Results 1 to 6 of 6
Thread: Wire3 on teensy 3.6?
    Nov 2018
    8
    Hi!
    Im currently working on a project where it would be very beneficial to use all 4 I2C on the teensy 3.6.
    However,
    Wire.begin() //Works fine
    Wire1.begin() //Works fine
    Wire2.begin() //Works fine
    Wire3.begin() //'Wire3 was not declared in this scope
    Tested on both Platformio and Arduino ide with latest Teensyduino installed. Wire3 even gets highlighted in Arduino Ide, but it doesnt work.
    Any thoughts?
    4,569
    Go into the Wire library into the file WireKenitis.h
    You will see the section for T3.6
    // Teensy 3.6
    #elif defined(__MK66FX1M0__)
    #define WIRE_IMPLEMENT_WIRE
    #define WIRE_IMPLEMENT_WIRE1
    #define WIRE_IMPLEMENT_WIRE2
    //Wire3 is seldom used on Teensy 3.6
    //#define WIRE_IMPLEMENT_WIRE3
    #define WIRE_HAS_START_INTERRUPT
    #define WIRE_HAS_STOP_INTERRUPT
    Uncomment the define and you will have Wire3
    Nov 2018
    8
    Thanks! Now it at least compiles Up to test tomorrow.
    Wonder why it was commented out?
    Feb 2014
    Colmar, France
    2,385
    It was commented out because each declared WIRE instance eats up a few system resources, if used afterwards or not. And WIRE3 is a fourth I2C bus. Seen that each bus can theoretically handle 120 devices, under condition of thoughtful addressing, this fourth wire instance would only be needed from the 361st peripheral...
    19,929
    Quote Originally Posted by Frassil View Post
    As mentioned earlier, each one eats up some RAM even if not used.
    Almost nobody uses Wire3, parly because Wire, Wire1 and Wire2 meet almost everyone's needed, but also because Wire3's pins are only on the bottom side pads.
    In fact, as far as I can recall, this is the first time in 2 years anyone has even asked about how to use Wire3.
    Dec 2016
    Montreal, Canada
    3,003
