Results 1 to 5 of 5
Thread: Teensy 3.2/3.6 using arm_neon.h
    Feb 2019
    7
    I've been poking around the libraries and hardware features of the teensy, and found that there's supposedly SIMD support https://forum.pjrc.com/threads/31285...ns-with-Teensy.
    I looked deeper into this, and found that there's a library in the teensy folder called "arm_neon.h". I tried including it in a bare project but I'm getting this error upon compilation:
    #include <arm_math.h>
    #include <arm_neon.h>
    int32x2_t i;
    In file included from C:\Users\user\Documents\Arduino\teensy_math\teensy_math.ino:7:0:
    c:\program files (x86)\arduino\hardware\tools\arm\lib\gcc\arm-none-eabi\5.4.1\include\arm_neon.h:31:2: error: #error You must enable NEON instructions (e.g. -mfloat-abi=softfp -mfpu=neon) to use arm_neon.h
    teensy_math:9: error: 'int32x2_t' does not name a type
     int32x2_t i;
    How do I enable neon? Do I need to edit the build flags? If so, how do I do this?
    Germany NRW
    5,567
    ARM NEON is single instruction - multiple data ("SIMD") for the ARM Cortex-A Series and R52.
    Teensy 3.x is Cortex-M and does not support NEON. But it can do SIMD, with its DSP-Extensions. The audio-library for example uses these instructions.
    Feb 2019
    7
    Ah, I see. My hopes are slightly dashed.
    I was hoping for SIMD instructions that can do vector addition/multiplication like neon. I'll check out the audio library later tonight and see what I find.
    Thanks!
    Germany NRW
    5,567
    Feb 2019
    7
    Thank you so much! Exactly what I was trying to find.
