Results 1 to 4 of 4
Thread: Differential ADC Values Off
    Feb 2019
    2
    I am using the differential pins on ADC1 to do some sampling (currently trying 22.05kHz). The PDB and DMA interrupts are working fine. I have tested all of my code using single ended mode and everything was working flawlessly.
    Now I am trying to convert all of this to use the differential ADC so I don't need any conversion circuit for my differential signal.
    I set the reference on ADC1 to 3V3 and the resolution to 12 bits (which I understand is really 13 when using differential mode).
    The problem is that when I check the samples they are either <20 or >65530, the entire midsection of my wave is getting cut off. It is also very weird to me that I'm getting 16 bit values when I explicitly set it to 12 bit resolution
    Did I toast the ADC? Is there something I'm missing that I didn't do to get correct samples?
    I will get some code up later, thanks
    Feb 2014
    Colmar, France
    2,299
    Even when doing differential, both input signals have to be between 0 and 3.3V, centered around 1.65V...
    19,539
    Without code and a diagram or photo, nobody can see what you've actually tried, nor try to reproduce the problem. We can't even tell from your message which Teensy you're using.
    Feb 2019
    2
    Sorry for the delay in posting code, I am working with the Teensy 3.6. After seeing Theremingenieur's response, I think that could be my issue because the differential signal has no point of reference on the Teensy, I will try some modifications tonight and get back to you.
    Here is the code I am working with:
    #include <ADC.h>
    #include <DMAChannel.h>
    #define BETTER_PI     3.141592654
    //const int MeasurementPin = A4;  // ADC0
    //const int MeasurementPin2 = A2;  // ADC1
    /*  We are now using the differential ADC to measure voltages
     *  The only exposed differential pair on the Teensy is connected to ADC1
     *  using pins A11 (ADC1_DM0, minus) and A10 (ADC1_DP0, plus)
    const int MeasurementPin_P = A10;
    const int MeasurementPin_M = A11;
    // SD Card pin thingy
    const int chipSelect = BUILTIN_SDCARD;
    // Number of samples to take before evaluating
    const uint32_t NUM_SAMPLES = 200;
    volatile uint16_t sample_cnt = 0;
    // Frequency to detect in Hz
    const uint16_t TGT_FREQ1 = 1000;
    const uint16_t TGT_FREQ2 = 2000;
    volatile int counter = 0;
    /* We don't actually need to keep all the samples but
     * it looks like DMA is the quickest way to get samples
     * out of the ADC and on top of that the best way to
     * know when we have NUM_SAMPLES full is with an interrupt
     * when the array is full.
    uint16_t samples[NUM_SAMPLES];
    const uint32_t SAMPLE_FREQ = 22050;
    /* This Goertzel algorithm implementation based off the
     *  Embedded Programming Magazine article by Kevin Banks
     *  August 20, 2002 (accessed 1/29/2019)
    const int32_t k1 = (int)(0.5 + ((NUM_SAMPLES * TGT_FREQ1) / SAMPLE_FREQ));
    const double w1 = ((2 * BETTER_PI) / NUM_SAMPLES) * k1;
    const double cosine_w1 = cos(w1);
    const double sine_w1 = sin(w1);
    const double GOERTZ_COEFF1 = 2 * cosine_w1;
    const int32_t k2 = (int)(0.5 + ((NUM_SAMPLES * TGT_FREQ2) / SAMPLE_FREQ));
    const double w2 = ((2 * BETTER_PI) / NUM_SAMPLES) * k2;
    const double cosine_w2 = cos(w2);
    const double sine_w2 = sin(w2);
    const double GOERTZ_COEFF2 = 2 * cosine_w2;
    // Per-sample processing variables
    volatile double Q01 = 0;
    volatile double Q11 = 0;
    volatile double Q21 = 0;
    volatile double Q02 = 0;
    volatile double Q12 = 0;
    volatile double Q22 = 0;
    // Check some values for mind sanity
    // sound of mind sound of body... hopefully
    volatile double min_gerd1 = 0;
    volatile double max_gerd1 = 0;
    volatile double min_gerd2 = 0;
    volatile double max_gerd2 = 0;
    volatile bool has_gerd = false;
    volatile double moving_avg1 = 0;
    volatile double moving_avg2 = 0;
    ADC *adc = new ADC(); // ADC object
    DMAChannel dma;       // DMA channel
    // Track where we are in samples
    int buffCount = 0;
      pinMode(LED_BUILTIN, OUTPUT);
      // According to Stoffgren forum post somewhere either don't
      // touch or use INPUT_DISABLE
      //pinMode(MeasurementPin_P, INPUT);
      //pinMode(MeasurementPin_M, INPUT);
      while(!Serial);
      Serial.println("Begin setup");
      Serial.println("Constants: ");
      Serial.print("Goertz coeff1: ");
      Serial.println(GOERTZ_COEFF1);
      Serial.print("Goertz coeff2: ");
      Serial.println(GOERTZ_COEFF2);
      Serial.print("Samples (N): ");
      Serial.println(NUM_SAMPLES);
      Serial.print("Tgt Frequency1: ");
      Serial.println(TGT_FREQ1);
      Serial.print("Tgt Frequency2: ");
      Serial.println(TGT_FREQ2);
      Serial.print("Measurement pin P: ");
      Serial.println(MeasurementPin_P);
      Serial.print("Measurement pin M: ");
      Serial.println(MeasurementPin_M);
      dmaInit();
      adcInit();
      Serial.println("Initializing SD card...");
      // see if the card is present and can be initialized:
      if (!SD.begin(chipSelect)) {
        Serial.println("Card failed, or not present");
        // don't do anything more:
        return;
      Serial.println("card initialized.");
      Serial.println("Starting PDB");
      adc->adc1->startPDB(SAMPLE_FREQ);
      Serial.println("End of setup");
    char c = 0;
    int value;
    int value2;
      if(Serial.available()) {
        c = Serial.read();
        if(c == 'd') {
          for(int i = 0; i < 16; i++) {
            Serial.println(samples[i]);
          Serial.println(" ");
        } else if (c == 'p') {
          Serial.print("Prescaler: ");
          Serial.println( (PDB0_SC & 0x7000) >> 12, HEX);
          Serial.print("Mult: ");
          Serial.println( (PDB0_SC & 0xC) >> 2, HEX);
        } else if (c == 'a') {
          Serial.println("Starting DMA sample again");
          // Run sampling again
          dma.attachInterrupt(dma_isr);
      /* fail_flag containes all possible errors, they are defined in ADC_Module.h as:
       *  ADC_ERROR_OTHER
       *  ADC_ERROR_CALIB
       *  ADC_ERROR_WRONG_PIN
       *  ADC_ERROR_ANALOG_READ
       *  ADC_ERROR_COMPARISON
       *  ADC_ERROR_ANALOG_DIFF_READ
       *  ADC_ERROR_CONT
       *  ADC_ERROR_CONT_DIFF
       *  ADC_ERROR_WRONG_ADC
       *  ADC_ERROR_SYNCH
       *  You can compare the value of the flag with those masks to know what's the error.
      if(adc->adc1->fail_flag) {
        Serial.print("ADC0 error flags: 0x");
        Serial.println(adc->adc1->fail_flag, HEX);
        if(adc->adc1->fail_flag == ADC_ERROR_COMPARISON) {
          adc->adc1->fail_flag &= ~ADC_ERROR_COMPARISON; // Clear the error
          Serial.println("Comparison error in ADC1");
    void dmaInit() {
      dma.source(*(uint16_t*) &ADC1_RA);
      dma.destinationBuffer(samples, sizeof(samples));
      dma.interruptAtCompletion();
      dma.triggerAtHardwareEvent(DMAMUX_SOURCE_ADC1);
      Serial.print("Samples start ");
      Serial.println(millis());
      dma.enable();
    void adcInit() {
      // ADC to use:
      int8_t adc_num = ADC_1;
      // reference can be ADC_REF_3V3, ADC_REF_1V2 (not for Teensy LC) or ADC_REF_EXT
      adc->setReference(ADC_REFERENCE::REF_3V3, adc_num);
      adc->setAveraging(4, adc_num);
      adc->setResolution(12, adc_num);
      // it can be ADC_VERY_LOW_SPEED, ADC_LOW_SPEED, ADC_MED_SPEED,
      // ADC_HIGH_SPEED_16BITS, ADC_HIGH_SPEED, ADC_VERY_HIGH_SPEED
      adc->setConversionSpeed(ADC_CONVERSION_SPEED::HIGH_SPEED_16BITS, adc_num);
      // it can be ADC_VERY_LOW_SPEED, ADC_LOW_SPEED, ADC_MED_SPEED, ADC_HIGH_SPEED, or ADC_VERY HIGH SPEED
      adc->setSamplingSpeed(ADC_SAMPLING_SPEED::HIGH_SPEED, adc_num); /// change the sampling speed
      adc->enableInterrupts(adc_num); // it's necessary to enable interrupts for PDB to work
      adc->enableDMA(adc_num); // enable DMA requeste ADC0_SC2 |= | ADC_SC2_ADTRG | ADC_SC2_DMAEN
      adc->analogReadDifferential(MeasurementPin_P, MeasurementPin_M, adc_num);
      //adc->analogRead(MeasurementPin, ADC_0); // Call this to setup everything before the PDB starts
      Serial.print("Is this adc in diff mode? ");
      Serial.println(adc->isDifferential(adc_num));
    void adc1_isr() {
      // Frequency 1
      Q01 = GOERTZ_COEFF1 * Q11 - Q21 + samples[sample_cnt];
      Q21 = Q11;
      Q11 = Q01;
      // Frequency 2
      Q02 = GOERTZ_COEFF2 * Q12 - Q22 + samples[sample_cnt];
      Q22 = Q12;
      Q12 = Q02;
      sample_cnt++;
    // pdb interrupt is enabled in case it is needed
    void pdb_isr(void) {
      PDB0_SC &= ~PDB_SC_PDBIF; // clear interrupt
      //Serial.print("pdb isr: ");
      //Serial.println(millis());
      //digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN) );
    void dma_isr() {
      adc->adc1->stopPDB();
      dma.detachInterrupt();
      dma.disable();
      uint16_t sample_cpy[NUM_SAMPLES];
      memcpy(sample_cpy, samples, sizeof(samples));
      memset(samples, 0, sizeof(samples));
      String dataString = "";
      String statString = "";
      for(int i = 0; i < NUM_SAMPLES; i++) {
        dataString += sample_cpy[i];
        dataString += ",";
      dataString += "fin";
      dma.clearInterrupt();
    //  Serial.print("Samples finished ");
    //  Serial.println(millis());
      // Goertzel calcs freq 1
      double magnitude_sq1 = (Q11 * Q11) + (Q21 * Q21) - Q11 * Q21 * GOERTZ_COEFF1;
      Serial.print("Gerds^2 1: ");
      Serial.println(magnitude_sq1);
      double magnitude1 = sqrt(magnitude_sq1);
      // Goertzel calcs freq 2
      double magnitude_sq2 = (Q12 * Q12) + (Q22 * Q22) - Q12 * Q22 * GOERTZ_COEFF2;
      Serial.print("Gerds^2 2: ");
      Serial.println(magnitude_sq2);
      double magnitude2 = sqrt(magnitude_sq2);
      Serial.print("Gerds Gertzels1,");
      Serial.print("Gerds Gertzels2,");
      Serial.print(magnitude1);
      Serial.print(",");
      Serial.println(magnitude2);
      statString += "Goertzel LF: ";
      statString += magnitude1;
      statString += "\nGoertzel HF: ";
      statString += magnitude2;
      statString += "\n";
      if(magnitude1 < min_gerd1) {
        min_gerd1 = magnitude1;
      if(magnitude1 > max_gerd1) {
        max_gerd1 = magnitude1;
      moving_avg1 = (moving_avg1 + magnitude1) / 2;
      if(magnitude2 < min_gerd2) {
        min_gerd2 = magnitude2;
      if(magnitude2 > max_gerd2) {
        max_gerd2 = magnitude2;
      moving_avg2 = (moving_avg2 + magnitude2) / 2;
      counter++;
      if(counter >= 100) {
        Serial.println("**********************************************");
        Serial.println("**************  200 Samples  *****************");
        counter = 0;
        delay(10000);
      // Set min_gerd on first run
      if(!has_gerd) {
      // Reset for next run of good ole Gertz
      Q11 = 0;
      Q21 = 0;
      Q12 = 0;
      Q22 = 0;
      sample_cnt = 0;
      File dataFile = SD.open("datalog.txt", FILE_WRITE);
      if(dataFile) {
        dataFile.println(dataString);
        dataFile.print(statString);
        dataFile.close();
        Serial.println("Written to file!");
        Serial.println("Error opening datalog.txt");
      dataFile.close();
      dma.enable();
    Also here is a very basic diagram of the circuit:
