Results 1 to 13 of 13
Thread: Using Faust with Teensy
    May 2018
    108
    I was trying to use faust code with the (Arduino-)Teensy-IDE. Therefore I used the latest faust from github and the faust2teensy. I tried to fix the linking problems by following this, but it seems that it is outdated because changing recipe.c.combine.pattern="{compiler.path}{build.to olchain}{build.command.gcc}" to recipe.c.combine.pattern="{compiler.path}{build.to olchain}{build.command.g++}" is not really possible. build.command.gcc does not exist anymore (I am using Arduino-IDE-1.8.8 and Teensyduino-1.45).
    Has anyone a hint how to get faust examples (like FaustSawtooth) running?
    Thanks, Holger
    May 2018
    108
    Detailed test
    Hi all,
    I just tried again and wrote down what I have done. First I installed the actual faust release from github (because the Ubuntu release seems to be too old: there is no faust2teensy script available)
    # Install faust master-dev
    cd /tmp
    git clone https://github.com/grame-cncm/faust.git
    cd faust
    make
    sudo make install
    After that I created the simple demo as described in https://faust.grame.fr/doc/tutorials...nsy-with-faust:
    # Install test code
    mkdir /tmp/faust-teensy
    cd /tmp/faust-teensy
    cat >FaustSawtooth.dsp <<EOF
    import("stdfaust.lib");
    freq = nentry("freq",440,20,20000,0.01) : si.smoo;
    gain = nentry("gain",1,0,1,0.01) : si.smoo;
    process = os.sawtooth(freq)*gain;
    EOF
    faust2teensy -lib FaustSawtooth.dsp
    mkdir ~/Arduino/FaustSawtooth
    cd ~/Arduino
    unzip /tmp/faust-teensy/FaustSawtooth.zip
    cat >FaustSawtooth.ino <<EOF
    #include "FaustSawtooth.h"
    FaustSawtooth faustSawtooth;
    AudioOutputI2S out;
    AudioConnection patchCord0(faustSawtooth,0,out,0);
    AudioConnection patchCord1(faustSawtooth,0,out,1);
      AudioMemory(2);
      audioShield.enable();
      audioShield.volume(0.1);
      faustSawtooth.setParamValue("freq",random(50,1000));
      delay(50);
    EOF
    After loading this script into TeensyDuino-1.45 and trying to compile I got this:
    /tmp/arduino_build_465017/sketch/FaustSawtooth.cpp: In constructor 'FaustSawtooth::FaustSawtooth()':
    FaustSawtooth.cpp:748: warning: operation on '((FaustSawtooth*)this)->FaustSawtooth::fDSP' may be undefined
     FaustSawtooth::FaustSawtooth() : AudioStream((fDSP = new mydsp())->getNumInputs(), new audio_block_t*[fDSP->getNumInputs()])
    /tmp/arduino_build_465017/sketch/FaustSawtooth.cpp.o: In function `void std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_construct<char*>(char*, char*, std::forward_iterator_tag)':
    /home/local/arduino-1.8.8-teensy/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.tcc:219: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_create(unsigned int&, unsigned int)'
    /home/local/arduino-1.8.8-teensy/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.tcc:212: undefined reference to `std::__throw_logic_error(char const*)'
     Used: /home/local/arduino-1.8.8-teensy/hardware/teensy/avr/libraries/SD
     Not used: /home/local/arduino-1.8.8-teensy/libraries/SD
    /tmp/arduino_build_465017/sketch/FaustSawtooth.cpp.o: In function `std::_Rb_tree_iterator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, float*> >::operator--()':
    /home/local/arduino-1.8.8-teensy/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/stl_tree.h:220: undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
    /tmp/arduino_build_465017/sketch/FaustSawtooth.cpp.o: In function `std::_Rb_tree_iterator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, float*> >::operator++()':
    /home/local/arduino-1.8.8-teensy/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/stl_tree.h:205: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base*)'
    /tmp/arduino_build_465017/sketch/FaustSawtooth.cpp.o: In function `std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, float*>, std::_Select1st<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, float*> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, float*> > >::_M_insert_node(std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, float*> >*)':
    /home/local/arduino-1.8.8-teensy/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/stl_tree.h:2105: undefined reference to `std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
    /tmp/arduino_build_465017/sketch/FaustSawtooth.cpp.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
    /home/local/arduino-1.8.8-teensy/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.h:1058: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_append(char const*, unsigned int)'
    /tmp/arduino_build_465017/sketch/FaustSawtooth.cpp.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)':
    /home/local/arduino-1.8.8-teensy/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.h:1104: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_append(char const*, unsigned int)'
    /tmp/arduino_build_465017/sketch/FaustSawtooth.cpp.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_check_length(unsigned int, unsigned int, char const*) const':
    /home/local/arduino-1.8.8-teensy/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.h:271: undefined reference to `std::__throw_length_error(char const*)'
    /tmp/arduino_build_465017/sketch/FaustSawtooth.cpp.o:/home/local/arduino-1.8.8-teensy/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.h:1058: more undefined references to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_append(char const*, unsigned int)' follow
    collect2: error: ld returned 1 exit status
    Error compiling for board Teensy 3.6.
    Hm... I have no idea what's going wrong. The manual says that you should use the following platform.txt: https://faust.grame.fr/doc/tutorials/misc/platform.txt. But it seems that it is outdated... my platform.txt looks not like this one...
    Any ideas?
    TIA, Holger
    May 2018
    108
    I think I got it!
    Even if it doesn't look as if the platform.txt referenced at https://faust.grame.fr/doc/tutorials...nsy-with-faust matches the current TeensyDuino-1.45/Arduino-1.8.8: it works and the error messages are gone.
    I just don't understand why.
    But what is important: Faust creates the lookup tables with relatively fine resolution and you get problems with too little RAM. The solution is to reduce the resolution (see "Notes About Computational Power and Memory Footprint") like this:
    tblosc(n,f,freq,mod)    = (1-d)*rdtable(n,wform,i&(n-1)) +
                              d*rdtable(n,wform,(i+1)&(n-1))
    with {
            wform   = ba.time*(2.0*ma.PI)/n : f;
            phase           = freq/ma.SR : (+ : ma.decimal) ~ _;
            modphase        = ma.decimal(phase+mod/(2*ma.PI))*n;
            i               = int(floor(modphase));
            d               = ma.decimal(modphase);
            n = 1 << 15; // I added this!
    Regards, Holger
    Wow i had no idea Faust was implemented for teensy. Ive got to try this. Thanks for documenting this
    Jun 2014
    Helsinki
    2
    Quote Originally Posted by C0d3man View Post
    I think I got it!
    Regards, Holger
    Great to hear you got it running. Do you mind to develop how? Did you replace the platform.txt? or what did you change to make it work? I am experiencing the same kind of errors that you repport in the first post. I am using Arduino 1.8.9 and TeensyDuino 1.46. Working on the example https://faust.grame.fr/doc/tutorials...nsy-with-faust
    Thank you
    May 2018
    108
    Quote Originally Posted by relojero View Post
    Thank you
    As I wrote :
    "Even if it doesn't look as if the platform.txt referenced at https://faust.grame.fr/doc/tutorials...nsy-with-faust matches the current TeensyDuino-1.45/Arduino-1.8.8: it works and the error messages are gone."
    I tried with Arduino-IDE-1.8.8 and Teensyduino-1.45. Don't know if this works also for Arduino 1.8.9 and TeensyDuino 1.46. Be sure to make a copy of your old platform.txt!
    I currently havn't done anything else with faust, because the generated code eats the memory. I tried to use a faust-chorus. Now I am thinking of writing my own modulated delay line.
    Regards, Holger
    Boston, MA, USA
    1,111
    Hmm, I'm getting an error with a fresh install of Arduino 1.8.12 and Teensyduino 1.5.1. I added the two faust-specific lines near the top of platform.txt:
    # http://www.pjrc.com/teensy/teensyduino.html
    name=Teensyduino
    version=1.8.5
    rewriting=disabled
    ## Special Faust/Audio Compilation Flags
    audio.options=-DAUDIO_BLOCK_SAMPLES=8
    compiler.path={runtime.hardware.path}/../tools/
    (rest continues as usual)
    using the Bandlimited Sawtooth Oscillator on the Teensy example from
    http://faust.grame.fr/doc/tutorials/...nsy-with-faust
    and the online faust editor to create the Teensy .ino, .cpp and .h files
    https://faust.grame.fr/tools/editor/...2/exfaust2.dsp
    Compiling for either Teensy 3.6 or 4.0 gives errors. Full errors below; relevant portion seems to be
    In function `get_eit_entry':
    unwind-arm.c:(.text+0x134): undefined reference to `__exidx_end'
    unwind-arm.c:(.text+0x138): undefined reference to `__exidx_start'
    Arduino: 1.8.12 (Windows 10), TD: 1.51, Board: "Teensy 4.0, MIDI, 600 MHz, Faster, US English"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Chris\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Chris\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Chris\Documents\Arduino\sketches\libraries -fqbn=teensy:avr:teensy40:usb=midi,speed=600,opt=o2std,keys=en-us -ide-version=10812 -build-path C:\Users\Chris\AppData\Local\Temp\arduino_build_361300 -warnings=more -build-cache C:\Users\Chris\AppData\Local\Temp\arduino_cache_362607 -verbose C:\Users\Chris\Downloads\teensy\faustTutorial\faustTutorial.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Chris\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Chris\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Chris\Documents\Arduino\sketches\libraries -fqbn=teensy:avr:teensy40:usb=midi,speed=600,opt=o2std,keys=en-us -ide-version=10812 -build-path C:\Users\Chris\AppData\Local\Temp\arduino_build_361300 -warnings=more -build-cache C:\Users\Chris\AppData\Local\Temp\arduino_cache_362607 -verbose C:\Users\Chris\Downloads\teensy\faustTutorial\faustTutorial.ino
    Using board 'teensy40' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    aand I can't give the full error log because
    The text that you have entered is too long (301300 characters). Please shorten it to 200000 characters long.
    Linking everything together...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300/faustTutorial.ino.elf" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\sketch\\FaustSawtooth.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\sketch\\faustTutorial.ino.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\memcpy_audio.S.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\data_spdif.c.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\data_ulaw.c.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\data_waveforms.c.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\data_windows.c.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\analyze_fft1024.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\analyze_fft256.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\analyze_notefreq.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\analyze_peak.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\analyze_print.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\analyze_rms.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\analyze_tonedetect.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\control_ak4558.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\control_cs42448.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\control_cs4272.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\control_sgtl5000.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\control_tlv320aic3206.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\control_wm8731.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_bitcrusher.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_chorus.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_combine.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_delay.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_delay_ext.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_envelope.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_fade.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_flange.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_freeverb.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_granular.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_midside.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_multiply.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_reverb.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\effect_waveshaper.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\filter_biquad.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\filter_fir.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\filter_variable.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\input_adc.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\input_adcs.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\input_i2s.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\input_i2s2.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\input_i2s_quad.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\input_pdm.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\input_tdm.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\input_tdm2.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\mixer.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_adat.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_dac.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_dacs.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_i2s.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_i2s2.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_i2s_quad.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_mqs.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_pt8211.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_pt8211_2.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_pwm.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_spdif.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_spdif2.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_spdif3.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_tdm.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\output_tdm2.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\play_memory.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\play_queue.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\play_sd_raw.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\play_sd_wav.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\play_serialflash_raw.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\record_queue.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\spi_interrupt.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_dc.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_karplusstrong.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_pinknoise.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_pwm.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_simple_drum.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_sine.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_tonesweep.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_waveform.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_wavetable.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\synth_whitenoise.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\utility\\sqrt_integer.c.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Audio\\utility\\imxrt_hw.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\File.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\SD.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\cache_t3.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\card_t3.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\dir_t3.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\fat_t3.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\file_t3.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\init_t3.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\utility\\NXP_SDHC.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\utility\\Sd2Card.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\utility\\SdFile.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SD\\utility\\SdVolume.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SerialFlash\\SerialFlashChip.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\SerialFlash\\SerialFlashDirectory.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Wire\\WireIMXRT.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Wire\\WireKinetis.cpp.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300/core\\core.a" "-LC:\\Users\\Chris\\AppData\\Local\\Temp\\arduino_build_361300" -larm_cortexM7lfsp_math -lm -lstdc++
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/armv7e-m/fpu/fpv5-d16\libgcc.a(unwind-arm.o): In function `get_eit_entry':
     Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
     Not used: C:\Program Files (x86)\Arduino\libraries\SD
    Using library Audio at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
    Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
    Using library SD at version 1.2.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
    Using library SerialFlash at version 0.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SerialFlash
    Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
    Error compiling for board Teensy 4.0.
    Attached Files Attached Files
    Hi Nantonos,
    same problem for me, with a teensy 3.2, and the latest version of arduino and teensyduino. I had also tested previously with PlatformIO under Visual Studio Code. I tried to modifiy boards.txt and platform.txt but linking fails even when using g++ as linker.
    My error message is not exactly the same as yours, but it also mentions __exidx_end and __exidx_start :
    Building in release mode
    Linking .pio/build/teensy31/firmware.elf
    .pio/build/teensy31/src/effect.cpp.o:(.bss.__exidx_end+0x0): multiple definition of `__exidx_end'
    .pio/build/teensy31/src/Effect.cpp.o:(.bss.__exidx_end+0x0): first defined here
    /home/maxime/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Disabling relaxation: it will not work with multiple definitions
    .pio/build/teensy31/src/effect.cpp.o:(.bss.__exidx_start+0x0): multiple definition of `__exidx_start'
    .pio/build/teensy31/src/Effect.cpp.o:(.bss.__exidx_start+0x0): first defined here
    /home/maxime/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/libc.a(lib_a-writer.o): In function `_write_r':
    writer.c:(.text._write_r+0x12): undefined reference to `_write'
    *** [.pio/build/teensy31/firmware.elf] Error 1
    May 2020
    2
    I got the same Problem, compiling with the Faust online editor..
    I hope there a fix or workaround some day because Faust is pretty cool
    May 2020
    1
    This setup works for me
    • Teensy 4.0 with Audio Adaptor
    • macOS 10.15
    faust built from master-dev on GitHub
    • VS Code with PlatformIO
    My platform.ini looks like this:
    [env:teensy40]
    platform = teensy
    board = teensy40
    framework = arduino
    build_flags = -DAUDIO_BLOCK_SAMPLES=8
    Steps
    1. Make a Faust DSP file, for example test.dsp
    2. Generate DSP objects compatible with the Teensy Audio Library: faust2teensy -lib test.dsp
    3. Use the generated DSP objects (test.h and test.cpp) in a main.cpp including Teensy Audio Library
    4. Build, Upload, and Monitor using the PlatformIO tools
    I have left out a number of more or less important details, but this can hopefully help as a start.
    NOTE:
    Sometimes I've been able to build but not run code on Teensy 4.0. I've been told it's probably because the Faust DSP objects use too much memory. For example I've been able to run re.mono_freeverb, but not re.stereo_freeverb. Using Teensy < 4.0 will probably induce a greater risk of memory problems, since Teensy has more memory than its predecessors.
    Here is some good information https://faust.grame.fr/doc/tutorials...nsy-with-faust
    Oct 2019
    10
    Quote Originally Posted by maxime_andre View Post
    Hi Nantonos,
    I also have the same problem and accidently started a new thread here on the forum (didn't use the search function, shame on me).
    I noticed, that you get those errors with " multiple definition of `__exidx_end' " when you include more than one faust objects in your Arduino sketch.
    The Arduino IDE somehow includes all .h files int the sketches directory, even if you don't manually include them via #include. In your case, you probably have two faust objects, one called effects and one called Effects. Try removing one of those from your directory and it should work.
    Being limited to one Faust object is rather sad though, and probably a bug.
    I also opened a github issue (https://github.com/grame-cncm/faust/issues/434) but got redirected to the Teensy forum. (Somehow, nobody wants to feel responsible for this ^^)
    Yes, that's it ! Thank you !
    At the beginning, I created "effect.dsp", and renamed it later to "Effect.dsp", but i forgot to remove the corresponding .cpp and .h files.
    And I have found the solution for the last error "undifined reference to `_write'" : the c standard library was not linked. The solution was to add this line in platformio.ini :
    build_flags = -llibc -lc
    I've just put my teensy in a stompbox enclosure, when the glue dries I will upload that !!
    May 2020
    2
    Really nice, that solved it also for me!
    Thank you!!
