I am trying to build a simple mixer i.e. it will take 8 or more(max 12) channels of analog audio signals mix them and output to a single DAC channel. I know that for 6 channels I can use a CS42448 board(https://oshpark.com/shared_projects/2Yj6rFaW) as PaulStoffregen has mentioned in this thread https://forum.pjrc.com/threads/54839-Multiple-CS42448?highlight=CS42448 that it is possible to use multiple CS42448 chips for more than 6 input channals now the problem is that I have to design the full mixer board from ground up with 2 of these chips.
Now the question for which I am posting here are.
- How do I connect 2 of these chips to a single Teensy 3.6 (the interconnection between The Teensy and these chips)
- Is there any repository where I can find the CS42448 Multichannel I/O board circuit/schematic diagram for reference use.
