 3 of 3
Thread: How can I convert a string of "KEY_A" to the Keyboard.h KEY_A define value?
    I'm building a project that accepts commands over RS232 and then sends a keystroke over USB HID using the Teensy 3.2.
    What is the most efficient way to accept any keystroke string and then convert it to the correct value for Keyboard.press() ?
    Thanks for any help!
    Jul 2016
    1
    If you do it that way, you pretty much have to create some sort of lookup table in your program and search it.
    19,250
    Use Keyboard.print(char). It knows how to translate characters to the actual keystoke, based on the keyboard layout you selected in Tools > Keyboard Layout.
    if (Serial.available()) {
      char c = Serial.read();
      Keyboard.print(c);
