hello to all
i m working on a project with 2 mux16 (74HC4067) connected to teensy3.6 all channel of the mux16 connected to buttons accept the last one
so i got 31 buttons im using this code t send sysex masseges when i press some button.
all the buttons r working great accept mux(1) channel 10.
first my guess was the soldering connection but i checked and do some measurement for all connections and everything is ok.
so i go to the code and i try to remove everything that related to mux(2) and finaly ch10 in mux(1) starts responding but then ch3 in mux(1) not respond.
hope u guys can help me with this code conflict.
here is the code im using:
tnx
rota
#include <Bounce.h>
const int channel = 1;
// Store the elapsed milliseconds for analog and multiplexed input smoothing/de-bouncing
elapsedMillis msec1 = 0;
long msecMux1[5] = {0, 0, 0, 0, 0};
elapsedMillis msec2 = 0;
long msecMux2[5] = {0, 0, 0, 0, 0};
// Setup mux1 chip pins
const int selectPins1[4] = {43, 44, 45, 46}; // S0~0, S1~1, S2~12
const int zInput1 = 13; // Connect common (Z) to 19 (digital input)
// Setup mux2 chip pins
const int selectPins2[4] = {24, 25, 26, 27}; // S0~0, S1~1, S2~12
const int zInput2 = 28; // Connect common (Z) to 19 (digital input)
// Mux1 button states for de-bouncing
int buttonState1[16] = { -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1};
int buttonStatePrev1[16] = { -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1};
// Mux2 button states for de-bouncing
int buttonState2[15] = { -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1,};
int buttonStatePrev2[15] = { -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1,};
// Set up the select pins as outputs for the mux chip and raise them:
for (int i = 0; i < 16; i++)
pinMode(selectPins1[i], OUTPUT);
digitalWrite(selectPins1[i], HIGH);
pinMode(selectPins2[i], OUTPUT);
digitalWrite(selectPins2[i], HIGH);
// Set up mux Z as an input
pinMode(zInput1, INPUT_PULLUP);
pinMode(zInput2, INPUT_PULLUP);
SysexButtonmsg();
// The selectMuxPin function sets the S0, S1, and S2 pins
// accordingly, given a pin from 0-7.
void selectMuxPin(byte pin){
for (int i = 0; i < 4; i++)
if (pin & (1 << i)){
delayMicroseconds(10);
else {
digitalWrite(selectPins1[i], LOW);
else {
digitalWrite(selectPins2[i], LOW);
//BUTTONS SYSEX COMMENDS
void SysexButtonmsg(){
//MUX1
// Loop through only the first five mux pins (last three are not connected)
for (byte pin = 0; pin <= 15; pin++)
// Effectively a 5ms debounce
if ((millis() - msecMux1[pin]) >= 5) {
selectMuxPin(pin); // Select one at a time
buttonState1[pin] = digitalRead(zInput1); // and read Z
if (buttonState1[pin] != buttonStatePrev1[pin]) {
// If a button is pressed
//SOLO BUTTONS
if (buttonState1[0] == 0) {
byte solo1push[] = { 0xB0,0x0F,0x00, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo1push, true);
else {
byte solo1release[] = { 0xB0,0x0F,0x00, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo1release, true);
if (buttonState1[2] == 0) {
byte solo2push[] = { 0xB0,0x0F,0x01, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo2push, true);
else {
byte solo2release[] = { 0xB0,0x0F,0x01, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo2release, true);
if (buttonState1[4] == 0) {
byte solo3push[] = { 0xB0,0x0F,0x02, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo3push, true);
else {
byte solo3release[] = { 0xB0,0x0F,0x02, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo3release, true);
if (buttonState1[6] == 0) {
byte solo4push[] = { 0xB0,0x0F,0x03, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo4push, true);
else {
byte solo4release[] = { 0xB0,0x0F,0x03, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo4release, true);
if (buttonState1[8] == 0) {
byte solo5push[] = { 0xB0,0x0F,0x04, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo5push, true);
else {
byte solo5release[] = { 0xB0,0x0F,0x04, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo5release, true);
if (buttonState1[10] == 0) {
byte solo6push[] = { 0xB0,0x0F,0x05, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo6push, true);
else {
byte solo6release[] = { 0xB0,0x0F,0x05, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo6release, true);
if (buttonState1[12] == 0) {
byte solo7push[] = { 0xB0,0x0F,0x06, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo7push, true);
else {
byte solo7release[] = { 0xB0,0x0F,0x06, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo7release, true);
if (buttonState1[14] == 0) {
byte solo8push[] = { 0xB0,0x0F,0x07, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo8push, true);
else {
byte solo8release[] = { 0xB0,0x0F,0x07, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, solo8release, true);
//MUTE BUTTONS
if (buttonState1[1] == 0) {
byte mute1push[] = { 0xB0,0x0F,0x00, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute1push, true);
else {
byte mute1release[] = { 0xB0,0x0F,0x00, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute1release, true);
if (buttonState1[3] == 0) {
byte mute2push[] = { 0xB0,0x0F,0x01, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute2push, true);
else {
byte mute2release[] = { 0xB0,0x0F,0x01, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute2release, true);
if (buttonState1[5] == 0) {
byte mute3push[] = { 0xB0,0x0F,0x02, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute3push, true);
else {
byte mute3release[] = { 0xB0,0x0F,0x02, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute3release, true);
if (buttonState1[7] == 0) {
byte mute4push[] = { 0xB0,0x0F,0x03, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute4push, true);
else {
byte mute4release[] = { 0xB0,0x0F,0x03, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute4release, true);
if (buttonState1[9] == 0) {
byte mute5push[] = { 0xB0,0x0F,0x04, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute5push, true);
else {
byte mute5release[] = { 0xB0,0x0F,0x04, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute5release, true);
if (buttonState1[11] == 0) {
byte mute6push[] = { 0xB0,0x0F,0x05, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute6push, true);
else {
byte mute6release[] = { 0xB0,0x0F,0x05, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute6release, true);
if (buttonState1[13] == 0) {
byte mute7push[] = { 0xB0,0x0F,0x06, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute7push, true);
else {
byte mute7release[] = { 0xB0,0x0F,0x06, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute7release, true);
if (buttonState1[15] == 0) {
byte mute8push[] = { 0xB0,0x0F,0x07, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute8push, true);
else {
byte mute8release[] = { 0xB0,0x0F,0x07, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, mute8release, true);
msecMux1[pin] = millis();
buttonStatePrev1[pin] = buttonState1[pin];
while (usbMIDI.read()) {
delay(10);
//TRANSPORT BUTTONS
//MUX2
if ((millis() - msecMux2[pin]) >= 5) {
buttonState2[pin] = digitalRead(zInput2); // and read Z
if (buttonState2[pin] != buttonStatePrev2[pin]) {
if (buttonState2[2] == 0) {
byte playpush[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x44}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, playpush, true);
else {
byte playrelease[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x04}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, playrelease, true);
if (buttonState2[3] == 0) {
byte stoppush[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, stoppush, true);
else {
byte stoprelease[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, stoprelease, true);
if (buttonState2[1] == 0) {
byte fastfwdpush[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, fastfwdpush, true);
else {
byte fastfwdrelease[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, fastfwdrelease, true);
if (buttonState2[0] == 0) {
byte rewindpush[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x41}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, rewindpush, true);
else {
byte rewindrelease[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x01}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, rewindrelease, true);
if (buttonState2[4] == 0) {
byte recpush[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x45}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, recpush, true);
else {
byte recrelease[] = { 0xB0,0x0F,0x0e, 0xB0,0x2F,0x05}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, recrelease, true);
if (buttonState2[5] == 0) {
byte qckpnchpush[] = { 0xB0,0x0F,0x0f, 0xB0,0x2F,0x44}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, qckpnchpush, true);
else {
byte qckpnchrelease[] = { 0xB0,0x0F,0x0f, 0xB0,0x2F,0x04}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, qckpnchrelease, true);
if (buttonState2[6] == 0) {
byte looppush[] = { 0xB0,0x0F,0x0f, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, looppush, true);
else {
byte looprelease[] = { 0xB0,0x0F,0x0f, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, looprelease, true);
// READ TOUCH LATCH WRITE
if (buttonState2[7] == 0) {
byte readpush[] = { 0xB0,0x0F,0x18, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, readpush, true);
else {
byte readrelease[] = { 0xB0,0x0F,0x18, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, readrelease, true);
if (buttonState2[8] == 0) {
byte touchpush[] = { 0xB0,0x0F,0x18, 0xB0,0x2F,0x45}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, touchpush, true);
else {
byte touchrelease[] = { 0xB0,0x0F,0x18, 0xB0,0x2F,0x05}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, touchrelease, true);
if (buttonState2[9] == 0) {
byte latchpush[] = { 0xB0,0x0F,0x18, 0xB0,0x2F,0x41}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, latchpush, true);
else {
byte latchrelease[] = { 0xB0,0x0F,0x18, 0xB0,0x2F,0x01}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, latchrelease, true);
if (buttonState2[10] == 0) {
byte writepush[] = { 0xB0,0x0F,0x18, 0xB0,0x2F,0x44}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, writepush, true);
else {
byte writerelease[] = { 0xB0,0x0F,0x18, 0xB0,0x2F,0x04}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, writerelease, true);
//BANKS LEFT RIGHT
if (buttonState2[13] == 0) {
byte chanl1leftpush[] = { 0xB0,0x0F,0x0a, 0xB0,0x2F,0x41}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, chanl1leftpush, true);
else {
byte chanl1leftrelease[] = { 0xB0,0x0F,0x0a, 0xB0,0x2F,0x01}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, chanl1leftrelease, true);
if (buttonState2[14] == 0) {
byte chanl8leftpush[] = { 0xB0,0x0F,0x0a, 0xB0,0x2F,0x40}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, chanl8leftpush, true);
else {
byte chanl8leftrelease[] = {0xB0,0x0F,0x0a, 0xB0,0x2F,0x00}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, chanl8leftrelease, true);
if (buttonState2[11] == 0) {
byte chanl1rightpush[] = { 0xB0,0x0F,0x0a, 0xB0,0x2F,0x42}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, chanl1rightpush, true);
else {
byte chanl1rightrelease[] = { 0xB0,0x0F,0x0a, 0xB0,0x2F,0x02}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, chanl1rightrelease, true);
if (buttonState2[12] == 0) {
byte chanl8rightpush[] = { 0xB0,0x0F,0x0a, 0xB0,0x2F,0x43}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, chanl8rightpush, true);
else {
byte chanl8rightrelease[] = { 0xB0,0x0F,0x0a, 0xB0,0x2F,0x03}; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(6, chanl8rightrelease, true);
msecMux2[pin] = millis();
buttonStatePrev2[pin] = buttonState2[pin];
// ignore incoming messages
delay(10);
rota
