Results 1 to 9 of 9
Thread: Teensy usb powered + External power at same time?
    Jan 2019
    13
    So I've been reading some things on here and I don't quite understand some of it.
    Is it possible to have my teensy powered from a regulated 5V source (VIN), and then I plug on a usb cable to update it?
    Is it possible to do this OK without cutting the trace?
    I've done this with arduino nanos and got away with it, what's the issue with teensy?
    Teensy 3.6
    Dec 2016
    Montreal, Canada
    3,020
    if your external source voltage backfires to your PC port, it may or may not work, however, if the voltage of the external psu is higher you can blow out the PC usb port. Secondly some arduinos switch to the external power instead of USB if the power if both are applied, they have a circuit for that, not sure on the nanos, however, the VIN on teensies is tied to both external and USB, thats why a trace is there to be cut or not.
    you can also use a data-only usb cable as well instead of cutting the trace, this will allow you to reprogram teensy while plugged into the external source without cutting the trace. But realistically, you’d want to remember that later on in future you don’t use wrong usb cables or forget you didnt cut the trace, etc.
    Jan 2019
    13
    And is there a diode between the USB and the VIN?
    Dec 2016
    Montreal, Canada
    3,020
    https://www.pjrc.com/teensy/external_power.html
    option #3 is of interest to you
    Jan 2019
    13
    THanks. Wonder where this is on the 3.6.
    Tomorrow I search or if anything i come back here.
    8,591
    Quote Originally Posted by donperryjm View Post
    On Teensy 3.x and LC the VIN<>VUSB cuttable trace is shown on the card - the same on them - but different than that web link to the Teensy 2.
    2,959
    On all Teensy LC/3.0/3.1/3.2/3.5/3.6's, it is in the same place (and different from the Teensy 2 as defragster notes):
    Jan 2019
    13
    OK. I saw that circuit, and I'm still thinking of an easier way,
    So backfeeding is a concern, OK i hear that.
    Will it still be a problem if i put a diode after my regulator to drop the voltage to 4.3V, would that still backfeed into the usb 5v power?
    Jan 2019
    13
    Simulating this in multisim looks promising. What am i missing here?
