too low values from analogRead II
AdmiralCrunch
hi,
i had a first try ever and got my first PCBs delivered .. while equiping it turns out, that i made a mistake in the blueprint for my slide-pots so I had to be creative.. the holes are too small for the pins of the sliders.. so i put them on and soldered them this way..
also something went wrong with the pin-numbers in the blueprint, so i had to do a litte "hack" on the pcb
.. i know, i know.. but this was my first try, .. i measured everything and now every slide-pot gives me values between ~22 Ohm and ~10K Ohm
the thing is, when I do a simple analogRead on one of them, I only get values between 0 and 14 .. I measured what comes out at the end of my wires and everything looks fine here, too.
what could cause this?
