Results 1 to 5 of 5
Thread: waveformMod Pulse Pulse With?
    Mar 2015
    9
    waveformMod_Pulse pulseWidth();?
    Hi!
    I can't modulate the Pulse Width of the Pulse waveform in the new waveformMod.
    edit:
    I noticed now the pulseWidth(); does not exist in the waveformMod object. Any plans to fix this in the future?
    Thanks in advance!
    Feb 2014
    Colmar, France
    2,299
    The waveformMod object is not only about pulse waveforms but also about plenty of others including arbitrary, for which modulating the pulse width would not make sense or would be just technically impossible. Thus, if one would need to modulate the pulse width with this object, one had to do this within a if(waveform == pulse) condition.
    Feel free to fork the audio library on GitHub, to add this function and to contribute a pull request.
    Mar 2015
    9
    I'm aware that the pulse width function does not make sense to any waveform other than pulse. But since pulseWidth(); exists on the waveform object (is ignored if you have a waveform other than pulse selected) i though it would be available on the waveformMod object.
    Unfortunately i'm not skilled enough to mess with the library :/ but i'll try to take a look at it.
    Thanks!
    19,539
    Quote Originally Posted by manatee View Post
    Sure you can. In fact, that's exactly what the "Mod" version of the waveform is meant to do. You apply a signal to its 2nd input and that signal modulates the pulse width.
    It's not broken. If you want to control the pulse width by calling a function from your code, then you would use the regular waveform. The "Mod" version is meant to have that stuff controlled by a signal input.
    If you want to use it with a fixed value with the "Mod" versoin, just connect the "DC" synth to its input. Then you can control the DC value, and it controls the signal input. Easy stuff.
    Mar 2015
    9
    oh, I see! thank you both for your help!
