long file names and play audio from SD card
Moo
Has anybody managed to get the audio library to play from SD and read long filenames too?
Im writing a file browser to display and allow users to select files and navigate directory. using 8.3 filenames is something I'd really like to avoid if possible.
my issue is play_sd_audio is coupled to SD library which appears to only support 8.3 file names.
One solution would be write a play_sdfat_audio class using SDFat library - I think this seems like my best chance..
The other option is to see if I can port the long file name functions from SdFat to Sd libraries, im not sure if this is possible, but I think it would be a better solution...
My code is here: https://github.com/newdigate/teensy-tft-sd-browser
Anybody have any insight and/or opinions?
WavFilePlayerUSB
NOTE: This player needs wav file with long name on SD Card: (SDTEST1 test long name.wav)
#define USE_SdFat_ // uncomment for SdFat.h, comment for SD.h lib.
// NOTE: uncomment~comment also in play_sd_raw.cpp & play_sd_wav.cpp
#ifdef USE_SdFat_
#include <SdFat.h>
//SdFatSdioEX SD; // SdFatSdioEX uses extended multi-block transfers without DMA.
SdFatSdio SD; // SdFatSdio uses a traditional DMA SDIO implementation.
// Note the difference is speed and busy yield time.
// Teensy 3.5 & 3.6 SDIO: 4 to 5 times the throughput using the 4-bit SDIO mode compared to the 1-bit SPI mode
#else
File root;
File entry;
AudioPlaySdWav           playWav1;
AudioOutputUSB           audioOutput; // must set Tools > USB Type to Audio
AudioOutputAnalog        dac;
AudioConnection          patchCord1(playWav1, 0, audioOutput, 0);
AudioConnection          patchCord2(playWav1, 1, audioOutput, 1);
AudioConnection          patchCord3(playWav1, 0, dac, 0);
//#define SDCARD_CS_PIN    10
//#define SDCARD_MOSI_PIN  7
//#define SDCARD_SCK_PIN   14
////////// For Sd.h lib. only /////////
#define SDCARD_CS_PIN    BUILTIN_SDCARD
#define SDCARD_MOSI_PIN  11  // not actually used
#define SDCARD_SCK_PIN   13  // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN    4
//#define SDCARD_MOSI_PIN  11
//#define SDCARD_SCK_PIN   13
elapsedMillis since_Update;
int SEC = 0;
  AudioMemory(20);
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
#ifdef USE_SdFat_
  if (!(SD.begin())) { //<///////  SdFat.h  /////////
    Serial.println(" SdFat.h ");
    // stop here, but print a message repetitively
    while (1) {
#else                 //<///////   Sd.h   /////////
    while (1) {
#if defined(SdFat_h)
  Serial.print( "SdFat version "), Serial.println( SD_FAT_VERSION ), Serial.println("");
#elif defined(__SD_H__)
  Serial.println( "SD - a slightly more friendly wrapper for sdfatlib"), Serial.println("");
#ifdef USE_SdFat_
  char filename[255]; //
  root = SD.open("/"); // ROOT
  while (true) {
    File entry = root.openNextFile();
    entry.getName(filename, sizeof(filename));
    if (entry.isDirectory()) {
      Serial.print("Dir.  "), Serial.println(filename);
      Serial.print("      "), Serial.println(filename);
    if (! entry) {
      // no more files
      Serial.println(" **nomorefiles** ");
  entry.close();
  root.close();
  playWav1.play(filename);
  // A brief delay for the library read WAV info
  delay(5);
  // Simply wait for the file to finish playing.
  while (playWav1.isPlaying()) {
    if (since_Update > 999) {
      since_Update = 0;
      Serial.print(" SEC: "), Serial.println(SEC);
      SEC++;
  SEC = 0;
  playFile("SDTEST1 test long name.WAV");  // uppercase or lowercase 255 long max.
  /*playFile("SDTEST2.WAV");
    playFile("SDTEST3.WAV");
    playFile("SDTEST4.WAV");
    delay(1500);*/
// A known problem occurs on Macintosh computers, where the Mac's driver
// does not seem to be able to adapt and transmit horribly distorted
// audio to Teensy after a matter of minutes.  An imperfect workaround
// can be enabled by editing usb_audio.cpp.  Find and uncomment
// "#define MACOSX_ADAPTIVE_LIMIT".  More detailed info is available here:
// https://forum.pjrc.com/threads/34855-Distorted-audio-when-using-USB-input-on-Teensy-3-1?p=110392&viewfull=1#post110392
