Results 1 to 4 of 4
Thread: I2C Slave will not send data to master when requested
    Sep 2018
    4
    I have a simple master and slave code for two teensy 3.6 devices which are communicating via i2c. The master sends the slave the slave address, then 0xAA, and requests the slave to send 3 bytes of data in return. The slave does not send data in response. Can someone provide me insight as to why the slave device does not send data to the master? The master and slave code is included below.
    MASTER.inoSLAVE.ino
    Thank you so much,
    Sam
    Feb 2014
    Colmar, France
    2,386
    How do the SDA and SCL signals look on the oscilloscope? Which value are you using for the pull-up resistors? Do the two teensys have a common ground?
    Sep 2018
    4
    I have attached an oscilloscope screenshot that shows how the master and slave are interacting. The yellow waveform is the data line, and the green waveform is the clock signal. I am using 4.7 kOhm pull up resistors. The teensys do share a common ground.
    Feb 2017
    279
    Did you try adding debug prints to see if the actually gets the request?
