RogerdeValle
New member
I have been attempting a UDP broadcast using the Teensy Ethernet library (Teensy 3.6 with Wiz8820io). I want to broadcast a UDP packet to a local subnet by using an IP address such as 192.168.0.255, the core of my code looks something like this..
IPAddress broadcastIp(192,168,0,255);
EthernetUDP UDP;
char tmp[30];
UDP.begin(30305);
strcpy(tmp,"Hello from 192.168.0.140");
UDP.beginPacket(broadcastIp,30304);
UDP.write(tmp);
UDP.endPacket();
If I use the broadcastIp address as 192.168.0.3 the target gets the packet across the network, if however I use 192.168.0..255 there is nothing received. In fact using Wireshark I can see that the Teensy never transmits a UDP packet whenever the broadcast address is used (It transmits the fully qualified IP address packet fine). Is this a library issue and does someone have fix or am I missing something very fundamental
Regards, Roger d
EthernetUDP UDP;
char tmp[30];
UDP.begin(30305);
UDP.write(tmp);
UDP.endPacket();
Regards, Roger d
