Results 1 to 3 of 3
Thread: How to use long file names on Teensy/Arduino SD Card Reader
    Feb 2019
    2
    Does anyone know if there is a way to get Arduino SD card readers to work with long files names (bigger than the 8.3 filename format)? I am currently trying read files from a Teensy 3.5 using the standard Arduino SD card library, and the file fails to open whenever I use longer file names.
    Is this an inherent hardware limitation, or is it simply a software limitation?
    If I could implement this, it would greatly simplify my code and would improve the user experience significantly.
    7,579
    That is a software limitation. There are related forum posts - I think most link to work found or linked here which came up first in my search : https://github.com/greiman/SdFat
    Feb 2019
    2
    That is a software limitation. There are related forum posts - I think most link to work found or linked here which came up first in my search : https://github.com/greiman/SdFat/mybkexperience
    Thank you so much for the suggestion.
