ffb.boy.30
New member
I would like to use a teensy 3.6 for my project and I would like to know if it is able to do the job.
I need to use 2 CANBus at 1M : need to send 10 PDO each every 5ms.
I need to have 3 UDP port with a Wiznet module for example : receive 100Hz packets each with 100 bytes .
A real serial port at 230400 baud minimum.
An USB device able to simulate HID device.
an SDcard capabilities to store high rate informations 100 byte every ms.
I know someone that use the Teensy and make awesome project.
Thanks you for you diagnostic
