#include <Keypad.h>
//#define KEY_NON_US_BS (100 | 0xF000)
//#define KEY_MENU (101 | 0xF000)
//#define KEY_FN 1
const byte LEFT_COLS = 7;
const byte LEFT_ROWS = 6;
const byte RIGHT_COLS = 11;
const byte RIGHT_ROWS = 6;
const int LAYOUT_NBR = 2;
const byte I2C_ADDRESS = 8;
uint16_t layoutsRight[LAYOUT_NBR][RIGHT_COLS*RIGHT_ROWS]{
KEY_ESC, KEY_TILDE, KEY_TAB, KEY_CAPS_LOCK, MODIFIERKEY_SHIFT, MODIFIERKEY_CTRL,
NO_KEY, KEY_1, KEY_Q, KEY_A, KEY_NON_US_BS, MODIFIERKEY_GUI,
KEY_F1, KEY_2, KEY_W, KEY_S, KEY_Z, NO_KEY,
KEY_F2, KEY_3, KEY_E, KEY_D, KEY_X, MODIFIERKEY_ALT,
KEY_F3, KEY_4, NO_KEY, NO_KEY, KEY_C, KEY_SPACE,
KEY_F4, KEY_5, KEY_R, KEY_F, KEY_V, NO_KEY,
NO_KEY, KEY_6, KEY_T, KEY_G, KEY_B, NO_KEY
uint16_t layoutsLeft[LAYOUT_NBR][RIGHT_COLS*RIGHT_ROWS]{
KEY_F5, KEY_7, KEY_Y, KEY_H, KEY_N, KEY_SPACE,
KEY_F6, KEY_8, KEY_U, KEY_J, KEY_M, 1,
KEY_F7, KEY_9, KEY_I, KEY_K, KEY_COMMA, NO_KEY,
KEY_F8, KEY_0, KEY_O, KEY_L, KEY_PERIOD, MODIFIERKEY_RIGHT_ALT,
KEY_F9, KEY_MINUS, KEY_P, KEY_SEMICOLON, KEY_SLASH, MODIFIERKEY_RIGHT_GUI,
KEY_F10, KEY_EQUAL, KEY_LEFT_BRACE, KEY_QUOTE, NO_KEY, NO_KEY,
KEY_F11, KEY_BACKSPACE, KEY_RIGHT_BRACE, KEY_TILDE, MODIFIERKEY_RIGHT_SHIFT, KEY_MENU,
KEY_F12, NO_KEY, KEY_ENTER, NO_KEY, NO_KEY, MODIFIERKEY_RIGHT_CTRL,
KEY_PRINTSCREEN, KEY_INSERT, KEY_DELETE, NO_KEY, NO_KEY, KEY_LEFT,
KEY_SCROLL_LOCK, KEY_HOME, KEY_END, NO_KEY, KEY_UP, KEY_DOWN,
KEY_PAUSE, KEY_PAGE_UP, KEY_PAGE_DOWN, NO_KEY, NO_KEY, KEY_RIGHT
KEY_F5, KEY_7, KEY_Y, KEY_H, KEY_N, 0,
KEY_F6, KEY_8, KEY_U, KEY_J, KEY_M, KEYPAD_0,
KEY_F8, KEY_0, KEY_O, KEY_L, KEY_PERIOD, KEYPAD_PERIOD,
KEY_F9, KEY_MINUS, KEY_P, KEY_SEMICOLON, KEY_SLASH, KEYPAD_ENTER,
char keys[RIGHT_COLS][RIGHT_ROWS] = {
{'A', 'B', 'C', 'D', 'E', 'F'},
{'G', 'H', 'I', 'J', 'K', 'L'},
{'M', 'N', 'O', 'P', 'Q', 'R'},
{'S', 'T', 'U', 'V', 'W', 'X'},
{'Y', 'Z', 'a', 'b', 'c', 'd'},
{'e', 'f', 'g', 'h', 'i', 'j'},
{'k', 'l', 'm', 'n', 'o', 'p'}
byte rowPins[RIGHT_ROWS] = {21, 20, 19, 18, 17, 16};
byte colPins[RIGHT_COLS] = { 9, 22, 11, 13, 14, 15, 12};
Keypad kpd = Keypad( makeKeymap(keys), colPins, rowPins, RIGHT_COLS, RIGHT_ROWS );
unsigned long loopCount;
unsigned long startTime;
String msg;
byte currentLayout;
Wire.begin(I2C_ADDRESS);
Wire.onReceive(receiveKey);
loopCount = 0;
startTime = millis();
msg = "";
currentLayout = 0;
loopCount++;
if ( (millis()-startTime)>5000 ) {
Serial.print("Average loops per second = ");
Serial.println(loopCount/5);
loopCount = 0;
// Fills kpd.key[ ] array with up-to 10 active keys.
// Returns true if there are ANY active keys.
if (kpd.getKeys())
for (int i=0; i<LIST_MAX; i++) // Scan the whole key list.
char keyPressed = kpd.key[i].kchar;
uint16_t keyChar = layoutsRight[currentLayout][kpd.key[i].kcode];
if ( kpd.key[i].stateChanged ) // Only find keys that have changed state.
switch (kpd.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case PRESSED:
Keyboard.press(keyChar);
msg = " PRESSED.";
case HOLD:
msg = " HOLD.";
case RELEASED:
Keyboard.release(keyChar);
msg = " RELEASED.";
case IDLE:
msg = " IDLE.";
Serial.print("Key ");
Serial.print(keyPressed);
Serial.println(msg);
} // End loop
void receiveKey(int howMany) {
int x = Wire.read(); // receive byte as an integer
uint16_t keyChar;
if(x < 128)
keyChar = layoutsLeft[currentLayout][x];
if(keyChar < LAYOUT_NBR){
Serial.print("Switching layout to");
Serial.println(keyChar);
currentLayout = keyChar;
else {
Serial.print(x);
Serial.println(" PRESSED.");
keyChar = layoutsLeft[currentLayout][x - 128];
if(keyChar > LAYOUT_NBR){
Serial.print(x - 128);
Serial.println(" RELEASED.");
