Results 1 to 7 of 7
Thread: Low power uses too much power...
    I was trying to reduce power consumption following the advice given here : https://www.pjrc.com/teensy/low_power.html
    so I implemented this :
    if (LOW_POWER_MODE) {
        Serial.end();
          for (int i=0; i<sizeof unusedPins/sizeof unusedPins[0]; i++) {
            pinMode(unusedPins[i], OUTPUT);
    The problem is that the "low power mode" uses 3mA more that the default mode... Did I miss something ?
    Cheers
    M
    Dec 2016
    Montreal, Canada
    2,919
    try INPUT_DISABLE
    7,579
    That pages links to the AVR Teensy 2 - is that the Teensy in use? The Arm Teensy's are different. On T_3.x and T_LC the pins are in disabled state unless acted on with pinMode - setting to output will actually enable them.
    Good point, I should have mentioned that I was using a Teensy 3.2
    It makes sense then if I was actually enabling the pins...
    What about Serial.end, is it worth it ?
    Any other tip to save juice ?
    Cheers
    Is there a way to read the state of an input (i.e. enabled/disabled ?)
    Dec 2016
    Montreal, Canada
    2,919
    you can check out duff’s snooze library, for very low power states
    yes, its possible to determine if a pin is used as input or output
    7,579
    There is a SNOOZE library that offers various 'sleep' options. Also search for "WFI" - that sleeps CPU between interrupts - it may offer some reduction.
    I'm not sure what USB Serial does with .end()? If this is the code behind it:
    void end() { };
    Unless the CODE does a PinMode() - or an Analogxx() the pins unused will be disabled.
