Page 2 of 2 FirstFirst 1 2
Results 26 to 31 of 31
Thread: New adafruit GFX 1.4.x libs doesn't work for me
  1. #26
    4,546
    Ughhh - retesting here and I also get the black screen issue.
    Earlier I tested with version 1.2.4. Looks like something broke starting with version 1.2.6. I'm putting this library back on my list of issues to investigate.
    Just to be realistic, I probably won't be able to dig into what went wrong for at least a couple weeks. In the meantime, I recommend using the library manager to uninstall 1.2.8 and install version 1.2.5. I tested just now and 1.2.5 seems to be working fine.
    Here's how the buttons render at the end of "graphictest" with 1.2.5.
    Attachment 16360
    For the heck of it, I picked up an ST7789 from Amazon (https://smile.amazon.com/MakerFocus-.../dp/B07P9X3L7M)
    But not sure if it will actually work?
    That is the pins are marked(GND, VCC, SCL, SDA, RES, DC, BLK)
    i.e. no CS pin?
  2. #27
    Member tcottle's Avatar
    Dec 2014
    Longmont, CO
    39
    Well I have made some more progress. I don't think that it is a problem in the Teensy though. I suspect that the library is broken from 1.26 to 1.29 but I do not have a real Arduino board to verify on (everything that I have on hand is a Teensy 3.X )
    The problem is in the ST77XX displayInit method in Adafruit_ST77xx.cpp. The routine spits out a standard display initialization sequence.
    Here is 1.25
    void Adafruit_ST77xx::displayInit(const uint8_t *addr) {
      uint8_t  numCommands, numArgs;
      uint16_t ms;
      numCommands = pgm_read_byte(addr++);   // Number of commands to follow
      while(numCommands--) {                 // For each command...
        startWrite();
        writeCommand(pgm_read_byte(addr++)); //   Read, issue command
        numArgs  = pgm_read_byte(addr++);    //   Number of args to follow
        ms       = numArgs & ST_CMD_DELAY;   //   If hibit set, delay follows args
        numArgs &= ~ST_CMD_DELAY;            //   Mask out delay bit
        while(numArgs--) {                   //   For each argument...
          spiWrite(pgm_read_byte(addr++));  //     Read, issue argument
        endWrite();
        if(ms) {
          ms = pgm_read_byte(addr++); // Read post-command delay time (ms)
          if(ms == 255) ms = 500;     // If 255, delay for 500 ms
          delay(ms);
    and 1.26.
      uint16_t ms;
      startWrite();
        if(ms) {
          delay(ms);
      endWrite();
    The startWrite() and endWrite() routines were moved outside of the while loop (for unknown reasons) and this is what breaks on the ST7789 display
    They seem to have noticed this and and tried to toggle the CS line inside the while loop as a patch for the ST7789. It didn't work
    1.29
      uint16_t ms;
      startWrite();
        SPI_CS_HIGH(); SPI_CS_LOW();  // ST7789 needs chip deselect after each
        if(ms) {
          delay(ms);
      endWrite();
    so here is a patched 1.29 routine that works for me
      uint16_t ms;
    	startWrite();
    //    SPI_CS_HIGH(); SPI_CS_LOW();  // ST7789 needs chip deselect after each
    	endWrite();
        if(ms) {
          delay(ms);
  3. #28
    19,922
    Quote Originally Posted by tcottle View Post
    Oh, that's probably not going to work on Teensy 3.6 if they're using direct register I/O. The pins default to slew rate limiting, which is a feature you definitely do want if running the signals over those inches-long wires. With slew rate limiting, back-to-back writes directly to the register on Teensy 3.6 runs so fast (only 5 or 10 ns) that the pin's voltage can't fully change!
  4. #29
    Dec 2014
    Longmont, CO
    39
    Hmmm can't edit my old post - anyway please change the references to 1.29 to 1.28 (the latest issue)
    Based on Paul's insight I grabbed a fresh copy of 1.28 and added a 10uS delay between CS_HIGH and CS_LOW. Pleased to report that it now works with this change only. Tried smaller delays and for my breadboard setup with long leads 3uS was the shortest delay that would still work
  5. #30
    19,922
    Would you consider opening an issue on Adafruit's github repository for this library?
  6. #31
    Dec 2014
    Longmont, CO
    39
    Sure (once I figure out how to :-D)
