are there any issues with regards to controlling a servo, even with an audio shield attached?..
I was trying the code found here : https://www.pjrc.com/teensy/td_libs_Servo.html
and the servo doesnt seem to move or anything..
I am planning to use the servo together with the audio shield attached. since i want to control the servo based on the specific FFT bin/point amplitude..
servo teeensy
GND - ------- - GND
SIGNAL/ DATA - -- pin 29
VCC - ------------ -5v external power..
currently having this code for the mean time to test the servo only ...
#include <Servo.h>
#include <SerialFlash.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
AudioInputI2S            i2s1;           //xy=567,347
AudioAnalyzeFFT256       fft256_1;       //xy=777,355
AudioConnection          patchCord1(i2s1, 0, fft256_1, 0);
AudioControlSGTL5000     sgtl5000_1;     //xy=689,499
   myservo.attach(29);
      Serial.println("FFT RESULTS");
      //fft1024_1.windowFunction(AudioWindowHanning1024);
      AudioMemory(12);
int delayValue = 50;
  float n;
  int i;
  for(pos = 10; pos < 170; pos += 1)  // goes from 10 degrees to 170 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
      if (fft256_1.available()) {
    Serial.print("FFT: ");
    for (i=0; i<75; i++) {
      n = fft256_1.read(i);
      if (n >= 0.01) {
        Serial.print(n);
        Serial.print(" ");
        Serial.print("  -  "); // don't print "0.00"
      delay(delayValue); // Delay for a period of time (in milliseconds).
