I've got a Teensy 3.6 and I'm trying to log data to the on-board Sd Card. CardInfo.ino and TwoCard.ino (with Teensy modifications, see below) all work fine. However, with my Teensy modified LowLatencyLogger.ino I get the "error: createContiguous failed" when I try to perform the logging. What am I missing (as a Teensy and SdFat noob, I know it's a lot)? Is there a better way to do logging with the Teensy?
For reference, my goal is to log data to both the Teensy 3.6 Sd card (CardInfo.ino is working, LowLatencyLogger.ino is not) and an SPI connected Sd card for data redundancy (both CardInfo.ino and LowLatencyLogger.ino are working fine). I modified TwoCards.ino and that's working fine too.
I also tried an older logger from this post, but it gives compile errors ('block_t' does not name a type) with the latest SdFat library and going to SdFat-Beta seems like a bad move.
Teensy modified LowLatencyLogger.ino, gives error: createContiguous failed when running "r - record data":
Teensy modified TwoCards.ino, working fine:
* This program logs data to a binary file. Functions are included
* to convert the binary file to a csv text file.
* Samples are logged at regular intervals. The maximum logging rate
* depends on the quality of your SD card and the time required to
* read sensor data. This example has been tested at 500 Hz with
* good SD card on an Uno. 4000 HZ is possible on a Due.
* If your SD card has a long write latency, it may be necessary to use
* slower sample rates. Using a Mega Arduino helps overcome latency
* problems since 12 512 byte buffers will be used.
* Data is written to the file using a SD multiple block write command.
#include "SdFat.h"
#include "FreeStack.h"
#include "UserTypes.h"
#ifdef __AVR_ATmega328P__
#include "MinimumSerial.h"
MinimumSerial MinSerial;
#define Serial MinSerial
#endif // __AVR_ATmega328P__
// Start of configuration constants.
// Abort run on an overrun. Data before the overrun will be saved.
#define ABORT_ON_OVERRUN 1
//Interval between data records in microseconds.
const uint32_t LOG_INTERVAL_USEC = 2000;
// Set USE_SHARED_SPI non-zero for use of an SPI sensor.
// May not work for some cards.
#ifndef USE_SHARED_SPI
#define USE_SHARED_SPI 0
#endif // USE_SHARED_SPI
// Pin definitions.
// Set USE_SDIO to zero for SPI card access.
#define USE_SDIO 1 // 0 for SPI Sd Card, 1 for Teensy Sd Card
// SD chip select pin.
const uint8_t SD_CS_PIN = 10;
// Digital pin to indicate an error, set to -1 if not used.
// The led blinks for fatal errors. The led goes on solid for
// overrun errors and logging continues unless ABORT_ON_OVERRUN
// is non-zero.
#ifdef ERROR_LED_PIN
#undef ERROR_LED_PIN
#endif // ERROR_LED_PIN
const int8_t ERROR_LED_PIN = -1;
// File definitions.
// Maximum file size in blocks.
// The program creates a contiguous file with FILE_BLOCK_COUNT 512 byte blocks.
// This file is flash erased using special SD commands. The file will be
// truncated if logging is stopped early.
const uint32_t FILE_BLOCK_COUNT = 256000;
// log file base name if not defined in UserTypes.h
#ifndef FILE_BASE_NAME
#define FILE_BASE_NAME "data"
#endif // FILE_BASE_NAME
// Buffer definitions.
// The logger will use SdFat's buffer plus BUFFER_BLOCK_COUNT-1 additional
// buffers.
#ifndef RAMEND
// Assume ARM. Use total of ten 512 byte buffers.
const uint8_t BUFFER_BLOCK_COUNT = 10;
#elif RAMEND < 0X8FF
#error Too little SRAM
#elif RAMEND < 0X10FF
// Use total of two 512 byte buffers.
const uint8_t BUFFER_BLOCK_COUNT = 2;
#elif RAMEND < 0X20FF
// Use total of four 512 byte buffers.
const uint8_t BUFFER_BLOCK_COUNT = 4;
#else // RAMEND
// Use total of 12 512 byte buffers.
const uint8_t BUFFER_BLOCK_COUNT = 12;
#endif // RAMEND
// End of configuration constants.
// Temporary log file. Will be deleted if a reset or power failure occurs.
#define TMP_FILE_NAME FILE_BASE_NAME "##.bin"
// Size of file base name.
const uint8_t BASE_NAME_SIZE = sizeof(FILE_BASE_NAME) - 1;
const uint8_t FILE_NAME_DIM = BASE_NAME_SIZE + 7;
char binName[FILE_NAME_DIM] = FILE_BASE_NAME "00.bin";
#if USE_SDIO
// Use faster SdioCardEX
SdFatSdioEX sd;
// SdFatSdio sd;
#else // USE_SDIO
SdFat sd;
#endif // USE_SDIO
SdBaseFile binFile;
// Number of data records in a block.
const uint16_t DATA_DIM = (512 - 4)/sizeof(data_t);
//Compute fill so block size is 512 bytes. FILL_DIM may be zero.
const uint16_t FILL_DIM = 512 - 4 - DATA_DIM*sizeof(data_t);
struct block_t {
uint16_t count;
uint16_t overrun;
data_t data[DATA_DIM];
uint8_t fill[FILL_DIM];
// Error messages stored in flash.
#define error(msg) {sd.errorPrint(&Serial, F(msg));fatalBlink();}
void fatalBlink() {
while (true) {
SysCall::yield();
if (ERROR_LED_PIN >= 0) {
digitalWrite(ERROR_LED_PIN, HIGH);
delay(200);
digitalWrite(ERROR_LED_PIN, LOW);
delay(200);
// read data file and check for overruns
void checkOverrun() {
bool headerPrinted = false;
block_t block;
uint32_t bn = 0;
if (!binFile.isOpen()) {
Serial.println(F("No current binary file"));
return;
binFile.rewind();
Serial.print(F("FreeStack: "));
Serial.println(FreeStack());
Serial.println(F("Checking overrun errors - type any character to stop"));
while (binFile.read(&block, 512) == 512) {
if (block.count == 0) {
if (block.overrun) {
if (!headerPrinted) {
Serial.println(F("Overruns:"));
Serial.println(F("fileBlockNumber,sdBlockNumber,overrunCount"));
headerPrinted = true;
Serial.print(bn);
Serial.print(',');
Serial.print(binFile.firstBlock() + bn);
Serial.print(',');
Serial.println(block.overrun);
bn++;
Serial.println(F("No errors found"));
Serial.println(F("Done"));
// Convert binary file to csv file.
void binaryToCsv() {
uint8_t lastPct = 0;
block_t block;
uint32_t t0 = millis();
uint32_t syncCluster = 0;
SdFile csvFile;
char csvName[FILE_NAME_DIM];
return;
// Create a new csvFile.
strcpy(csvName, binName);
strcpy(&csvName[BASE_NAME_SIZE + 3], "csv");
if (!csvFile.open(csvName, O_WRONLY | O_CREAT | O_TRUNC)) {
error("open csvFile failed");
binFile.rewind();
Serial.print(F("Writing: "));
Serial.print(csvName);
Serial.println(F(" - type any character to stop"));
printHeader(&csvFile);
uint32_t tPct = millis();
while (!Serial.available() && binFile.read(&block, 512) == 512) {
uint16_t i;
if (block.count == 0 || block.count > DATA_DIM) {
csvFile.print(F("OVERRUN,"));
csvFile.println(block.overrun);
for (i = 0; i < block.count; i++) {
printData(&csvFile, &block.data[i]);
if (csvFile.curCluster() != syncCluster) {
csvFile.sync();
syncCluster = csvFile.curCluster();
if ((millis() - tPct) > 1000) {
uint8_t pct = binFile.curPosition()/(binFile.fileSize()/100);
if (pct != lastPct) {
tPct = millis();
lastPct = pct;
Serial.print(pct, DEC);
Serial.println('%');
if (Serial.available()) {
csvFile.close();
Serial.print(F("Done: "));
Serial.print(0.001*(millis() - t0));
Serial.println(F(" Seconds"));
void createBinFile() {
// max number of blocks to erase per erase call
const uint32_t ERASE_SIZE = 262144L;
uint32_t bgnBlock, endBlock;
// Delete old tmp file.
if (sd.exists(TMP_FILE_NAME)) {
Serial.println(F("Deleting tmp file " TMP_FILE_NAME));
if (!sd.remove(TMP_FILE_NAME)) {
error("Can't remove tmp file");
// Create new file.
Serial.println(F("\nCreating new file"));
binFile.close();
if (!binFile.createContiguous(TMP_FILE_NAME, 512 * FILE_BLOCK_COUNT)) {
error("createContiguous failed");
// Get the address of the file on the SD.
if (!binFile.contiguousRange(&bgnBlock, &endBlock)) {
error("contiguousRange failed");
// Flash erase all data in the file.
Serial.println(F("Erasing all data"));
uint32_t bgnErase = bgnBlock;
uint32_t endErase;
while (bgnErase < endBlock) {
endErase = bgnErase + ERASE_SIZE;
if (endErase > endBlock) {
endErase = endBlock;
if (!sd.card()->erase(bgnErase, endErase)) {
error("erase failed");
bgnErase = endErase + 1;
// dump data file to Serial
void dumpData() {
block_t block;
return;
binFile.rewind();
Serial.println(F("Type any character to stop"));
printHeader(&Serial);
while (!Serial.available() && binFile.read(&block , 512) == 512) {
Serial.print(F("OVERRUN,"));
for (uint16_t i = 0; i < block.count; i++) {
printData(&Serial, &block.data[i]);
// log data
void logData() {
createBinFile();
recordBinFile();
renameBinFile();
void openBinFile() {
char name[FILE_NAME_DIM];
strcpy(name, binName);
Serial.println(F("\nEnter two digit version"));
Serial.write(name, BASE_NAME_SIZE);
for (int i = 0; i < 2; i++) {
while (!Serial.available()) {
SysCall::yield();
char c = Serial.read();
Serial.write(c);
if (c < '0' || c > '9') {
Serial.println(F("\nInvalid digit"));
return;
name[BASE_NAME_SIZE + i] = c;
Serial.println(&name[BASE_NAME_SIZE+2]);
if (!sd.exists(name)) {
Serial.println(F("File does not exist"));
return;
binFile.close();
strcpy(binName, name);
if (!binFile.open(binName, O_RDONLY)) {
Serial.println(F("open failed"));
return;
Serial.println(F("File opened"));
void recordBinFile() {
const uint8_t QUEUE_DIM = BUFFER_BLOCK_COUNT + 1;
// Index of last queue location.
const uint8_t QUEUE_LAST = QUEUE_DIM - 1;
// Allocate extra buffer space.
block_t block[BUFFER_BLOCK_COUNT - 1];
block_t* curBlock = 0;
block_t* emptyStack[BUFFER_BLOCK_COUNT];
uint8_t emptyTop;
uint8_t minTop;
block_t* fullQueue[QUEUE_DIM];
uint8_t fullHead = 0;
uint8_t fullTail = 0;
// Use SdFat's internal buffer.
emptyStack[0] = (block_t*)sd.vol()->cacheClear();
if (emptyStack[0] == 0) {
error("cacheClear failed");
// Put rest of buffers on the empty stack.
for (int i = 1; i < BUFFER_BLOCK_COUNT; i++) {
emptyStack[i] = &block[i - 1];
emptyTop = BUFFER_BLOCK_COUNT;
minTop = BUFFER_BLOCK_COUNT;
// Start a multiple block write.
if (!sd.card()->writeStart(binFile.firstBlock())) {
error("writeStart failed");
Serial.println(F("Logging - type any character to stop"));
bool closeFile = false;
uint32_t bn = 0;
uint32_t maxLatency = 0;
uint32_t overrun = 0;
uint32_t overrunTotal = 0;
uint32_t logTime = micros();
while(1) {
// Time for next data record.
logTime += LOG_INTERVAL_USEC;
closeFile = true;
if (closeFile) {
if (curBlock != 0) {
// Put buffer in full queue.
fullQueue[fullHead] = curBlock;
fullHead = fullHead < QUEUE_LAST ? fullHead + 1 : 0;
curBlock = 0;
if (curBlock == 0 && emptyTop != 0) {
curBlock = emptyStack[--emptyTop];
if (emptyTop < minTop) {
minTop = emptyTop;
curBlock->count = 0;
curBlock->overrun = overrun;
overrun = 0;
if ((int32_t)(logTime - micros()) < 0) {
error("Rate too fast");
int32_t delta;
do {
delta = micros() - logTime;
} while (delta < 0);
if (curBlock == 0) {
overrun++;
overrunTotal++;
#if ABORT_ON_OVERRUN
Serial.println(F("Overrun abort"));
#endif // ABORT_ON_OVERRUN
#if USE_SHARED_SPI
sd.card()->spiStop();
acquireData(&curBlock->data[curBlock->count++]);
#if USE_SHARED_SPI
sd.card()->spiStart();
if (curBlock->count == DATA_DIM) {
curBlock = 0;
if (fullHead == fullTail) {
// Exit loop if done.
if (closeFile) {
} else if (!sd.card()->isBusy()) {
// Get address of block to write.
block_t* pBlock = fullQueue[fullTail];
fullTail = fullTail < QUEUE_LAST ? fullTail + 1 : 0;
// Write block to SD.
uint32_t usec = micros();
if (!sd.card()->writeData((uint8_t*)pBlock)) {
error("write data failed");
usec = micros() - usec;
if (usec > maxLatency) {
maxLatency = usec;
// Move block to empty queue.
emptyStack[emptyTop++] = pBlock;
bn++;
if (bn == FILE_BLOCK_COUNT) {
// File full so stop
if (!sd.card()->writeStop()) {
error("writeStop failed");
Serial.print(F("Min Free buffers: "));
Serial.println(minTop);
Serial.print(F("Max block write usec: "));
Serial.println(maxLatency);
Serial.print(F("Overruns: "));
Serial.println(overrunTotal);
// Truncate file if recording stopped early.
if (bn != FILE_BLOCK_COUNT) {
Serial.println(F("Truncating file"));
if (!binFile.truncate(512L * bn)) {
error("Can't truncate file");
void recoverTmpFile() {
uint16_t count;
if (!binFile.open(TMP_FILE_NAME, O_RDWR)) {
return;
if (binFile.read(&count, 2) != 2 || count != DATA_DIM) {
error("Please delete existing " TMP_FILE_NAME);
Serial.println(F("\nRecovering data in tmp file " TMP_FILE_NAME));
uint32_t bgnBlock = 0;
uint32_t endBlock = binFile.fileSize()/512 - 1;
// find last used block.
while (bgnBlock < endBlock) {
uint32_t midBlock = (bgnBlock + endBlock + 1)/2;
binFile.seekSet(512*midBlock);
if (binFile.read(&count, 2) != 2) error("read");
if (count == 0 || count > DATA_DIM) {
endBlock = midBlock - 1;
bgnBlock = midBlock;
// truncate after last used block.
if (!binFile.truncate(512*(bgnBlock + 1))) {
error("Truncate " TMP_FILE_NAME " failed");
renameBinFile();
void renameBinFile() {
while (sd.exists(binName)) {
if (binName[BASE_NAME_SIZE + 1] != '9') {
binName[BASE_NAME_SIZE + 1]++;
binName[BASE_NAME_SIZE + 1] = '0';
if (binName[BASE_NAME_SIZE] == '9') {
error("Can't create file name");
binName[BASE_NAME_SIZE]++;
if (!binFile.rename(binName)) {
error("Can't rename file");
Serial.print(F("File renamed: "));
Serial.println(binName);
Serial.print(F("File size: "));
Serial.print(binFile.fileSize()/512);
Serial.println(F(" blocks"));
void testSensor() {
const uint32_t interval = 200000;
int32_t diff;
data_t data;
Serial.println(F("\nTesting - type any character to stop\n"));
// Wait for Serial Idle.
uint32_t m = micros();
m += interval;
do {
diff = m - micros();
} while (diff > 0);
acquireData(&data);
printData(&Serial, &data);
void setup(void) {
pinMode(ERROR_LED_PIN, OUTPUT);
// Wait for USB Serial
while (!Serial) {
SysCall::yield();
Serial.print(F("\nFreeStack: "));
Serial.print(F("Records/block: "));
Serial.println(DATA_DIM);
if (sizeof(block_t) != 512) {
error("Invalid block size");
// Allow userSetup access to SPI bus.
pinMode(SD_CS_PIN, OUTPUT);
digitalWrite(SD_CS_PIN, HIGH);
// Setup sensors.
userSetup();
// Initialize at the highest speed supported by the board that is
// not over 50 MHz. Try a lower speed if SPI errors occur.
/*if (!sd.begin(SD_CS_PIN, SD_SCK_MHZ(50))) {
sd.initErrorPrint(&Serial);
fatalBlink();
#if USE_SDIO
if (!sd.cardBegin()) {
//sdErrorMsg("\ncardBegin failed");
fatalBlink();
//return;
#else // USE_SDIO
//sdErrorMsg("cardBegin failed");
fatalBlink();
//return;
#endif // USE_SDIO */
// recover existing tmp file.
Serial.println(F("\nType 'Y' to recover existing tmp file " TMP_FILE_NAME));
SysCall::yield();
if (Serial.read() == 'Y') {
recoverTmpFile();
error("'Y' not typed, please manually delete " TMP_FILE_NAME);
void loop(void) {
// Read any Serial data.
do {
delay(10);
} while (Serial.available() && Serial.read() >= 0);
Serial.println(F("type:"));
Serial.println(F("b - open existing bin file"));
Serial.println(F("c - convert file to csv"));
Serial.println(F("d - dump data to Serial"));
Serial.println(F("e - overrun error details"));
Serial.println(F("l - list files"));
Serial.println(F("r - record data"));
Serial.println(F("t - test without logging"));
while(!Serial.available()) {
SysCall::yield();
#if WDT_YIELD_TIME_MICROS
Serial.println(F("LowLatencyLogger can not run with watchdog timer"));
SysCall::halt();
char c = tolower(Serial.read());
// Discard extra Serial data.
do {
delay(10);
if (c == 'b') {
openBinFile();
} else if (c == 'c') {
binaryToCsv();
} else if (c == 'd') {
dumpData();
} else if (c == 'e') {
checkOverrun();
} else if (c == 'l') {
Serial.println(F("\nls:"));
sd.ls(&Serial, LS_SIZE);
} else if (c == 'r') {
logData();
} else if (c == 't') {
testSensor();
Serial.println(F("Invalid entry"));
* Warning This example requires extra RAM and may crash on Uno.
* Example use of two SD cards.
#include "SdFat.h"
SdFat sd1;
const uint8_t SD1_CS = 10; // chip select for sd1
SdFatSdioEX sd2;
//const uint8_t SD2_CS = 4; // chip select for sd2
const uint8_t BUF_DIM = 100;
uint8_t buf[BUF_DIM];
const uint32_t FILE_SIZE = 1000000;
const uint16_t NWRITE = FILE_SIZE/BUF_DIM;
// print error msg, any SD error codes, and halt.
// store messages in flash
#define errorExit(msg) errorHalt(F(msg))
#define initError(msg) initErrorHalt(F(msg))
while (!Serial) {
SysCall::yield();
// fill buffer with known data
for (size_t i = 0; i < sizeof(buf); i++) {
buf[i] = i;
Serial.println(F("type any character to start"));
SysCall::yield();
// disable sd2 while initializing sd1
//pinMode(SD2_CS, OUTPUT);
//digitalWrite(SD2_CS, HIGH);
// initialize the first card
if (!sd1.begin(SD1_CS)) {
sd1.initError("sd1:");
// create Dir1 on sd1 if it does not exist
if (!sd1.exists("/Dir1")) {
if (!sd1.mkdir("/Dir1")) {
sd1.errorExit("sd1.mkdir");
// initialize the second card
//if (!sd2.begin(SD2_CS)) {
if (!sd2.begin()) {
sd2.initError("sd2:");
// create Dir2 on sd2 if it does not exist
if (!sd2.exists("/Dir2")) {
if (!sd2.mkdir("/Dir2")) {
sd2.errorExit("sd2.mkdir");
// list root directory on both cards
Serial.println(F("------sd1 root-------"));
sd1.ls();
Serial.println(F("------sd2 root-------"));
sd2.ls();
// make /Dir1 the default directory for sd1
if (!sd1.chdir("/Dir1")) {
sd1.errorExit("sd1.chdir");
// make /Dir2 the default directory for sd2
if (!sd2.chdir("/Dir2")) {
sd2.errorExit("sd2.chdir");
// list current directory on both cards
Serial.println(F("------sd1 Dir1-------"));
sd1.ls();
Serial.println(F("------sd2 Dir2-------"));
sd2.ls();
Serial.println(F("---------------------"));
// remove rename.bin from /Dir2 directory of sd2
if (sd2.exists("rename.bin")) {
if (!sd2.remove("rename.bin")) {
sd2.errorExit("remove rename.bin");
// set the current working directory for open() to sd1
sd1.chvol();
// create or open /Dir1/test.bin and truncate it to zero length
SdFile file1;
if (!file1.open("test.bin", O_RDWR | O_CREAT | O_TRUNC)) {
sd1.errorExit("file1");
Serial.println(F("Writing test.bin to sd1"));
// write data to /Dir1/test.bin on sd1
for (uint16_t i = 0; i < NWRITE; i++) {
if (file1.write(buf, sizeof(buf)) != sizeof(buf)) {
sd1.errorExit("sd1.write");
// set the current working directory for open() to sd2
sd2.chvol();
// create or open /Dir2/copy.bin and truncate it to zero length
SdFile file2;
if (!file2.open("copy.bin", O_WRONLY | O_CREAT | O_TRUNC)) {
sd2.errorExit("file2");
Serial.println(F("Copying test.bin to copy.bin"));
// copy file1 to file2
file1.rewind();
uint32_t t = millis();
while (1) {
int n = file1.read(buf, sizeof(buf));
if (n < 0) {
sd1.errorExit("read1");
if (n == 0) {
if ((int)file2.write(buf, n) != n) {
sd2.errorExit("write2");
t = millis() - t;
Serial.println(file2.fileSize());
Serial.print(F("Copy time: "));
Serial.print(t);
Serial.println(F(" millis"));
// close test.bin
file1.close();
file2.close();
Serial.println(F("------sd1 -------"));
sd1.ls("/", LS_R | LS_DATE | LS_SIZE);
Serial.println(F("------sd2 -------"));
sd2.ls("/", LS_R | LS_DATE | LS_SIZE);
Serial.println(F("Renaming copy.bin"));
// rename the copy
if (!sd2.rename("copy.bin", "rename.bin")) {
sd2.errorExit("sd2.rename");
void loop() {}
