Results 1 to 25 of 25
Thread: a crude audio compressor
    Member Moo's Avatar
    Oct 2016
    London
    52
    I'd like to share my crude audio compression effect for teensy audio library:
    https://github.com/newdigate/teensy-audio-multipressor
    Its a very basic attempt at a compression effect
    If there is any interest I would be happy to integrate into cloned teensy audio library repo and send pull request.
    There is a directive in the sketch to switch between SGTL5000 and TGAPro sound card by BlackAddr.
    The sketch uses two AudioFilterStateVariable filters on i2s stereo input and applies a compression effect to each of 6 filter outputs before combining outputs of each compressor back to left and right channels.
    The audio queue objects are used to display oscilliscope view. you may need to comment out, until I add some extra compiler directives. I am using ST7735 display (128 x 128) to display the input and output oscilliscope view.
    Please feel free to criticise, review, question, modify, extend, improve...
    Sep 2019
    Sevilla, Spain
    55
    Quote Originally Posted by Moo View Post
    hi Moo, I'm testing the compressor but I'm not sure how is it supposed to work,
    setting the input gain to 0.5 attenuates the signal but as far as I see (and hear) no compression is applied,
    and setting the gain to 1.5 clips the output,
    not using your example, instead I've inserted before the out in a project I'm working on
    btw, interesting to see that this post has no comments at all
    Member Moo's Avatar
    Oct 2016
    London
    52
    Hey Mangu I was just looking at the code and spotted something that looked very wrong... line 62 in effect_compressor.cpp
    I think if you comment that line out it will probably work -- looks like the output sample is being overwritten by the post-gain sample, ignoring the compressor... If it works let me know and I'll update the repo.
    The code is basically a wave shaper which applies a logarithmic shape to the wave -- Its very crude, i was thinking of converting it to use the more efficient waveshaper algorithm,
    Subsequently I was using MarkzP's https://github.com/MarkzP/AudioEffectDynamics which I had converted to a side-chaining compressor, which was making nice progress... but unfortunately, as it is at the moment, it applies a single gain across an entire audio buffer. so the gain is constant per buffer, and when the gain changes, there is a discontinuity in the signal. If the gain change is big between buffers you can hear and see the issue. I've been thinking about modifying this otherwise awesome repo to calculate overall gain on a per-sample basis - but just haven't managed to find the time. I don't think its alot of work.
    Member Moo's Avatar
    Oct 2016
    London
    52
    FYI, I've updated and deleted line 62 of effect_compressor.cpp but I've havent tested it....
    Sep 2019
    Sevilla, Spain
    55
    will test in a moment and let you know, thanks!
    Sep 2019
    Sevilla, Spain
    55
    indeed it sounds more like a wave folder than a compressor,
    here's a test, a beat that increases in volume every bar processed by the compressor:
    https://drive.google.com/file/d/1Xm4...ew?usp=sharing
    and here's the same without compression:
    https://drive.google.com/file/d/1-H8...ew?usp=sharing
    Member Moo's Avatar
    Oct 2016
    London
    52
Name:	Screenshot 2021-04-25 at 12.31.12.jpg
    awesome. thanks looks like the comp.mp3 has much smaller dynamic range - the quiet bits are amplified and the loud beats are quieter.
    Member Moo's Avatar
    Oct 2016
    London
    52
    btw: no, I don't think it is a wave-folder. a wave folder is a subset of wave shapers, but wave shapers aren't necessarily wave-folders. a rectifier is an example of a wave folder... a wave shaper basically maps an input value to an output value, as far as I know, thou I stand to be corrected.
    Sep 2019
    Sevilla, Spain
    55
    you're probably correct, but was commenting about how does it sound, and to me sounds like a folder/distortion
    Member Moo's Avatar
    Oct 2016
    London
    52
    yep theres definitely alot of noise on the comp.mp3 signal compared to the original signal. not sure if thats a result of the effect, input noise, or output noise.
    Sep 2019
    Sevilla, Spain
    55
    it has to be the effect, because both clips are processed by 2 channels of the same gear, but one channel has the compressor and the other not.
    Member Moo's Avatar
    Oct 2016
    London
    52
    ok. thanks for checking it out. appreciate the feedback.
    Jul 2020
    1,110
    That's a distortion effect, not a compression effect. To compress you need to use a linear response whose gain
    varies over time at scales longer than 50ms. (possibly several independent sections for different frequencies).
    But here you have a logarithmic response which will generate large amounts of harmonic distortion and
    intermodulation distortion directly. This generates spurious tones not present in the original signal.
    Member Moo's Avatar
    Oct 2016
    London
    52
    I think I've found the issue with my "compressor" distortion effect -- it was a divide by an int, causing decimation - effectively it was a bit-crusher!
    I've committed a fix for that now, but its a theoretic fix because I haven't tested it, unfortunately.
    3,261
    I do not understand the purpose of this logarithmic transformation (call it wave-shaping or "compression")
    being non-linear it creates a lot of intermodulation products, that cannot be un-done (as noted by MarkT).
    Could you elaborate in the use application?
    248
    You might take a look here for some inspiration, not sure if it's tested but on first glance looks okay: https://github.com/MarkzP/AudioEffectDynamics
    Member Moo's Avatar
    Oct 2016
    London
    52
    Quote Originally Posted by wcalvert View Post
    Yes thats a very nice example of a real compressor with bells and whistles. I absolutely love it, except for the fact that it applies a constant gain to an entire audio buffer (not so good when delta RMS is big between audio buffers - perhaps I am using it incorrectly...)
    It was more of an experiment to find out how it would sound. I was thinking of using this process for side-chain ducking -- using the amplitude of the kick signal to reduce gain on the bass signal - it was quite a while ago, I just updated recently because there was some interest.
    8,599
    The fork by newdigate is patched in a way that it does not work on blocks, but on samples.
    I'd like to see this in the official audio library.
    Member Moo's Avatar
    Oct 2016
    London
    52
    Hi Frank, I've created a PR to add this to the audio library. https://github.com/PaulStoffregen/Audio/pull/398
    Although I have subsequently realised that it really should have updates to the audio-gui and perhaps add #include in Audio.h
    8,599
    No Problem, i can add a additional PR when it is merged.
    It needs a #ifdef to prevent compile-errors on Teensy, LC, too
    I see it has an additional file for log.
    Is that needed? (almost) all other components have two files only, and it would be more clean without it.
    What do you think about nics PR? Do you merge it?
    @nic, what is const static unsigned int sampleBufferSize = 4410;
    Is that simply sample rate / 10? If so, could you calculate it instead?
    It would then adapt to a changed sample rate (audiostream.h).
    8,599
    ...and it is the non-"bitcrusher" version, right?
    Have not looked at the sourcecode so much..
    Member Moo's Avatar
    Oct 2016
    London
    52
    Thanks Frank! Good suggestions...
    I'll close the PR and re-open a new one when Im ready...
    Member Moo's Avatar
    Oct 2016
    London
    52
    That is a separate component I use for side-chaining "compression" / ducking. It's not much of a compressor as it is a wave shaper. It makes a punchier kik when using the kik to suppress the bassline.
  24. #24
    Member Moo's Avatar
    Oct 2016
    London
    52
    the "bitcrusher" as described above is a different repo... https://github.com/newdigate/teensy-audio-multipressor
  25. #25
    Member Moo's Avatar
    Oct 2016
    London
    52
    Opened a new pull request: https://github.com/PaulStoffregen/Audio/pull/399
    Let me know if theres any other improvements I should/could make. Thanks!
    Done.
    This file is not shared between other files, so makes sense to include in the effect cpp
    Yep, exactly - this is the duration in samples of the running RMS window, i.e. 1/10th of a second sliding window to calculate RMS
