Results 1 to 7 of 7
Thread: Is it possible to bitshift using ARM native bitshift operators?
    Looking in the user manual for the Teensy 3.x type processor uers guide, I have found 3 interesting commands that could possibly speed up bit shift operations for time critical code. The three specific operators for ARM assembler are
    LSR = Logical Shift Right
    ASR = "arithmetic" right shift
    LSL = Logical Shift Left
    excluding...
    RORS
    ROR
    RRXS
    RRX
    The three are quite interesting, but I am alittle taken because all examples reference uint32_t & int32_t only. What about uint8_t and int8_t and using the "LSL" and LSR" commands specifically. Do any experts in the group have experience using these commands and how should / could I make assembler code compatable with the Arduino or C++ language? Theres "__asm__" but how do I create such a function that inserts a value determining how far to shift similar to 1<<3 & 1>>3.
    BLMinTenn
    Germany NRW
    6,919
    normally the compiler does that automatically.
    and there are many more operations which can use shifts.
    then, often 8 bit is slower than 32 bit.
    so if you want fast code, use 32bit, uint32_t, not uint8_t.
    1,376
    When you use the << or >> operators in C/C++ code, the compiler will use those shift instructions anyway. For example, in some test code I used the statement "r = s << 3;" and the compiler executed the shift in one assembler instruction "lsls r3, r3, #3".
    The 3.x Teensys use a Cortex M4 processor which has a barrel shifter. This means that all shift instructions execute in one clock cycle. I don't see that there's much room for optimization here.
    What time critical code do you have in mind?
    Pete
    22,272
    Last time I checked, the compiler does indeed detect this as a rotate and implement it with 1 instruction:
    __attribute__((always_inline))
    static inline uint32_t lrotate(uint32_t num, uint32_t r)
            return (num >> r) | (num << (32 - r));
    Seattle, WA
    12
    You can quickly see what different compilers will do, using Godbolt compiler explorer.
    Just type in a non-inline function and ignore any function-call overhead, like the return at the end (bx lr).
    https://godbolt.org/z/vPLCD-
    Germany
    990
    Yes, this is a really useful tool. To see what modern compilers can do (and how tricky speed optimizations can be), try this:
    https://godbolt.org/z/Gi9vSE
    Good old Gauss would probably smile in his grave :-) https://betterexplained.com/articles...bers-1-to-100/
    Germany NRW
    6,919
    The -O3 -ffast-math is not even needed just -Os or even -Os1 is enough.
