Results 1 to 4 of 4
Thread: Garbage value on serial monitor using teensy 3.2
    Feb 2019
    17
    Hello every one.
    I am new user of teensy and i am using teensy3.2 i want to get float value from serial monitor but when i enter any float value it returns me accurate value but with garbage value like 0.00
    its my code
    float val;
    while(Serial.available()==0){}
     val=Serial.parseFloat();
    Serial.print("You Entered=");
    Serial.println(val);
    when i enter any number my output is like the picture that i have uploaded.
    Please guide me how can i fix this issue.
    9,675
    The problem is the SerMon doesn't send until the NEWLINE is created pressing Enter. Then the NewLine is in the data stream and it was triggering the next time through:
    	while (!Serial && millis() < 4000 );
    float val;
    	Serial.print("Enter a number - float if you please = ");
    	while (Serial.available() == 0) {}
    	val = Serial.parseFloat();
    	if ( 10 == Serial.peek() ) { Serial.read(); Serial.println("Ate the NewLine!"); }
    The parseFloat() uses PEEK to check the next char for the NewLine and leaves it queued:
    int Stream::timedPeek()
      int c;
      unsigned long startMillis = millis();
      do {
        c = peek();
        if (c >= 0) return c;
        yield();
      } while(millis() - startMillis < _timeout);
      return -1;     // -1 indicates timeout
    Feb 2019
    17
    Now it's working . Thank you so much for your kind and quick reply..
    9,675
    Glad to help - it is fun to solve new problems.
