Hi - strange issue w/ the wiz850io and Teeny 3.2...
using arduino 1.6.5.r5 w/ teensyloader 1.41
code using PS's ethernet Lib v 2.0.0 - released jul 28 2018 -
have here 5x wiz850io which i ordered from mouser in may 2018 . - PCB is labeled WIZ850io ver1.0
none of the wiz units power on/show link lights/function, in a circuit where the wiz820io worked fine 100% (teensy 3.2 + newer green teensy ethernet adapter)
test code is using UDPSendRecieveString example from the library - just for the sake of absolving my own code.
TBH i can get the wiz820 to show link lights with the blink sketch loaded as long as the board has power...
the only alteration to example code was to add the standard init/reset pin sequence that paul recommends. this does not seem to help.
i thought wiz850io was a 1:1 replacement as long as one is using the newer ethernet libs. i would have thought the dang things would at least power up and link regardless of what lib is running...
am i missing something here? seems hard to believe all 5 are NFG from mouser.
_JF
_JF
