MJAChapman
There are many pads on the underside of the Teensy 3.2 and 3.6. Is the a means of connecting to these pads from a PCB?
There are so called pogo pins which are soldered into the pcb and which, thanks to an integrated spring, will contact the pads when the Teensy is inserted into its socket. Another way is using pin headers and solder them onto the pads after having bent the Teensy-side pins outwards.
