Results 1 to 8 of 8
Thread: Teensy to teensy USB
    Feb 2019
    4
    Is communication between two or more Teensy 3.6 controllers on either USB port possible? If so, has anyone made any libraries for this purpose?
    Thanks,
    Dae
    19,744
    I believe you can plug any Teensy running Serial into the Teensy 3.6 host port.
    In Arduino, click File > Examples > USBHost_t36 > SerialTest for code to get started.
    Feb 2019
    4
    Thank you for your response. I will look into USBHost_t36 when I get a spare moment. Do you know if a single Teensy can communicate with several other Teensys in a hub/spoke pattern via a USB hub?
    I have a need to communicate between five teensys at the fastest data transfer rate possible, one master and four slave devices. I2C is too slow and the Teensy seems to have trouble using SPI as a slave (if this is not the case I am very much interested in SPI). Is USB a viable alternative in this configuration?
    19,744
    Yes, USBHost_t36 supports hubs. You can put as many hub & serial instances in your program as needed.
    Mar 2015
    13
    does this mean I could connect a usb hub to a teensy 3.6 and connect as many other teensy boards, lets say LCs to the usb hub and have all communicate via their own serial object instance? Does the USBSerial object provide similar methods as the normal serial object? (I quickly scanned through the source, seems like this is the case, but I am not sure)
    Is there any documentation yet? Is the library '"stable"?
    If this is all true, this seems to be very very nice!
    What would be the speed one could expect?
    19,744
    Yes, to all your questions, except "sort of" on the library status. The core EHCI & enumeration stuff is pretty solid, and the serial and hub drivers work very well. The library still does not support isochronous at all, and there's a long list of drivers to make, so large changes can be expected to the library for quite some time. There's also a good chance we'll eventually migrate to using EventResponder for some stuff, which could be considered quite a large change.
    Support for high-speed (480 Mbit) USB serial devices is still lacking. Not an issue with Teensy 3.x boards.
    Of course the available memory does limit the number of driver instances. Teensy 3.6 has quite a lot of memory and each instance doesn't use much memory, but eventually if you expand to hundreds of devices, you will hit memory limits.
    Mar 2015
    13
    wow! Thanks a lot!
    Now I have to get a teensy 3.6 :-)
    I guess the bigger problem is to find a good and cheap usb hub with many ports
    19,744
    When you use "large" hub like 10 or 13 ports, keep in mind that nearly all of them are internally several 4 port hubs connected together. You'll need 1 hub instance in your code for each actual hub chip, even though the consumer-visible info looks like it's just 1 hub.
