Results 26 to 50 of 51
Thread: MIDI SendSysEx on USB host
  1. #26
    20,176
    Ok, I'm looking at the UHS 2.0 code. I see this at line 313:
                                    if( isMidi )
                                            index = ((epDesc->bEndpointAddress & 0x80) == 0x80) ? epDataInIndex : epDataOutIndex;
                                            index = ((epDesc->bEndpointAddress & 0x80) == 0x80) ? epDataInIndexVSP : epDataOutIndexVSP;
    Then I see this at line 222:
            if( !isMidiFound ){ //MIDI Device not found. Try last Bulk transfer device
                    USBTRACE("MIDI not found. Attempts bulk device\r\n");
                    epInfo[epDataInIndex].epAddr      = epInfo[epDataInIndexVSP].epAddr;
                    epInfo[epDataInIndex].maxPktSize  = epInfo[epDataInIndexVSP].maxPktSize;
                    epInfo[epDataOutIndex].epAddr     = epInfo[epDataOutIndexVSP].epAddr;
                    epInfo[epDataOutIndex].maxPktSize = epInfo[epDataOutIndexVSP].maxPktSize;
    I guess I don't really understand why they bother to with epDataInIndexVSP and epDataOutIndexVSP, and 2 more sets of info in their list of endpoints, when they'll just unconditionally use the "VSP" entries when isMidiFound is false. What's the point?
    But what I *really* don't understand is how this code deals with the *many* USB devices that have interfaces with 2 bulk endpoints. What happens if you try to use a hub, a MIDI drumpad, and also a FTDI serial board? What keeps the USBH_MIDI from trying to talk MIDI to the FTDI device? Likewise for USB storage and many other interfaces that use 2 bulk endpoints?
  2. #27
    Feb 2019
    Switzerland
    23
    We're getting close. With your suggested change in midi.cpp, I can receive data from the THR10. A bInterfaceClass of 0xff probably makes sense, because the THR10 also has an USB audio interface that is not class compliant. Yamaha offers a proprietary Steinberg driver for this device.
    I can also send out SysEx messages and the THR10 does understand them (i.e. it does what I want it to
    I think I found another problem, though: My memory gets overwritten when the Teensy receives a certain amount of SysEx data. I suspect a buffer overrun within the library. With the original buffer sizes of MAX_PACKET_SIZE = 64 / RX_QUEUE_SIZE = 80, this happens almost immediately when I turn some knobs on the THR10. With the increased buffer sizes of 512 / 2048, I can't reproduce this behaviour. But Maybe that's something you want to check.
    Is there anything I have to do in order to clear the receive queue regularly or can I safely ignore all incoming messages from the THR10?
    BTW I left ehci.cpp in it's original state (no speed reduction to 12Mbit/s).
  3. #28
    Jul 2018
    38
    I see you found the UHS code. I do not see how it can reject non-MIDI devices. As long as the device has at least 1 bulk in and 1 bulk out the driver will claim the device. Perhaps a better solution is to add a way force claim a non-compliant MIDI device based on VID/PID (and at least 1 bulk in and 1 bulk out). The default is to claim only class compliant MIDI devices.
  4. #29
    20,176
    Quote Originally Posted by Hirnilein0815 View Post
    I'd like to investigate this. Without a real THR10 here for testing, or some other way to reproduce the problem, not sure how I could even begin.
    I don't even have a clear picture what you're really observing when you say "My memory gets overwritten". Even if I had a THR10 here, the only instruction I have so far to reproduce the problem is "turn some knobs on the THR10", but no idea of what you're expecting to see and what you actually seeing. There may indeed be a bug where memory is overwritten. Or any number of other issues could be happening. If I had a THR10, I would also need a clear description of the actual steps and observed behavior.
    EDIT: or with a very clear description of the behavior you're actually observing, and a good idea of what the THR10 is actually sending, I might be able to program another Teensy as a stand-in for the THR10. Or maybe you could try that, if you've got a spare Teensy available?
  5. #30
    20,176
    Quote Originally Posted by gdsports View Post
    I looked briefly at the Linux source code.
    My understanding of their code is vendor ID 0x0499 (Yamaja) causes create_yamaha_midi_quirk() to be called. That functions seems to look for an interface which has the MIDI jack descriptors and 2 bulk endpoints. As nearly as I can tell, it seems to completely ignore bInterfaceClass and also bInterfaceSubClass in the interface descriptor. That kinda make me wonder if there are other Yahama devices out there were they didn't even bother to set bInterfaceSubClass to 3?
    Here's the patch that seems to have added this to the Linux kernel, proposed almost 6 years ago.
    https://git.congatec.com/arm/imx6_ke...2ddf671ea9108c
  6. #31
    Jul 2018
    38
    I just tried a USB composite device with CDC ACM and MSC with the UHS2 USB host MIDI driver. The driver claimed the clearly non-MIDI device. I do not see how it can co-exist with any other USB device with bulk endpoints. Perhaps Uno/UHS users do not use multiple USB devices given the limited RAM and Flash.
    Maintaining code for quirky devices seems like a high maintenance solution.
  7. #32
    20,176
    I've committed an attempt to detect these Yamaha devices, without falsely claiming non-MIDI interfaces.
    https://github.com/PaulStoffregen/US...171deb108574fa
    Here's the new midi.cpp file. I don't have any Yamaha devices to test.
    Attached Files Attached Files
  8. #33
    Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    37
    Hey there.
    I have a Yamaha MX49 keyboard that has both usb audio I/O and 5 midi ports ( cables) in one physical USB cable.
    I saw a post on social media looking for this amp to test and Paul asked me to post the debug info from the MX49.
    Hopefully this helps.
    In any case, I know I want to develop a Teensy - based patch editor as this keyboard uses a third party editor to edit sounds. Sound editing is not done from the device panel, and Yamaha is enabling third party coding. The implementation of this editing "midi port" is available online and may *also* offer clues to how Yamaha may choose to use midi to control the parameters in the amp. Certainly this keyboard contains a multifx engine and full control of it is available via midi cc#s.
    I'd like to know myself how to have the midi host library select/differentiate between these ports.
    From the documentation:
    port 1 = the instrument as you'd normally expect
    port 2 = exclusive to DAW remote control functions on keyboard panel
    port 3 = midi thru ( meaning the 5 pin jacks on the keyboard)
    port 4 = "Not Used"
    port 5 = data communication for "remote editor" ( the third party software, see yamaha documentation online at https://usa.yamaha.com/files/downloa...h_en_pm_a0.pdf )
    All that plus audio I/O just like the amplifier. The keyboard becomes the soundcard in both directions.
    As per Paul's request, this is the debug results from the Midi-InputsFunctions example and the appropriate library modified. I edited out a huge number of clock receive events...
    port change: 10001803
        connect
      begin reset
    port change: 10001005
      port enabled
      end recovery
    new_Device: 12 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 EF 02 01 08 99 04 11 17 20 01 01 02 00 02
        VendorID = 0499, ProductID = 1711, Version = 0120
        Class/Subclass/Protocol = 239 / 2 / 1
        Number of Configurations = 2
    enumeration:
    enumeration:
    Manufacturer: Yamaha Corporation
    enumeration:
    Product: Yamaha MX Series
    enumeration:
    Config data length = 421
    enumeration:
    Configuration Descriptor:
      09 02 A5 01 04 01 00 C0 01
        NumInterfaces = 4
        ConfigurationValue = 1
      08 0B 00 04 01 00 20 00
        Interface Association = 0 through 3
        Class / Subclass / Protocol = 1 / 0 / 0
      09 04 00 00 00 01 01 20 00
        Interface = 0
        Number of endpoints = 0
        Class/Subclass/Protocol = 1 / 1 / 32
      09 24 01 00 02 09 4B 00 00
      08 24 0A 20 01 01 00 00
      08 24 0B 21 01 20 01 00
      11 24 02 01 01 01 00 21 02 03 00 00 00 00 00 00 00
      0C 24 03 02 13 07 00 01 21 00 00 00
      11 24 02 03 13 07 00 21 02 03 00 00 00 00 00 00 00
      0C 24 03 04 01 01 00 03 21 00 00 00
      09 04 01 00 00 01 02 20 00
        Interface = 1
        Class/Subclass/Protocol = 1 / 2 / 32
      09 04 01 01 01 01 02 20 00
        Interface = 1
        Number of endpoints = 1
      10 24 01 01 00 01 01 00 00 00 02 03 00 00 00 00
      06 24 02 01 03 18
      07 05 01 05 20 01 01
        Endpoint = 1 OUT
        Type = Isochronous
        Max Size = 288
        Polling Interval = 1
      08 25 01 00 00 00 00 00
      09 04 02 00 00 01 02 20 00
        Interface = 2
      09 04 02 01 01 01 02 20 00
        Interface = 2
      10 24 01 04 00 01 01 00 00 00 02 03 00 00 00 00
      06 24 02 01 03 18
      07 05 82 25 20 01 01
        Endpoint = 2 IN
        Type = Isochronous
        Max Size = 288
      09 04 03 00 02 01 03 00 00
        Interface = 3
        Number of endpoints = 2
        Class/Subclass/Protocol = 1 / 3 / 0
      07 24 01 00 01 BD 00
      06 24 02 01 01 00
      06 24 02 02 02 00
      06 24 02 01 03 00
      06 24 02 02 04 00
      06 24 02 01 05 00
      06 24 02 02 06 00
      06 24 02 01 07 00
      06 24 02 02 08 00
      06 24 02 01 09 00
      06 24 02 02 0A 00
      09 24 03 01 0B 01 02 01 00
      09 24 03 02 0C 01 01 01 00
      09 24 03 01 0D 01 04 01 00
      09 24 03 02 0E 01 03 01 00
      09 24 03 01 0F 01 06 01 00
      09 24 03 02 10 01 05 01 00
      09 24 03 01 11 01 08 01 00
      09 24 03 02 12 01 07 01 00
      09 24 03 01 13 01 0A 01 00
      09 24 03 02 14 01 09 01 00
      09 05 03 02 20 00 01 00 00
        Endpoint = 3 OUT
        Type = Bulk
        Max Size = 32
      09 25 01 05 01 03 05 07 09
      09 05 84 02 20 00 01 00 00
        Endpoint = 4 IN
        Type = Bulk
        Max Size = 32
      09 25 01 05 0B 0D 0F 11 13
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=1FFF26E0
    USBHub claim_device this=1FFF2AA0
    Descriptor 11 = IAD
    Descriptor 4 = INTERFACE
    MIDIDevice claim this=1FFF2020
    len = 404
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    len = 312
    len = 303
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 5 = ENDPOINT
    Descriptor 37 =  ???
    len = 257
    len = 248
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 37 =  ???
    len = 202
      Interface is MIDI
    type: 36, len: 7
        MIDI Header (ignored)
    type: 36, len: 6
        MIDI IN Jack (ignored)
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 9
        MIDI OUT Jack (ignored)
    type: 36, len: 9
    type: 36, len: 9
    type: 36, len: 9
    type: 36, len: 9
    type: 36, len: 9
    type: 36, len: 9
    type: 36, len: 9
    type: 36, len: 9
    type: 36, len: 9
    type: 5, len: 9
        MIDI Endpoint: 3
          tx_size = 32
    type: 37, len: 9
        MIDI Endpoint Jack Association (ignored)
    type: 5, len: 9
        MIDI Endpoint: 84
          rx_size = 32
    type: 37, len: 9
    new_Pipe
    new_Pipe
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 37 =  ???
    Descriptor 37 =  ???
    MIDIDevice Receive
      MIDI Data: 0F F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 78
    queue another receive packet
    read: F80F
    Clock
    MIDIDevice Receive
    avail = 78
    read: F80F
    Clock
    port change: 1C00100A
        disconnect
    disconnect_Device:
    USBDriver (available_drivers) list: 1FFF26E0 -> 1FFF2AA0
    USBDriver (dev->drivers) list: 1FFF2020
    disconnect driver 1FFF2020
    USBDriver (available_drivers) list: 1FFF2020 -> 1FFF26E0 -> 1FFF2AA0
    delete_Pipe 1FFF2420
      remove QH from async schedule
      Free transfers
        * 536818944 * remove * free
      Free transfers attached to QH
        * 536818816
    * Delete Pipe completed
    delete_Pipe 1FFF2480
      Free transfers
        * 536818880
    delete_Pipe 1FFF3400
      shut down async schedule
      Free transfers
        * 536819008
    removed Device_t from devlist
      disable
  9. #34
    Feb 2019
    Switzerland
    23
    In my code I have a global char[] that holds a filename. The content of this array got corrupted shortly after I connected the THR10 (I found out because file.open() first worked, but later failed with an error message: "Can't open <garbage>"). <garbage> was getting longer with every sysex message the Teensy received, so it's quite obvious that the library is filling up memory that doesn't belong to it. After some more time the Teensy became unresponsive. Again, this only happend with small buffers.
    I don't do anything with the Incoming sysexs, like copying them somwhere or run any code. I simply ignore them.
    Unfortunately, I don't have another Teensy. But I can post the output of my Windows-based MIDI-Monitor, if that helps. The THR10 sends a heartbeat every second or so, plus all the setting changes (i.e. turning knobs).
  10. #35
    20,176
    First, please make a backup copy of this code. Memory corruption bugs can be very elusive. Even small changes can cause the placement of variables in memory to change.
    With that in mind, I'm hoping you can share a copy of this code, or maybe trim away any secret or proprietary details and share just a small program where the memory corruption happens. Even with a program that's known to reproduce the bug, I'm going to have to create a replacement for the THR10 from only the info about the sysex message... so odds of reproducing exactly the same problem are already not good. If I have to guess the code on the Teensy 3.6 side too, I will need to get very lucky to reproduce this problem. Really hoping you can share a program for the Teensy 3.6 which prints that "Can't open <garbage>" result?
  11. #36
    Feb 2019
    Switzerland
    23
    Sure, I use SourceSafe as version control system, so I should be able to reproduce the code. The code also depends on other hardware (buttons, OLED, SD Card). I will try to reproduce the bug with a stripped down version that doesn't depend on extra hardware.
  12. #37
    Feb 2019
    Switzerland
    23
    As I found out, my own code doesn't make any difference. Even with this simple example that doesn't do anything with the incoming data, the Teensy hangs a short time after I connect the THR10:
    #include <USBHost_t36.h>
    USBHost myUsb;
    USBHub hub1(myUsb);
    USBHub hub2(myUsb);
    MIDIDevice myMidi(myUsb);
    char g_sString[] = "This is a string!";
    unsigned int g_nCounter = 0;
    	// Wait for serial port to connect
    	while (!Serial)
    		delay(10);
    	myUsb.begin();
    	Serial.print(g_sString);
    	Serial.print(" ");
    	Serial.println(g_nCounter++);
    This happens only with the small buffers (i.e. USBHost_t36.h in its original state). This is what the THR10 sends about every second:
    0000173A 2 3 F0 Buffer: 9 Bytes System Exclusive
    SYSX: F0 43 7D 60 44 54 41 31 F7
    0000192E 2 3 F0 Buffer: 9 Bytes System Exclusive
    00001B22 2 3 F0 Buffer: 9 Bytes System Exclusive
    00001D16 2 3 F0 Buffer: 9 Bytes System Exclusive
    00001F0B 2 3 F0 Buffer: 9 Bytes System Exclusive
    000020FE 2 3 F0 Buffer: 9 Bytes System Exclusive
    000022F3 2 3 F0 Buffer: 9 Bytes System Exclusive
    000024E6 2 3 F0 Buffer: 9 Bytes System Exclusive
  13. #38
    20,176
    I'm trying to reproduce the problem here, but not having much luck.
    This is the code I have on a Teensy 3.2, trying to emulate the THR10.
    uint8_t sysex[9] = {0xF0,0x43,0x7D,0x60,0x44,0x54,0x41,0x31,0xF7};
      pinMode(13, OUTPUT);
    int count=0;
      digitalWrite(13, HIGH);
      for (int i=0; i < 8; i++) {
        sysex[1] = i;
        sysex[2] = count;
        usbMIDI.sendSysEx(9, sysex, true);
      delay(10);
      digitalWrite(13, LOW);
      delay(990);
      if (++count > 128) count = 0;
    I'm running your program, but it's not crashing or printing garbage for the string.
  14. #39
    20,176
    Could you run your test again, but with "#define USBHOST_PRINT_DEBUG" uncommented in USBHost_t36.h, and then post the debug output? That will give me a much better picture of the USB packets actually sent by the THR10. Maybe with that info, I can change my code to make the Teensy 3.2 more closely mimic the THR10 and reproduce this problem.
  15. #40
    Feb 2019
    Switzerland
    23
    Hi Paul,
    Sure, I can do this when I'm back home.
    I just reviewed the changes you made to the library two days ago. You introduced a new class MIDIDevice_BigBuffer. May I suggest to solve this within the existing MIDIDevice class instead with an new constructor like this:
    public MIDIDevice(USBHost &host, bool bUseBigBuffers)
    or even better, define an enum for different buffer sizes
    enum eBufferSize = { eDefault, eLarge };
    public MIDIDevice(USBHost &host, eBufferSize bufferSize)
    This would make future changes much easier without breaking existing code.
  16. #41
    Feb 2019
    Switzerland
    23
    Just a thought: I think to remember from another forum discussion that the THR10 automatically sends out all its settings when you connect it to a host. That would be 261 bytes for the patch, 18 bytes for the prefix and 2 bytes for the suffix that are sent out at once. Is it possible that the buffers get corrupted if a single SysEx message is larger than the receive buffer or the queue? Maybe you can try to send a much larger byte Array from your Teensy 3.2.
    I have been staring at
    void MIDIDeviceBase::rx_data(const Transfer_t *transfer)
    for some time now and I believe that large transfers won't be handled correctly if the Transfer size is bigger than the queue. Not sure, though.
  17. #42
    20,176
    Possible, maybe. I've never tested with really long sysex data, so this very well may be it.
    Before I do more guessing to program a Teensy 3.2 to reproduce this problem, I'm waiting for you to post that debug info. I've already put the time into programming 1 unsuccessful attempt from a written description. I really want my 2nd attempt to be informed by the actual debug data. Hope you can understand my reluctance to blind guess again before seeing this info?
    I will consider this if you can show more specifically how to implement it, within the way the library is designed.
    USBHost_t36 never uses heap memory, by malloc/free or C++ new/delete or any other way. The buffers should be allocated within the class instances, but I am willing to consider other approaches. The memory usage *must* be visible to Arduino users in the summary the Arduino IDE prints when you compile. A major goal of USBHost_t36 is to avoid large allocation on the stack and any use of the heap, so users get a clear idea of how much memory is used by the driver instances they've chosen.
    Also off the table is any C++ template syntax in the user level API. Template stuff within the private APIs is ok, as long as it isn't exposed to users for use in their Arduino sketches.
    If you can show me how to make this idea work, within those design constraints, then I will consider it.
  18. #43
    Feb 2019
    Switzerland
    23
    I didn't know about these constraints. My idea was indeed to allocate the buffers dynamically.
  19. #44
    Feb 2019
    Switzerland
    23
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
    reset waited 5
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 1FFF6000
    periodictable = 1FFF6000
    connect
    begin reset
    port change: 18001205
    port enabled
    end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    12 01 00 02 FF 00 FF 40 99 04 07 15 00 01 01 02 00 01
    VendorID = 0499, ProductID = 1507, Version = 0100
    Class/Subclass/Protocol = 255 / 0 / 255
    Number of Configurations = 1
    enumeration:
    enumeration:
    enumeration:
    Product: THR10
    enumeration:
    Config data length = 215
    enumeration:
    09 02 D7 00 04 01 00 C0 00
    NumInterfaces = 4
    09 04 00 00 00 FF 01 00 00
    Interface = 0
    Class/Subclass/Protocol = 255 / 1 / 0
    0A 24 01 00 01 34 00 02 01 02
    0C 24 02 01 01 01 00 02 03 00 00 00
    09 24 03 02 01 03 00 01 00
    0C 24 02 03 03 06 00 02 03 00 00 00
    09 24 03 04 01 01 00 03 00
    09 04 01 00 00 FF 02 00 00
    Interface = 1
    Class/Subclass/Protocol = 255 / 2 / 0
    09 04 01 01 01 FF 02 00 00
    Interface = 1
    07 24 01 01 01 01 00
    0B 24 02 01 02 03 18 01 44 AC 00
    07 05 07 05 24 00 01
    Endpoint = 7 OUT
    Type = Isochronous
    Max Size = 36
    07 25 01 01 00 00 00
    09 04 02 00 00 FF 02 00 00
    Interface = 2
    09 04 02 01 01 FF 02 00 00
    Interface = 2
    07 24 01 04 01 01 00
    0B 24 02 01 04 03 18 01 44 AC 00
    07 05 86 05 48 00 01
    Endpoint = 6 IN
    Type = Isochronous
    Max Size = 72
    09 04 03 00 02 FF 03 FF 00
    Interface = 3
    Class/Subclass/Protocol = 255 / 3 / 255
    07 24 01 00 01 24 00
    06 24 02 02 01 00
    09 24 03 02 01 01 01 01 00
    07 05 01 02 00 02 00
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 512
    Polling Interval = 0
    07 05 82 02 00 02 00
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 512
    enumeration:
    USBHub claim_device this=1FFF2020
    USBHub claim_device this=1FFF23E0
    MIDIDevice claim this=1FFF27A0
    len = 206
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 36 = ???
    len = 145
    len = 136
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 37 = ???
    len = 95
    len = 86
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 37 = ???
    len = 45
    Interface is MIDI
    type: 36, len: 7
    type: 36, len: 6
    type: 36, len: 9
    type: 5, len: 7
    MIDI Endpoint: 1
    tx_size = 512
    type: 5, len: 7
    MIDI Endpoint: 82
    rx_size = 512
    new_Pipe
    new_Pipe
    Descriptor 36 = ???
    Descriptor 36 = ???
    Descriptor 36 = ???
    MIDIDevice Receive
    MIDI Data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 2047
    MIDIDevice Receive
    avail = 2047
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 60 44 54 07 41 31 F7 04 F0 43 7D 04 60 44 54 07 41 31 F7 04 F0 43 7D 04 60 44 54 07 41 31 F7 04 F0 43 7D 04 60 44 54 07 41 31 F7 04 F0 43 7D 04 60 44 54 07 41 31 F7 04 F0 43 7D 04 60 44 54 07 41 31 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 2029
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 60 44 54 07 41 31 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 2026
    This is a string! 0
    MIDIDevice Receive
    avail = 2023
    MIDIDevice Receive
    avail = 2020
    This is a string! 1
    MIDIDevice Receive
    avail = 2017
    MIDIDevice Receive
    avail = 2014
    [ Shortened ...]
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 10 41 30 04 01 01 00 06 05 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 148
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 10 41 30 04 01 01 00 06 06 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 144
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 10 41 30 04 01 01 00 06 09 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 140
    This is a string! 19
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 10 41 30 04 01 01 00 06 0C F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 136
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 10 41 30 04 01 01 00 06 10 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 132
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 10 41 30 04 01 01 00 06 15 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 128
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 10 41 30 04 01 01 00 06 1B F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 124
    wait to receive more packets
    This is a string! 20
    This is a string! 21
    This is a string! 22
    This is a string! 23
    This is a string! 24
    This is a string! 25
    This is a string! 26
    This is a string! 27
    This is a string! 28
    This is a string! 29
    This is a string! 30
    This is a string! 31
    This is a string! 32
    This is a string! 33
  20. #45
    Feb 2019
    Switzerland
    23
    Hi Paul
    The Output is huge. I made two tests:
    - With small buffers I didn't get any output for incoming SysEx messages
    - With large buffers I got the above output
    As you can see, after 20 Seconds I get no more debug messages. The avail value is getting smaller with each message.
    I then added the following code to my scetch:
    	while (myMidi.read())
    This leads to the following output:
  21. #46
    Feb 2019
    Switzerland
    23
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 10 41 30 04 01 01 00 06 51 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 136
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 60 44 54 07 41 31 F7 04 F0 43 7D 04 10 41 30 04 01 01 00 06 52 F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 129
    This is a string! 9
    read: 54446004
    MIDIDevice Receive
    avail = 126
    This is a string! 10
    read: F7314107
    read: 7D43F004
    MIDIDevice Receive
    avail = 128
    MIDIDevice Receive
    avail = 128
    MIDIDevice Receive
    MIDI Data: 04 F0 43 7D 04 10 41 30 04 01 01 00 06 44 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 3E F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 38 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 31 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 2C F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 29 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 26 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 25 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 24 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 23 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 22 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 23 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 24 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 27 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 29 F7 00 04 F0 43 7D 04 10 41 30 04 01 01 00 06 2A F7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    avail = 64
    This is a string! 11
    read: 54446004
    This is a string! 12
    read: F7314107
    read: 7D43F004
    This is a string! 13
    read: 54446004
    This is a string! 14
    read: F7314107
    read: 7D43F004
    This is a string! 15
    read: 54446004
    This is a string! 16
    read: F7314107
    read: 7D43F004
    This is a string! 17
    read: 54446004
    This is a string! 18
    read: F7314107
    read: 7D43F004
    read: 30411004
    read: 10104
    read: F72706
    read: 7D43F004
    read: 30411004
    read: 10104
    read: F72806
    read: 7D43F004
    read: 30411004
    read: 10104
    read: F72906
    read: 7D43F004
    read: 30411004
    read: 10104
    read: F72B06
    read: 7D43F004
    read: 30411004
    read: 10104
    read: F72D06
    read: 7D43F004
    This is a string! 34
    read: 30411004
    This is a string! 35
    read: 10104
    This is a string! 36
    read: F73006
    read: 7D43F004
    This is a string! 37
    read: 30411004
    This is a string! 38
    read: 10104
    This is a string! 39
    read: F73306
    read: 7D43F004
    This is a string! 40
    read: 30411004
    This is a string! 41
    read: 10104
    This is a string! 42
    read: F73706
    read: 7D43F004
    This is a string! 43
    read: 30411004
    This is a string! 44
    read: 10104
    This is a string! 45
    read: F73B06
    read: 7D43F004
    This is a string! 46
    read: 30411004
    This is a string! 47
    read: 10104
    This is a string! 48
    read: F73F06
    read: 7D43F004
    This is a string! 49
    read: 30411004
    This is a string! 50
    read: 10104
    This is a string! 51
    read: F74206
    read: 7D43F004
    This is a string! 52
    read: 30411004
    This is a string! 53
    read: 10104
    This is a string! 54
    read: F74506
    read: 7D43F004
    This is a string! 55
    read: 30411004
    This is a string! 56
    read: 10104
    This is a string! 57
    read: F74706
    read: 7D43F004
    MIDIDevice Receive
    avail = 128
    MIDIDevice Receive
    avail = 128
    MIDIDevice Receive
    avail = 125
    This is a string! 58
    read: 30411004
    This is a string! 59
    read: 10104
    This is a string! 60
    read: F74A06
    read: 7D43F004
    MIDIDevice Receive
    avail = 129
    MIDIDevice Receive
    avail = 129
    MIDIDevice Receive
    avail = 126
    MIDIDevice Receive
    avail = 123
    This is a string! 61
    read: 30411004
    This is a string! 62
    read: 10104
    This is a string! 63
    read: F74D06
    read: 7D43F004
    This is a string! 64
    read: 30411004
    MIDIDevice Receive
    avail = 128
    MIDIDevice Receive
    avail = 128
    MIDIDevice Receive
    avail = 125
    This is a string! 65
    read: 10104
  22. #47
    20,176
    Everything appears to be working properly.
    The descriptor info says the endpoint max is 512 bytes, so this can never work with the small buffers. The small buffers class should not try to claim the interface.
    When you saw the memory corrupted string, is there any chance you were running a modified copy of the library? If you deleted the code which checks the max packet size, then the small buffer class would erroneously claim the interface. Large incoming packets would be written to the small buffers, badly corrupting other memory!
    But if you're running the library without edits, this line is supposed to avoid using the small buffers when a larger packet size is used.
            // if an IN endpoint was found, create its pipe
            if (rx_ep && rx_size <= max_packet_size) {
  23. #48
    20,176
    I should also point out, the descriptor info you showed in msg #21 is not the same as the descriptors in msg #44.
    From msg #21:
    07 05 01 02 40 00 00
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
    07 05 82 02 40 00 00
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
    From msg #44:
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 512
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 512
    Why these aren't the same, I can only guess. This is the same THR10 device, right?
    Maybe in msg #21, perhaps you were running a modified copy of USBHost_t36 with the 12 Mbit edit I suggested in msg #13?
    The USB protocol limits bulk endpoints to only 64 bytes when the speed is 12 Mbit. But at 480 Mbit, up to 512 bytes is allowed. Most 480 Mbit devices send 2 different sets of descriptors and of course use different packet sizes, depending on the speed.
    Remember, I don't have a THR10. Everything I know about the THR10's USB is from the info you've posted here. Until just now, I believed THR10 was a 12 Mbit only device, since the msg #21 was the only info so far. Now it seems THR10 really is a 480 Mbit device?
    If you're running code that is different than the last release (in 1.45 and 1.46-beta6) or the latest on github, and you don't mention that fact when posting the debug output.... can you see how that could add a lot of extra uncertainty??
  24. #49
    Feb 2019
    Switzerland
    23
    The only changes I ever made where those you advised me to do:
    1. Reduce Speed to 12MBit/s according to Post#13. This change didn't make any difference, so I rolled it back later.
    2. Increase Buffer size in USBHost_t36.h according to Post#12. This change helped, so I kept it this way
    3. Comment out the bInterfaceClass == 1 condition in midi.cpp according to post#23. This change is essential for the THR10, so I kept it.
    Just to be on the safe sid I downloaded the library from GitHub again today, applied changes 2 and 3, and tested again. I cannot reproduce the crash with small buffers anymore. I still can reproduce the output in post#46. Basically, this is how I read it: I receive all messages until the avail value drops below 128. After that, messages get lost. The question is: How do I empty the queue?
  25. #50
    20,176
    Ok, I'm going to consider the memory corruption issue to be fully resolved.
    To answer your question, the way to empty the queue: just keep calling midi1.read(). The code fragment in msg #45 should do it.
    If that's not working, if you believe you've found another bug, as usual I need to see the full code to reproduce it. I'd like to ask you to please test with the latest code from github, without any changes, and please mention this in any more messages with code and debug data so I know exactly which copy of the library you used.
    Just to be clear, I have taken this thread off my list of known problems. If there is another bug here to be investigated, I will only put this thread back on my issue list when I see full code to reproduce the issue. Otherwise, I'm considering every problem raised so far on this thread to be fully resolved.
