Results 1 to 5 of 5
Thread: Necessity of Level Shifter for Teensy 3.2 I2C Functionality
    Mar 2019
    2
    I've read just about everything on this forum I can find about using Teensy 3.2 and I2C. I have successfully gotten a Teensy slave working with a Teensy master using I2C protocol for testing purposes.
    I am now attaching the Teensy 3.2 to a 5V logic I2C bus within another system but haven't succeeded in I2C SCL or SDA to the Teensy. I want to rule out the necessity of a level shifter for the Teensy 3.2.
    Is a level shifter needed for I2C functionality of a Teensy 3.2 on a 5V logic bus? I believe the answer is no since I2C pulls down the line, but I want to double check here as well and ensure I don't need extra hardware to get this working. I know Teensy's are 5V tolerant on digital pins and just need to rule this possibility out so I can continue debugging more into software perhaps.
    Thank you for the time!
    Hi, try putting two pullup resistors 4k7 on sda and scl
    https://www.pjrc.com/teensy/td_libs_Wire.html
    Mar 2019
    2
    I've got 2 pullups on there now and they work great with another Teensy as a Master. The issue is when I am putting the Teensy slave on a 5V I2C bus though and whether a level shifter isn't actually needed since I2C pulls the line down?
    theoretically there is no need, teensy 3.2 is 5v tolerant.
    Feb 2017
    279
    Why not just use the level shifter and remove all doubt? Here: https://www.adafruit.com/product/757
