I want to drive a 3W LED. I can use a TIP120 or MOSFET to switch it from the teensy.
But what's the best practise to drive it, I suppose constant current source?
I did find a LDD-600LW, which works with a HiV or higher input :
https://www.mouser.be/ProductDetail/...muiJ%2FoXFU%3D
Or I can just a a sufficient resistor in series with the LED and power the led with a bit safer lower voltage?
Is there another solution or any recommendations?
BTW. It will be battery powered, probably a few AA Nimh's .
