Results 1 to 6 of 6
Thread: Encoder library help
    I am trying to get a rotary encoder working on a Teensy 3.2 and 3.6 - I have tried my code on both but the same happens.
    I am getting a count of 4 for each detent on a Bournes 24 position rotary encoder.
    My code:
    #define ENCODER_OPTIMIZE_INTERRUPTS
    #include <Encoder.h>
    Encoder encoder0(2, 3);
    long encoderPos = -999;
      Serial.println("Encoder Test:");
      long newEncoderPos;
      newEncoderPos = encoder0.read();
      if (newEncoderPos != encoderPos) {
        Serial.print("Position = ");
        Serial.print(newEncoderPos);
        encoderPos = newEncoderPos;
    The output I see on the serial monitor - 2 clicks right and two clicks left:
    Encoder Test:
    Position = 0
    Position = 1
    Position = 2
    Position = 3
    Position = 4
    Position = 5
    Position = 6
    Position = 7
    Position = 8
    Position = 7
    Position = 6
    Position = 5
    Position = 4
    Position = 3
    Position = 2
    Position = 1
    Position = 0
    Each click results in 4 lines being printed to the serial monitor.
    Circuit is below - only difference is that I am using a HC7414N Schmitt trigger (yes its decoupled !):
Name:	Screen Shot 2019-02-28 at 9.05.48 pm.png
    If I turn the rotary encoder EXTREMELY slowly between detents I can get it to count up / down in 1 increment.
    Any help would be appreciated ! Is it the type of encoder I have that is doing this ? 4 counts per detent ?
    Is your Bournes encoder an optical quadrature encoder? In which case you might be getting the 4 phases giving one count each. The mechanical detents are also not really perfectly aligned to the optical discs inside an optical encoder which is why I find detent optical encoders difficult to use.
    Yes, its a quadrature encoder.
    Feb 2014
    Colmar, France
    2,277
    Where is the problem? There are different encoders, some with 1, others with 2, and still others with 4 counts per detent. It will be sufficient to adapt your loop() as follows :
      long newEncoderPos;
      newEncoderPos = (encoder0.read() >> 2); //same effect like divide by 4 but using much less CPU than a division
    Germany NRW
    5,419
    Its perfectly normal to get 4 counts.
    Thanks for the replies
