Results 1 to 3 of 3
Thread: Teensy 3.6 and APA 102 LED strips HELP!
    Mar 2019
    9
    Do I need to use a level shifter to run Apa 102 led strips from the Teensy 3.6?
    I am only able to get one led to turn on with the Teensy right now.
    Code works just fine when I use my Arduino but I have a 5 volt output on the Arduino...
    Feb 2014
    Colmar, France
    2,299
    What does the data sheet of your LED strip say, which logic voltage is required? If it’s 5V, the answer is clear: You need a level shifter of the 74HCT125 or 74HCT245 type. Simpler (and cheaper) level shifters with only one mosfet Transistor and a resistor have a too slow slew rate (switching speed) which causes timing problems.
    Mar 2019
    9
    Thanks for the tips!
    I ordered the 74HTC245N and the BOB-12009. I will see which one works.
