I have a problem with the teensy 3.5 bootloader which seems to stop working.
I have made some changes in my program and flashed the teensy as normal. I am not sure but I think I add to much voltage to a analog pin, which is externally protected against higher voltage than 3.3V. Also the lcd stops working. After disconnect and reconnect everything looks like working normal even also the analog input. Only the bootloader seems to be corrupted.
Now my question: Is it possible to flash the Controller without the bootloader? I have an Atmel ICE on Hand.
As the teensy is brand new (few days) I dont want to loose it
Thanks,
Jens
Thanks,
Jens
