uint8_t Sd2Card::SD_init(uint8_t sckRateID, uint8_t chipSelectPin) {
type_ = 0;
chipSelectPin_ = chipSelectPin;
// 16-bit init start time allows over a minute
unsigned int t0 = millis();
uint32_t arg;
digitalWrite(chipSelectPin_, HIGH);
pinMode(chipSelectPin_, OUTPUT);
#if defined(USE_TEENSY3_SPI)
spiBegin();
spiInit(6);
#elif defined(USE_TEENSY4_SPI)
spiInit(6);
pinMode(SS_PIN, OUTPUT);
digitalWrite(SS_PIN, HIGH); // disable any SPI device using hardware SS pin
[COLOR="#FF0000"]// ----- Teensy LC --- SET SCK PIN
#elif defined(KINETISL) && defined(__MKL26Z64__) // Teensy LC
#pragma message ( "Teensy LC hard-coded SPI CLK pin 14 ---> Sd2Card.cpp !!!!" )
pinMode(SPI_MISO_PIN, INPUT);
pinMode(SPI_MOSI_PIN, OUTPUT);
// CORE_PIN13_CONFIG = PORT_PCR_SRE | PORT_PCR_MUX(1); // disable pin
// CORE_PIN14_CONFIG = PORT_PCR_DSE | PORT_PCR_MUX(2); // enable pin
SPI.setSCK(14); // Set SCK pin 14
pinMode(14, OUTPUT); // SCK pin
settings = SPISettings(250000, MSBFIRST, SPI_MODE0);
SPI.begin();
// ^^^^^ Teensy LC ^^^ SCK pin SET[/COLOR]
#else
// set pin modes
pinMode(SPI_SCK_PIN, OUTPUT);
// SS must be in output mode even it is not chip select
// Enable SPI, Master, clock rate f_osc/128
SPCR = (1 << SPE) | (1 << MSTR) | (1 << SPR1) | (1 << SPR0);
// clear double speed
SPSR &= ~(1 << SPI2X);
#ifdef SPI_HAS_TRANSACTION
#endif // not USE_TEENSY3_SPI
// must supply min of 74 clock cycles with CS high.
SPI.beginTransaction(settings);
for (uint8_t i = 0; i < 10; i++) spiSend(0XFF);
SPI.endTransaction();
chipSelectLow();
// command to go idle in SPI mode
while ((status_ = cardCommand(CMD0, 0)) != R1_IDLE_STATE) {
unsigned int d = millis() - t0;
if (d > SD_INIT_TIMEOUT) {
goto fail; // SD_CARD_ERROR_CMD0
// check SD version
if ((cardCommand(CMD8, 0x1AA) & R1_ILLEGAL_COMMAND)) {
type_ = SD_CARD_TYPE_SD1;
// only need last byte of r7 response
for (uint8_t i = 0; i < 4; i++) status_ = spiRec();
if (status_ != 0XAA) {
goto fail; // SD_CARD_ERROR_CMD8
type_ = SD_CARD_TYPE_SD2;
// initialize card and send host supports SDHC if SD2
arg = (type_ == SD_CARD_TYPE_SD2) ? 0X40000000 : 0;
while ((status_ = cardAcmd(ACMD41, arg)) != R1_READY_STATE) {
// check for timeout
goto fail; // SD_CARD_ERROR_ACMD41
// if SD2 read OCR register to check for SDHC card
if (type_ == SD_CARD_TYPE_SD2) {
if (cardCommand(CMD58, 0)) {
goto fail; // SD_CARD_ERROR_CMD58
if ((spiRec() & 0XC0) == 0XC0) type_ = SD_CARD_TYPE_SDHC;
// discard rest of ocr - contains allowed voltage range
for (uint8_t i = 0; i < 3; i++) spiRec();
chipSelectHigh();
return setSckRate(sckRateID);
fail:
chipSelectHigh();
return false;
