Results 1 to 4 of 4
Thread: Prop Shield LC & Audio Playback
    Jan 2019
    12
    Hello Everyone;
    I have had a few round-about ways and some attempts at getting audio to play back through an LC prop shield from the onboard flash with a low-power/snooze function to save battery.
    Below is my very rough staged code in hopes to get any direction or help from anyone moving forward. I am hoping to use this thread to post some progress/updates from my work.
    My hardware: Teensyduino & Prop LC Shield LC & 3xAA batteries (~4.5v? input) the shield is soldered like:
    I can desolder them if need be, but wow is this thing a bit of a powerhouse and small *teensy?* when they are together!
    //#Include libraries for Audio somehow from here: https://www.pjrc.com/teensy/td_libs_Audio.html ??
    //#Include libraries for PropLC memory ??
    //#Include libraries for low power state, example here: https://github.com/duff2013/Snooze ??
    void Setup(){
    //setup as many pins as possible as inputs
    // Would I initiate low power consumption or low power state as shown here: https://github.com/duff2013/Snooze ?
    // If so, I would need to get a wakeup function to get this going
    void Loop(){
    if (pinX == HIGH){
    	//play audioFileX from LC Flash to (Speaker +) / (Speaker -) pins
    else if (pinY == HIGH){
    	//play audioFileY from LC Flash to (Speaker +) / (Speaker -) pins
    // (all other singular pins in similar else-if statements)
    else if (pinA && pin B == HIGH){
    	//play audioFileABC from LC Flash to (Speaker +) / (Speaker -) pins
    Super excited to try and get this working, but as you can probably tell I am struggling. Any help is greatly appreciated!
    2,952
    In general, the problem is the audio library that you normally use to play complex sounds uses instructions not available on the Teensy LC. You would need to move up to the Teensy 3.2 in order to use most of the audio library.
    Here is a post from 2015 talking about this issue:
    Looking further, it looks like Paul wrote this sketch that plays a single .WAV file on the LC, and a newer thread from 2018:
    Jan 2019
    12
    Ah, my apologies. In the original post I should have stated, it is a 3.2 that I am working with, not a teensyduino.
    I will review the wav file example and report back!
    Thanks @MichaelMeissner for your input
    2,952
    Quote Originally Posted by dash4g View Post
    Yeah, I mis-read your article. I saw the LC, and forgot that there are two different Teensy LC's. The Teensy LC processor (which as I said is limited in terms of audio support) and the Teensy LC prop shield (which does not have the motion sensors, but does have the flash memory, amplifier, and voltage translation support). Sorry about that. If you have a 3.2, it is a lot simpler.
