Results 1 to 2 of 2
Thread: Cannot install teensyduino on Ubuntu since unable to find my Arduino /lib/version.txt
    Feb 2019
    2
    I am trying to install the Teesnyduino plugin for the Arduino IDE but I am unable since the installer fails to find the /lib/version.txt file. I am using the Arduino IDE 1.8.8 and the Teensyduino 1.4.5 installer, so it should work.
    I assume that this is because when I installed the Arduino IDE I installed it from ~/Downloads, so I tried running it from /usr/share but the Teensyduino installer is still unable to find the version.txt file. I do not know where the installer is looking for this version.txt file, so I didn't bother trying any other options.
    Any help would be appreciated, and also if this is indeed the problem it would be useful to include this in the download instructions?
    Feb 2019
    2
    So I was being really quite silly. While looking through forum threads, I kept on seeing that people said you need to navigate to the /Arduino folder. On Ubuntu, there's an /Arduino folder on my home, but obviously what I needed to down was point it to ~/Downloads/arduino/lib (or wherever you install it). Then of course there's the weird feature whereby you need to open that folder and click on ../ to be able to click 'Next'. Anyway, problem solved!
