still struggling with c++ syntax :)
Gripporillat
Hi everybody!
I'm trying to create a no-arguments-provided-version of a class constructor, this is my code:
//empty Constructor
SkyFlash::SkyFlash(): poti(SkyPoti()), bounce(0, 0) {
//Constructor
SkyFlash::SkyFlash(SkyPoti& Poti, int pin) : poti(Poti), bounce(pin, 10) {
	pinMode(pin, INPUT_PULLUP);
and this is the error message:
Arduino: 1.8.8 (Windows 10), TD: 1.45, Board: "Teensy 3.5, MIDI, 120 MHz, Faster, US English"
...\libraries\SkyController\SkyFlash.cpp: In constructor 'SkyFlash::SkyFlash()':
...\libraries\SkyController\SkyFlash.cpp:7:51: error: invalid initialization of non-const reference of type 'SkyPoti&' from an rvalue of type 'SkyPoti'
Your help will be highly appreciated! :)
Robert
P.S.: You can find the whole project in the .zip file
  • SkyController.zip
Can you post a simple example to cut/paste into the IDE without needing zip download/extract …
Ok. This compiles:
class testclass1 {
  public:
    testclass1 ();
  private:
testclass1::testclass1 () {
class testclass2 {
  public:
    testclass2(testclass1& test);
  private:
    testclass1& _test;
testclass2::testclass2(testclass1& test): _test(test) {
while this unfortunately doesn't compile:
class testclass1 {
  public:
    testclass1 ();
  private:
class testclass2 {
  public:
    testclass2();
  private:
    testclass1& _test;
testclass2::testclass2() {
I have to somehow initialize _test without giving the constructor an argument. I tried:
class testclass1 {
  public:
    testclass1 ();
  private:
class testclass2 {
  public:
    testclass2();
  private:
    testclass1& _test;
testclass2::testclass2() : _test(testclass1()) {
But that doesn't work either.
Was the link ... added after initial posting … on point? The second example seemed relevant.
IIRC - in this environment it was found that doing things [calling code outside your code?] in the constructor is problematic and IIRC was best done in a .begin() in setup() after the machine was ready to run.
To be honest, I don't fully understand the content of your link and I don't exactly get how it relates to my problem.
First I had the equivalent to this code:
class testclass1 {
  public:
    testclass1 ();
  private:
class testclass2 {
  public:
  private:
    testclass1& _test;
and it nicely worked. But now I need a default constructor. It doesn't need to create a working object, I just need it as a dummy to initialize an array of objects. But I don't know how to write this default constructor without changing the rest of the code.
Maybe like this? (does compile)
class testclass1 {
  public:
    testclass1 ();
  private:
testclass1 default_instance_of_testclass1;
class testclass2 {
  public:
    testclass2();
  private:
    testclass1& _test;
testclass2::testclass2() : _test(default_instance_of_testclass1) {
The whole mess can be avoided by not trying to have a member variable that's a reference to a 'testclass1' object. Use a pointer instead. Then you can have a separate member function to set the pointer as desired - regardless of which construct was used to originally create the object:
class testclass1 {
  public:
    testclass1 ();
  private:
class testclass2 {
  public:
    testclass2();
    void setPointer(testclass1& test);
  private:
    testclass1 *_test = nullptr;
testclass2::testclass2(testclass1 &test): _test(&test) {
void testclass2::setPointer(testclass1 &test) {
  _test = &test;
BTW, next time you post example code, PLEASE try to use identifiers that don't all look so similar: testclass1, testclass2, test, _test, etc. Use a little imagination!
